root/radiance/doc/man/man1/bsdfview.1
Revision: 1.6
Committed: Fri Jul 20 00:50:40 2018 UTC (7 years, 3 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 1.5: +8 -1 lines
Added "-r" option to bsdf2rad and bsdfview to fix plotting range
# User Rev Content
1 greg 1.6 .\" RCSid "$Id: bsdfview.1,v 1.5 2017/10/18 19:30:48 greg Exp $"
2 greg 1.1 .TH BSDFVIEW 1 8/11/2017 RADIANCE
3     .SH NAME
4     bsdfview - view a BSDF representation
5     .SH SYNOPSIS
6     .B bsdfview
7     [
8     .B "\-q {Hi|Med|Lo}"
9     ][
10 greg 1.4 .B \-t
11     |
12 greg 1.1 rad options
13 greg 1.6 ][
14     .B "\-r min max"
15 greg 1.1 ]
16     input ..
17     .br
18     .SH DESCRIPTION
19     .I Bsdfview
20     renders a BSDF description interactively.
21 greg 1.3 This is a script that creates a
22 greg 1.1 .I rad(1)
23 greg 1.3 input file (RIF),
24     which builds an octree via
25 greg 1.2 .I bsdf2rad(1),
26 greg 1.4 then renders the scene interactively or calls the
27     .I trad(1)
28     graphical user interface if the
29     .I \-t
30     option is given.
31 greg 1.1 .PP
32     The input is either a single XML file, such as might be produced by
33     .I genBSDF(1),
34     .I bsdf2klems(1),
35     or
36     .I bsdf2ttree(1),
37 greg 1.2 or up to four scattering interpolation representation (SIR) files, as
38 greg 1.1 might be produced by
39     pabopto2bsdf(1).
40     .PP
41 greg 1.3 A
42     .I rad
43     input file will be produced, whose name matches the root of
44 greg 1.1 the first input file but with any leading path removed (i.e., in
45     the current directory).
46     This RIF may be reused for subsequent viewing and rendering via
47     .I rad
48     without incurring the cost of another call to
49     .I bsdf2rad.
50     .PP
51     The quality preference may be set via the
52     .I \-q
53     option.
54     The number of processors to use may be specified with the
55     .I \-n
56     option.
57     .PP
58     The program creates a number of views accessible via the
59     .I rvu(1)
60     "L" command:
61     .TP 10n
62     .BR def
63     The default view, showing the back and front BRDFs.
64     .TP
65     .BR fr
66     A view of the front reflection hemisphere.
67     .TP
68     .BR br
69     A view of the back reflection hemisphere.
70     .TP
71     .BR ft
72     A fisheye view of the front transmission hemisphere (from underneath).
73     .TP
74     .BR bt
75     A fisheye view of the back transmission hemisphere.
76     .TP
77     .BR pr
78     A parallel view of both reflection hemispheres from directly overhead.
79     .TP
80     .BR pt
81     A parallel view of both transmission hemispheres from directly underneath.
82     .PP
83     Additionally, all the standard views that
84     .I rvu
85     defines will be available (e.g., "xZ", "zl", etc.).
86 greg 1.3 .PP
87     Since a
88     .I rad
89     input file is created by the script, it may be used
90     in subsequent runs as long as the temporary files remain.
91     These are typically kept until the next reboot of the operating
92     system, so re-running
93     .I bsdfview
94     with the same arguments will not require re-running
95     .I bsdf2rad
96     or
97     .I oconv.
98     Thus, start-up will be much quicker, unless the temporary files have
99     been removed.
100     In this case, the script may exit with an error indicating that the
101     .I rad
102     input file needs to be removed.
103 greg 1.4 .PP
104     This input file may also be re-used directly from the command line using
105     .I rad
106     or
107 greg 1.3 .I trad(1).
108     This may be useful for generating RADIANCE pictures corresponding
109     to the above standard views.
110 greg 1.5 If no interactive run is desired, start
111     .I bsdfview
112     with the
113     .I "-v 0"
114     option.
115 greg 1.6 .PP
116     If an optional plotting range is given with the
117     .I \-r
118     option, this will override automatic settings from the BSDF input.
119     This may be useful for comparing different BSDF sources.
120 greg 1.1 .SH AUTHOR
121     Greg Ward
122     .SH "SEE ALSO"
123     bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), genBSDF(1),
124 greg 1.3 objview(1), oconv(1), pabopto2bsdf(1), rad(1), rvu(1), trad(1)
