root/radiance/doc/man/man1/dgraph.1
Revision: 1.3
Committed: Thu Jan 1 19:31:44 2004 UTC (21 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: dgraph.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH DGRAPH 1 6/24/98 RADIANCE
3     .SH NAME
4     dgraph - do a set of graphs to a dumb terminal
5     .SH SYNOPSIS
6     .B dgraph
7     [
8     .B -w width
9     ][
10     .B -l length
11     ][
12     .B +variable value ..
13     ][
14     .B file ..
15     ]
16     .SH DESCRIPTION
17     .I Dgraph
18     reads each graph
19     .I file
20     in sequence and converts it to a character plot
21     displayable on any ascii device.
22     If no files are given, the standard input is read.
23     .PP
24     Across the top of the plot, the extrema are printed.
25     This is the only indication of the axis size.
26     Curves are represented with their respective letter ('A' for
27     curve A, etc.) at each point.
28     Where two or more curves cross, a number is shown instead.
29     .PP
30     The size of the output array can be specified as a
31     certain
32     .I width
33     and
34     .I length.
35     The default size is 79 by 22.
36     .PP
37     Variables can be set explicitly with
38     .I +variable value
39     options.
40     See bgraph(1) for details.
41     .SH EXAMPLE
42     To get a quick glimpse of the sine function from 0 to 4.
43     .nf
44     dgraph
45     A(x)=sin(x)
46     Anpoints=100
47     xmin=0
48     xmax=4
49     ^D
50     .fi
51     .SH AUTHOR
52     Greg Ward
53     .SH BUGS
54     There is no mechanism provided for undefining a variable.
55     .SH "SEE ALSO"
56 greg 1.3 bgraph(1), gcomp(1), icalc(1), igraph(1)
