| 1 |
greg |
1.3 |
.\" RCSid "$Id: dgraph.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
| 2 |
greg |
1.1 |
.TH DGRAPH 1 6/24/98 RADIANCE |
| 3 |
.SH NAME |
| 4 |
dgraph - do a set of graphs to a dumb terminal |
| 5 |
.SH SYNOPSIS |
| 6 |
.B dgraph |
| 7 |
| 8 |
.B -w width |
| 9 |
| 10 |
.B -l length |
| 11 |
| 12 |
.B +variable value .. |
| 13 |
| 14 |
.B file .. |
| 15 |
| 16 |
.SH DESCRIPTION |
| 17 |
.I Dgraph |
| 18 |
reads each graph |
| 19 |
.I file |
| 20 |
in sequence and converts it to a character plot |
| 21 |
displayable on any ascii device. |
| 22 |
If no files are given, the standard input is read. |
| 23 |
.PP |
| 24 |
Across the top of the plot, the extrema are printed. |
| 25 |
This is the only indication of the axis size. |
| 26 |
Curves are represented with their respective letter ('A' for |
| 27 |
curve A, etc.) at each point. |
| 28 |
Where two or more curves cross, a number is shown instead. |
| 29 |
.PP |
| 30 |
The size of the output array can be specified as a |
| 31 |
certain |
| 32 |
.I width |
| 33 |
and |
| 34 |
.I length. |
| 35 |
The default size is 79 by 22. |
| 36 |
.PP |
| 37 |
Variables can be set explicitly with |
| 38 |
.I +variable value |
| 39 |
options. |
| 40 |
See bgraph(1) for details. |
| 41 |
.SH EXAMPLE |
| 42 |
To get a quick glimpse of the sine function from 0 to 4. |
| 43 |
.nf |
| 44 |
dgraph |
| 45 |
A(x)=sin(x) |
| 46 |
Anpoints=100 |
| 47 |
xmin=0 |
| 48 |
xmax=4 |
| 49 |
^D |
| 50 |
.fi |
| 51 |
.SH AUTHOR |
| 52 |
Greg Ward |
| 53 |
.SH BUGS |
| 54 |
There is no mechanism provided for undefining a variable. |
| 55 |
.SH "SEE ALSO" |
| 56 |
greg |
1.3 |
bgraph(1), gcomp(1), icalc(1), igraph(1) |
