root/radiance/doc/man/man1/dgraph.1
Revision: 1.3
Committed: Thu Jan 1 19:31:44 2004 UTC (21 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
1 .\" RCSid "$Id: dgraph.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH DGRAPH 1 6/24/98 RADIANCE
3 .SH NAME
4 dgraph - do a set of graphs to a dumb terminal
5 .SH SYNOPSIS
6 .B dgraph
7 [
8 .B -w width
9 ][
10 .B -l length
11 ][
12 .B +variable value ..
13 ][
14 .B file ..
15 ]
16 .SH DESCRIPTION
17 .I Dgraph
18 reads each graph
19 .I file
20 in sequence and converts it to a character plot
21 displayable on any ascii device.
22 If no files are given, the standard input is read.
23 .PP
24 Across the top of the plot, the extrema are printed.
25 This is the only indication of the axis size.
26 Curves are represented with their respective letter ('A' for
27 curve A, etc.) at each point.
28 Where two or more curves cross, a number is shown instead.
29 .PP
30 The size of the output array can be specified as a
31 certain
32 .I width
33 and
34 .I length.
35 The default size is 79 by 22.
36 .PP
37 Variables can be set explicitly with
38 .I +variable value
39 options.
40 See bgraph(1) for details.
41 .SH EXAMPLE
42 To get a quick glimpse of the sine function from 0 to 4.
43 .nf
44 dgraph
45 A(x)=sin(x)
46 Anpoints=100
47 xmin=0
48 xmax=4
49 ^D
50 .fi
51 .SH AUTHOR
52 Greg Ward
53 .SH BUGS
54 There is no mechanism provided for undefining a variable.
55 .SH "SEE ALSO"
56 bgraph(1), gcomp(1), icalc(1), igraph(1)
