root/radiance/doc/filefmts.ms
Revision: 1.3
Committed: Thu Nov 24 02:01:39 2022 UTC (2 years, 10 months ago) by greg
Content type: application/x-troff-ms
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 1.2: +19 -18 lines
docs(filefmts): updates and additions from Randolph Fritz
1 .\" RCSid $Id: filefmts.ms,v 1.2 2022/11/11 02:38:34 greg Exp $
2 .EQ
3 delim @@
4 .EN
5 .SH 1
6 \f[BI]Radiance\f[B] File Formats
7 .pdfhref O 1 "Radiance File Formats"
8 .pdfhref M "radiance-file-formats"
9 .LP
10 This chapter discusses the standard file formats specific to
11 \f[I]Radiance\f[R], and gives their internal structure, with pointers to
12 routines for reading and writing them.
13 The following file formats (listed with their conventional suffixes) are
14 covered:
15 .IP "\f[B]Scene Description (.rad suffix)\f[R]" 3
16 This is the main input file type, describing materials and geometry for
17 the rendering programs, and must be compiled into an octree by oconv
18 prior to ray-tracing.
19 It is an ASCII text format, and is often translated from a CAD
20 description, but may be created or edited by a text editor as well.
21 .RS 3
22 .RE
23 .IP "\f[B]Function File (.cal suffix)\f[R]" 3
24 Also a text format, these files describe mathematical patterns,
25 textures, and surface shapes.
26 In the case of patterns and textures, the functions serve as input
27 directly to the rendering programs.
28 In the case of surfaces, the functions serve as input to one of the
29 generator programs, \f[B]gensurf\f[R], \f[B]genrev\f[R] or
30 \f[B]genworm\f[R].
31 Additionally, \f[B]pcomb\f[R] may be used to perform math on
32 \f[I]Radiance\f[R] pictures and the \f[B]rcalc\f[R] utility may be used
33 in creative ways to manipulate data for scene generation and data
34 analysis.
35 .RS 3
36 .RE
37 .IP "\f[B]Data File (.dat suffix)\f[R]" 3
38 Another ASCII format, data files are used directly by the rendering
39 programs to interpolate values for luminaire photometry, among other
40 things.
41 .RS 3
42 .RE
43 .IP "\f[B]Font File (.fnt suffix)\f[R]" 3
44 A simple, polygonal font representation for rendering text patterns.
45 This ASCII format describes each character \[lq]glyph\[rq] as a sequence
46 of vertices in rectangular, integer coordinates ranging from 0 to 255.
47 .RS 3
48 .RE
49 .IP "\f[B]Octree (.oct suffix)\f[R]" 3
50 A binary data structure computed from one or more scene description
51 files by the oconv program.
52 It may contain frozen scene data in binary form, or merely references to
53 the original scene files.
54 .RS 3
55 .RE
56 .IP "\f[B]Picture (.hdr suffix)\f[R]" 3
57 A binary image file containing calibrated, real radiance values at each
58 pixel.
59 \f[I]Radiance\f[R] pictures may be displayed, analyzed, and converted to
60 other image formats.
61 .RS 3
62 .RE
63 .IP "\f[B]Z-buffer (.zbf suffix)\f[R]" 3
64 A binary file with the distances to each pixel in a corresponding
65 picture.
66 .RS 3
67 .RE
68 .IP "\f[B]Ambient File (.amb suffix)\f[R]" 3
69 A binary file used to store diffuse interreflection values, which are
70 shared between cooperating rendering processes running sequentially or
71 in parallel.
72 Since these values are view-independent, sharing this information across
73 multiple runs is highly economical.
74 .RS 3
75 .RE
76 .LP
77 We will discuss each of these formats in turn, giving examples and
78 pointers to routines in the source code for reading and writing them,
79 and the programs that use them.
80 In general, the ASCII text formats have no standard routines for writing
81 them, since they generally originate outside of \f[I]Radiance\f[R] or
82 are created with simple \f[I]printf(3)\f[R] statements.
83 Most binary file formats are machine and system independent, meaning
84 they can be moved safely from one place to another and
85 \f[I]Radiance\f[R] will still understand them (provided no unintentional
86 character translation takes place along the way)\**.
87 .FS
88 The single exception to this rule is the Z-buffer file, whose contents
89 are dictated by the floating point representation and byte order of the
90 originating machine.
91 This choice was made for economic reasons, and is rarely a problem.
92 .FE
93 Most binary files also include a standard ASCII header at their
94 beginning that may be read by the \f[B]getinfo\f[R] program.
95 This offers a convenient method for identifying the file contents when
96 the file name is ambiguous.
97 .SH 2
98 Scene Description Format (.rad suffix)
99 .pdfhref O 2 "Scene Description Format \(.rad suffix\)"
100 .pdfhref M "scene-description-format-.rad-suffix"
101 .LP
102 The semantics of the \f[I]Radiance\f[R] scene description format are
103 covered in the Reference Manual.
104 We will therefore focus on the file syntax and structure, which are
105 simple and straightforward.
106 In fact, some would say that the \f[I]Radiance\f[R] scene description
107 format is brain-dead, in the sense that it offers few language amenities
108 and requires the awkward counting of string and real arguments (not to
109 mention those non-existent integer arguments).
110 We have little to offer in its defense.
111 .PP
112 The truth is, the scene format was designed to grow with
113 \f[I]Radiance\f[R], and we wanted to keep it as simple as possible so as
114 to encourage others to write translators to and from it.
115 Specifically, we wanted to be able to read files using the
116 \f[I]scanf(3)\f[R] library function and write files using
117 \f[I]printf(3)\f[R].
118 Furthermore, we wanted everyone\[cq]s parsers to be stable over time,
119 which meant no primitive-specific syntax.
120 We also decided that a flat file structure was most practical, since
121 hierarchies are typically lost on the first translation, and sufficient
122 structure could be provided by the file system itself.
123 Since we did not intend text editing to be the primary input method, we
124 felt the effects of these programming decisions on the human readability
125 and writability of the format were less important.
126 .PP
127 Even so, the format is relatively easy to read and write once you get
128 used to it, and with the \f[I]Radiance\f[R] generator programs and
129 in-line command expansion, the text editor becomes a powerful modeling
130 tool in the hands of an experienced user.
131 Together with the need for editing material descriptions, our assumption
132 that users would rarely edit these files turned out to be mistaken.
133 Consequently, it is a good idea for all users to familiarize themselves
134 with the scene description format, awkward or not.
135 .SH 3
136 Basic File Structure
137 .pdfhref O 3 "Basic File Structure"
138 .pdfhref M "basic-file-structure"
139 .LP
140 There are four statement types in a scene description file: comments,
141 commands, primitives and aliases.
142 These may be interspersed in the file, and the only structural
143 requirement is that modifiers precede the primitives they modify.
144 .SH 4
145 Comments
146 .pdfhref O 4 "Comments"
147 .pdfhref M "comments"
148 .LP
149 The simplest statement type is a comment statement begins with a pound
150 sign (`#') and continues to the end of line:
151 .IP
152 .nf
153 \f[C]
154 # This is a comment.
155 \f[]
156 .fi
157 .SH 4
158 Commands
159 .pdfhref O 4 "Commands"
160 .pdfhref M "commands"
161 .LP
162 An in-line command, which begins with an exclamation mark (`!') and
163 continues to the end of line:
164 .IP
165 .nf
166 \f[C]
167 !xform -n chair1 -t 10 5 8 chair.rad
168 \f[]
169 .fi
170 .LP
171 The command is executed during file parsing, and its output is read as
172 more input.
173 Long commands may be continued on multiple lines by escaping the newline
174 character with a backslash (`\[rs]'):
175 .IP
176 .nf
177 \f[C]
178 !gensurf marble sink \[aq]15.5+x(theta(s),phi(t))\[aq] \[rs]
179 \[aq]10.5+y(theta(s),phi(t))\[aq] \[rs]
180 \[aq]30.75+z(theta(s),phi(t))\[aq] \[rs]
181 8 29 -f basin.cal -s
182 \f[]
183 .fi
184 .LP
185 Since the command is executed by the shell, pipes and other facilities
186 are available as well.
187 The following command creates a counter with a precisely cut hole for
188 the sink basin just given:
189 .IP
190 .nf
191 \f[C]
192 !( echo marble polygon sink_top 0 0 108 31 \[rs]
193 10.5 30.75 31 22 30.75 0 22 30.75 0 0 \[rs]
194 30.75 31 0 30.75 31 10.5 30.75 ; \[rs]
195 cnt 30 | rcalc \[rs]
196 -e \[aq]$1=15.5+x(theta(0),phi(1-$1/29))\[aq] \[rs]
197 -e \[aq]$2=10.5+y(theta(0),phi(1-$1/29))\[aq] \[rs]
198 -e \[aq]$3=30.75\[aq] -f basin.cal )
199 \f[]
200 .fi
201 .LP
202 Note in the above example that two commands are executed in sequence.
203 The first creates the counter perimeter, and the second cuts the hole.
204 The two commands are enclosed in parentheses, so if a final
205 transformation is added by \f[B]xform\f[R] with the \f[B]-c\f[R] option,
206 it will be applied to both commands, not just the last one.
207 .SH 4
208 Primitives
209 .pdfhref O 4 "Primitives"
210 .pdfhref M "primitives"
211 .LP
212 A primitive can be thought of as an indivisible unit of scene
213 information.
214 It can be a surface, material, pattern, texture or mixture.
215 The basic structure of a primitive is as follows:
216 .IP
217 .nf
218 \f[C]
219 modifier type identifier
220 n S1 S2 S3 ..Sn
221 0
222 m R1 R2 R3 ..Rm
223 \f[]
224 .fi
225 .LP
226 The \f[C]modifier\f[R] is the \f[C]identifier\f[R] of a previously
227 defined primitive, or \f[C]void\f[R] if no modifier is appropriate.
228 The type is one of the supported \f[I]Radiance\f[R] primitive keywords,
229 such as \f[I]polygon\f[R] or \f[I]plastic\f[R].
230 Following the \f[C]modifier\f[R], type and identifier are the string
231 arguments, preceded by the number of string arguments and separated by
232 white space.
233 If there are no string arguments, then 0 should be given for
234 \f[C]n\f[R].
235 The string arguments are followed by the integer arguments in the same
236 fashion.
237 (Since there are no \f[I]Radiance\f[R] primitives currently using
238 integer arguments, the count is always 0.)
239 Finally, the number of real arguments is given, followed by the real
240 arguments.
241 .PP
242 The location of the primitive in the scene description has no
243 importance, except that its modifier refers to the most recently defined
244 primitive with that identifier.
245 If no such modifier was defined, an error results.
246 In fact, \[lq]undefined modifier\[rq] is the most frequently reported
247 error when parsing an invalid scene description, since any random bit of
248 junk encountered where a statement is expected will be interpreted as a
249 modifier.
250 One final note about modifiers \[em] since surfaces never modify
251 anything, their identifiers are neither stored nor referenced in the
252 parser\[cq]s modifier list, and serve only for debugging purposes during
253 editing and rendering.
254 .PP
255 Within a primitive, white space serves only to separate words, and
256 multiple spaces, tabs, form feeds, returns, and newlines are all
257 considered as one separator.
258 Consequently, it is not possible for a string argument to contain any
259 white space, which is OK because no \f[I]Radiance\f[R] primitive needs
260 this.
261 .SH 4
262 Aliases
263 .pdfhref O 4 "Aliases"
264 .pdfhref M "aliases"
265 .LP
266 An alias simply associates a new modifier and identifier with a
267 previously defined primitive.
268 The syntax is as follows:
269 .IP
270 .nf
271 \f[C]
272 modifier alias new_identifier old_identifier
273 \f[]
274 .fi
275 .LP
276 The \f[C]old_identifier\f[R] should be associated with some modifier
277 primitive (i.e., non-surface) given earlier.
278 The \f[C]modifier\f[R], if different from the original, will be used
279 instead in later applications of \f[C]new_identifier\f[R].
280 .PP
281 Aliases are most often used to give new names to previously defined
282 materials.
283 They may also be used to associate different patterns or textures with
284 the same material.
285 .SH 3
286 Scene Hierarchy
287 .pdfhref O 3 "Scene Hierarchy"
288 .pdfhref M "scene-hierarchy"
289 .LP
290 Hierarchical scene descriptions are achieved through expansion of
291 in-line \f[B]xform\f[R] commands.
292 The \f[B]xform\f[R] command is used to read and place other
293 \f[I]Radiance\f[R] scene description files in the calling file, and
294 these other descriptions may in turn read others, and so on down the
295 tree.
296 No check is made to assure that none of the calling files is called
297 again, even by itself.
298 If this happens, commands open commands until the system runs out of
299 processes, which is a very nasty business and to be avoided.
300 .SH 3
301 \f[BI]Radiance\f[B] Programs
302 .pdfhref O 3 "Radiance Programs"
303 .pdfhref M "radiance-programs"
304 .LP
305 The following table shows programs in the main \f[I]Radiance\f[R]
306 distribution that read and write scene description files.
307 Additionally, there are other translators that write scene files, which
308 are available separately as free contributions or as part of other (CAD)
309 programs.
310 .PP
311 .na
312 .TS
313 delim(@@) tab( );
314 l l l l.
315 T{
316 Program
317 T} T{
318 Read
319 T} T{
320 Write
321 T} T{
322 Function
323 T}
324 _
325 T{
326 \f[B]arch2rad\f[R]
327 T} T{
328 T} T{
329 X
330 T} T{
331 Convert Architrion text file to \f[I]Radiance\f[R]
332 T}
333 T{
334 \f[B]genblinds\f[R]
335 T} T{
336 T} T{
337 X
338 T} T{
339 Generate curved venetian blinds
340 T}
341 T{
342 \f[B]genbox\f[R]
343 T} T{
344 T} T{
345 X
346 T} T{
347 Generate parallelepiped
348 T}
349 T{
350 \f[B]genclock\f[R]
351 T} T{
352 T} T{
353 X
354 T} T{
355 Generate analog clock
356 T}
357 T{
358 \f[B]genprism\f[R]
359 T} T{
360 T} T{
361 X
362 T} T{
363 Generate extruded polygon
364 T}
365 T{
366 \f[B]genrev\f[R]
367 T} T{
368 T} T{
369 X
370 T} T{
371 Generate surface of revolution
372 T}
373 T{
374 \f[B]gensky\f[R]
375 T} T{
376 T} T{
377 X
378 T} T{
379 Generate CIE sky distribution
380 T}
381 T{
382 \f[B]gensurf\f[R]
383 T} T{
384 T} T{
385 X
386 T} T{
387 Generate arbitrary surface patch
388 T}
389 T{
390 \f[B]genworm\f[R]
391 T} T{
392 T} T{
393 X
394 T} T{
395 Generate varying diameter curved path
396 T}
397 T{
398 \f[B]ies2rad\f[R]
399 T} T{
400 T} T{
401 X
402 T} T{
403 Convert IES luminaire file to \f[I]Radiance\f[R]
404 T}
405 T{
406 \f[B]mgf2rad\f[R]
407 T} T{
408 T} T{
409 X
410 T} T{
411 Convert MGF file to \f[I]Radiance\f[R]
412 T}
413 T{
414 \f[B]mkillum\f[R]
415 T} T{
416 X
417 T} T{
418 X
419 T} T{
420 Compute \f[I]illum\f[R] secondary sources
421 T}
422 T{
423 \f[B]nff2rad\f[R]
424 T} T{
425 T} T{
426 X
427 T} T{
428 Convert NFF file to \f[I]Radiance\f[R]
429 T}
430 T{
431 \f[B]objline\f[R]
432 T} T{
433 T} T{
434 X
435 T} T{
436 Generate line drawing of \f[I]Radiance\f[R] file
437 T}
438 T{
439 \f[B]objview\f[R]
440 T} T{
441 T} T{
442 X
443 T} T{
444 Quick view of \f[I]Radiance\f[R] object
445 T}
446 T{
447 \f[B]oconv\f[R]
448 T} T{
449 T} T{
450 X
451 T} T{
452 Compile \f[I]Radiance\f[R] scene description
453 T}
454 T{
455 \f[B]obj2rad\f[R]
456 T} T{
457 T} T{
458 X
459 T} T{
460 Convert Wavefront .OBJ file to \f[I]Radiance\f[R]
461 T}
462 T{
463 \f[B]rad\f[R]
464 T} T{
465 X
466 T} T{
467 T} T{
468 Render \f[I]Radiance\f[R] scene
469 T}
470 T{
471 \f[B]rad2mgf\f[R]
472 T} T{
473 X
474 T} T{
475 T} T{
476 Convert \f[I]Radiance\f[R] file to MGF
477 T}
478 T{
479 \f[B]raddepend\f[R]
480 T} T{
481 X
482 T} T{
483 T} T{
484 Determine scene file dependencies
485 T}
486 T{
487 \f[B]replmarks\f[R]
488 T} T{
489 X
490 T} T{
491 X
492 T} T{
493 Replace triangular markers with objects
494 T}
495 T{
496 \f[B]rpict\f[R]
497 T} T{
498 X
499 T} T{
500 T} T{
501 Batch rendering program
502 T}
503 T{
504 \f[B]rtrace\f[R]
505 T} T{
506 X
507 T} T{
508 T} T{
509 Customizable ray-tracer
510 T}
511 T{
512 \f[B]rview\f[R]
513 T} T{
514 X
515 T} T{
516 T} T{
517 Interactive renderer
518 T}
519 T{
520 \f[B]thf2rad\f[R]
521 T} T{
522 T} T{
523 X
524 T} T{
525 Convert GDS things file to \f[I]Radiance\f[R]
526 T}
527 T{
528 \f[B]tmesh2rad\f[R]
529 T} T{
530 T} T{
531 X
532 T} T{
533 Convert triangle mesh file to \f[I]Radiance\f[R]
534 T}
535 T{
536 \f[B]xform\f[R]
537 T} T{
538 X
539 T} T{
540 X
541 T} T{
542 Transform Radiance objects
543 T}
544 .TE
545 .ad
546 .LP
547 \f[B]Table 1.\f[R] Radiance programs that read and write scene
548 descriptions.
549 .SH 3
550 \f[BI]Radiance\f[B] C Library
551 .pdfhref O 3 "Radiance C Library"
552 .pdfhref M "radiance-c-library"
553 .LP
554 The principal library function for reading scene description files is
555 \f[C]readobj(inpspec)\f[R], defined in \f[C]src/common/readobj.c\f[R].
556 This routine takes the name of a file, or command beginning with `!', or
557 \f[C]NULL\f[R] if standard input is to be read, and loads the
558 \f[I]Radiance\f[R] data structures defined in
559 \f[C]src/common/object.h\f[R].
560 If loading \f[I]Radiance\f[R] data structures is not the action desired,
561 then a more custom approach is necessary, such as that used in
562 \f[C]src/gen/xform.c\f[R].
563 If using \f[I]Radiance\f[R] data structures is acceptable, but the data
564 need not remain resident in memory, then follow the lead in
565 \f[C]src/ot/getbbox.c\f[R] and use \f[C]src/ot/readobj2.c\f[R] instead.
566 In any case, the list of defined primitive types in
567 \f[C]src/common/otypes.h\f[R] is crucial.
568 .SH 2
569 Function File Format (.cal suffix)
570 .pdfhref O 2 "Function File Format \(.cal suffix\)"
571 .pdfhref M "function-file-format-.cal-suffix"
572 .LP
573 Function files are used throughout \f[I]Radiance\f[R] to specify
574 mathematical formulas and relations for procedural textures, patterns
575 and surfaces.
576 They are also used by filter programs such as rcalc to manipulate data,
577 and pcomb to manipulate pictures.
578 .PP
579 Function file syntax is simple and should be familiar to most
580 programmers, as it is based on fairly standard algebraic expressions.
581 Here is an example, which corresponds to the in-line commands given in
582 the previous section:
583 .IP
584 .nf
585 \f[C]
586 {
587 basin.cal - calculate coordinates for basin sink.
588 }
589
590 theta(s) = PI*(0.5+0.5*s);
591 phi(t) = 2*PI*t;
592
593 R(th,p) = 5 + ( 3.25*cos(p)\[ha]2 +
594 1.75*sin(p)\[ha]2 ) * sin(th)\[ha]2;
595
596 x(th,p) = R(th,p)*sin(th)*cos(p);
597 y(th,p) = R(th,p)*sin(th)*sin(p);
598 z(th,p) = R(th,p)*cos(th);
599 \f[]
600 .fi
601 .LP
602 In contrast to the usual semantics in programs where each statement
603 corresponds to an evaluation, statements in function files correspond to
604 \f[I]definitions\f[R].
605 Once a function or variable has been defined, it may be used in later
606 definitions, along with predefined functions such as \f[C]sin(x)\f[R]
607 and \f[C]cos(x)\f[R] and constants such as \f[C]PI\f[R]\**.
608 .FS
609 TBD - There once was a footnote here
610 .FE
611 (All math functions use standard C conventions, hence trigonometry is
612 done in radians rather than degrees.)
613 .PP
614 Evaluation order (operator precedence) follows standard rules of
615 algebra.
616 Exponentiation is performed first \f[C](x\[ha]y)\f[R], followed by
617 multiplication and division \f[C](x*y, x/y)\f[R], then addition and
618 subtraction \f[C](x+y, x-y)\f[R].
619 Unary minus is most tightly associated \f[C](-x)\f[R], and parentheses
620 override operator precedence in the usual way.
621 Semicolons separate statements, and white space is generally ignored.
622 Comments are enclosed by curly braces, which may be nested.
623 .PP
624 The above file does not actually \f[I]do\f[R] anything, it merely
625 defines functions that are useful by a program that does.
626 Taking our \f[B]gensurf\f[R] example from the previous section:
627 .IP
628 .nf
629 \f[C]
630 !gensurf marble sink \[aq]15.5+x(theta(s),phi(t))\[aq] \[rs]
631 \[aq]10.5+y(theta(s),phi(t))\[aq] \[rs]
632 \[aq]30.75+z(theta(s),phi(t))\[aq] \[rs]
633 8 29 -f basin.cal -s
634 \f[]
635 .fi
636 .LP
637 The \f[B]-f\f[R] option loads in our file, which is then used to
638 evaluate expressions such as \f[C]15.5+x(theta(s),phi(t))\f[R] for
639 specific values of \f[C]s\f[R] and \f[C]t\f[R].
640 These variables range from 0 to 1 over the surface patch in increments
641 of @1 / 8@ and @1 / 29@, respectively.
642 (See the \f[B]gensurf\f[R] manual page for details.)
643 The entire expression for each evaluation could have been written in the
644 command line, but it is much more convenient to create a function file.
645 .SH 3
646 Language Features
647 .pdfhref O 3 "Language Features"
648 .pdfhref M "language-features"
649 .LP
650 Subtle features of the functional language provide much greater power
651 than first meets the eye.
652 One of these is the ability to define recursive functions.
653 The following example defines the factorial function (\f[I]n!\f[R]):
654 .IP
655 .nf
656 \f[C]
657 fact(n) : if(n-1.5, n*fact(n-1), 1);
658 \f[]
659 .fi
660 .LP
661 This uses the library function \f[C]if(cond,e1,e0)\f[R], which returns
662 \f[C]e1\f[R] if cond is greater than zero, and \f[C]e0\f[R] otherwise.
663 Since only one of these expressions is evaluated, \f[C]fact(n)\f[R] will
664 call itself until \f[C]n\f[R] is less than 2, when the \f[C]if\f[R]
665 expression returns 1\**.
666 .FS
667 Note that we compare \f[C]n\f[R] to 1.5, so as to avoid any round-off
668 problems caused by floating point math.
669 Caution is advised because all expressions are evaluated as
670 double-precision real, and comparisons to zero are unreliable.
671 .FE
672 The colon (`:') is used in place of the usual equals assignment (`=')
673 because we want this function to have the constant attribute, which
674 means any later appearance in an expression of \f[C]fact(ce)\f[R] where
675 ce is also a constant expression will be replaced by its value.
676 This can be an important savings in cases where an expression or
677 subexpression is expensive to evaluate, and only needs to be computed
678 once.
679 All of the standard library functions have the constant attribute.
680 (See the following section for a complete list.)
681 .PP
682 Another handy language feature is the ability to pass function names as
683 arguments.
684 A simple example of this is the following function, which computes the
685 numerical derivative of a function given as its first argument:
686 .IP
687 .nf
688 \f[C]
689 FTINY : 1e-7;
690 d1(f,x) = (f(x+FTINY)-f(x-FTINY))/FTINY/2;
691 \f[]
692 .fi
693 .LP
694 Evaluating \f[C]d1(sin,1.1)\f[R] using this formula yields 0.4536, which
695 is fairly close to the true derivative, which is \f[C]cos(1.1)\f[R].
696 .PP
697 A third language feature, which is normally transparent to the user, is
698 the notion of \f[I]contexts\f[R].
699 Identifiers may be composed of parts, starting with a name and
700 continuing with one or more context names.
701 Each name is delimited by a back-quote (`\[ga]').
702 Names themselves begin with a letter and continue with any sequence of
703 letters, digits, underscores and decimal points.
704 The following are examples of valid identifiers:
705 .IP
706 .nf
707 \f[C]
708 v1, V.W, x_rand\[ga]local, \[ga]A_, Qa_5\[ga]
709 \f[]
710 .fi
711 .LP
712 If a context mark appears at the beginning of the identifier, then its
713 reference must be local.
714 If it appears at the end, then its reference must be global.
715 A local reference must be resolved in the local context, i.e., no
716 contexts above this one will be searched.
717 A global reference must correspond to the original context, ignoring any
718 local redefinitions.
719 .PP
720 The reason that contexts are normally transparent is that they are
721 controlled by the calling program \[em] there are no explicit language
722 features for establishing contexts.
723 A new context is established automatically for each function file loaded
724 by the rendering programs.
725 That way, it is safe to reuse variable names that have been used in
726 other files, and even in the main initialization file,
727 \f[C]rayinit.cal\f[R].
728 .PP
729 Although not strictly necessary, there are two good reasons to define
730 variables and functions before referencing them in a function file.
731 One is related to contexts.
732 If a previous definition of a variable name is given in an enclosing
733 context (e.g., \f[C]rayinit.cal\f[R]), then that reference will be used
734 rather than a later one in the current context, unless the reference is
735 made explicitly local by starting the identifier with a context mark.
736 The second reason for defining before referencing is constant
737 expressions.
738 If a variable or function has the constant attribute (i.e., defined with
739 `:' instead of `='), then a later subexpression referencing it can be
740 replaced by its evaluated result during compilation.
741 If the constant is not defined until after it is referenced, it remains
742 as a reference, which takes time to evaluate each time.
743 .PP
744 Other features of the language are truly transparent, but knowledge of
745 them can help one to write more efficient function files:
746 .IP \[bu] 3
747 Once a variable has been evaluated, the result is cached and it is not
748 reevaluated unless the client program changes an internal counter
749 (\f[C]eclock\f[R]), which indicates that something has changed.
750 This means that using variables to hold frequently used values will not
751 only simplify the function file, it will save time during evaluation.
752 .IP \[bu] 3
753 An argument passed in a function call is not evaluated until the
754 function calls for it specifically, and the result is also cached to
755 avoid redundant calculation.
756 The conditional evaluation feature is actually a requirement for
757 recursive functions to work, but caching is not.
758 Argument value caching means it is more efficient to pass an
759 expensive-to-compute expression than to have the function compute it
760 internally if it appears more than once in the function definition.
761 This is especially true for recursive functions with deep call trees.
762 .SH 3
763 Standard Definitions (Library)
764 .pdfhref O 3 "Standard Definitions \(Library\)"
765 .pdfhref M "standard-definitions-library"
766 .LP
767 The following are always defined:
768 .IP "\f[B]\f[CB]if(a, b, c)\f[B]\f[R]" 3
769 Conditional expression.
770 If a is positive, return b, else return c.
771 .RS 3
772 .RE
773 .IP "\f[B]\f[CB]select(N, a1, a2, ..)\f[B]\f[R]" 3
774 Return Nth argument.
775 If N is 0, then return the count of arguments excluding the first.
776 This provides basic array functionality.
777 .RS 3
778 .RE
779 .IP "\f[B]\f[CB]sqrt(x)\f[B]\f[R]" 3
780 Return square root of \f[C]x\f[R], where \f[C]x >= 0\f[R].
781 .RS 3
782 .RE
783 .IP "\f[B]\f[CB]sin(x), cos(x), tan(x), asin(x), acos(x), atan(x), atan2(y,x)\f[B]\f[R]" 3
784 Standard trigonometry functions.
785 .RS 3
786 .RE
787 .IP "\f[B]\f[CB]floor(x), ceil(x)\f[B]\f[R]" 3
788 Greatest lower bound and least upper bound (integer).
789 .RS 3
790 .RE
791 .IP "\f[B]\f[CB]exp(x), log(x), log10(x)\f[B]\f[R]" 3
792 Exponent and logarithm functions.
793 .RS 3
794 .RE
795 .IP "\f[B]\f[CB]rand(x)\f[B]\f[R]" 3
796 Return pseudo-random number in the range [0,1) for any argument x.
797 The same return value is guaranteed for the same argument.
798 .RS 3
799 .RE
800 .LP
801 The following are sometimes defined, depending on the program:
802 .IP "\f[B]\f[CB]PI\f[B]\f[R]" 3
803 The ratio of a circle\[cq]s circumference to its diameter.
804 .RS 3
805 .RE
806 .IP "\f[B]\f[CB]erf(z), erfc(z)\f[B]\f[R]" 3
807 Error function and complimentary error function.
808 .RS 3
809 .RE
810 .IP "\f[B]\f[CB]j0(x), j1(x), jn(n,x), y0(x), y1(x), yn(n,x)\f[B]\f[R]" 3
811 Bessel functions.
812 .RS 3
813 .RE
814 .IP "\f[B]\f[CB]hermite(p0,p1,r0,r1,t)\f[B]\f[R]" 3
815 One-dimensional Hermite polynomial.
816 .RS 3
817 .RE
818 .LP
819 The rendering programs also define the following noise functions:
820 .IP "\f[B]\f[CB]noise3(x,y,z), noise3x(x,y,z), noise3y(x,y,z), noise3z(x,y,z)\f[B]\f[R]" 3
821 Perlin noise function and its gradient [Perlin85][Arvo91,p.396].
822 .RS 3
823 .RE
824 .IP "\f[B]\f[CB]fnoise3(x,y,z)\f[B]\f[R]" 3
825 Fractal noise function, ranging from -1 to 1.
826 .RS 3
827 .RE
828 .LP
829 Interaction with the renderer is achieved via special purpose variables
830 and functions whose values correspond to the current ray intersection
831 and the calling primitive.
832 Unlike the above functions, none of these have the constant attribute
833 since their values change from one ray to the next:
834 .IP "\f[B]\f[CB]Dx, Dy, Dz\f[B]\f[R]" 3
835 ray direction
836 .RS 3
837 .RE
838 .IP "\f[B]\f[CB]Nx, Ny, Nz\f[B]\f[R]" 3
839 surface normal
840 .RS 3
841 .RE
842 .IP "\f[B]\f[CB]Px, Py, Pz\f[B]\f[R]" 3
843 intersection point
844 .RS 3
845 .RE
846 .IP "\f[B]\f[CB]T\f[B]\f[R]" 3
847 distance from start
848 .RS 3
849 .RE
850 .IP "\f[B]\f[CB]Ts\f[B]\f[R]" 3
851 single ray (shadow) distance
852 .RS 3
853 .RE
854 .IP "\f[B]\f[CB]Rdot\f[B]\f[R]" 3
855 ray dot product
856 .RS 3
857 .RE
858 .IP "\f[B]\f[CB]S\f[B]\f[R]" 3
859 world scale
860 .RS 3
861 .RE
862 .IP "\f[B]\f[CB]Tx, Ty, Tz\f[B]\f[R]" 3
863 world origin
864 .RS 3
865 .RE
866 .IP "\f[B]\f[CB]Ix, Iy, Iz\f[B]\f[R]" 3
867 world i unit vector
868 .RS 3
869 .RE
870 .IP "\f[B]\f[CB]Jx, Jy, Jz\f[B]\f[R]" 3
871 world j unit vector
872 .RS 3
873 .RE
874 .IP "\f[B]\f[CB]Kx, Ky, Kz\f[B]\f[R]" 3
875 world k unit vector
876 .RS 3
877 .RE
878 .IP "\f[B]\f[CB]arg(n)\f[B]\f[R]" 3
879 real arguments, arg(0) is count
880 .RS 3
881 .RE
882 .LP
883 For BRDF primitives, the following variables are also available:
884 .IP "\f[B]\f[CB]NxP, NyP, NzP\f[B]\f[R]" 3
885 perturbed surface normal
886 .RS 3
887 .RE
888 .IP "\f[B]\f[CB]RdotP\f[B]\f[R]" 3
889 perturbed ray dot product
890 .RS 3
891 .RE
892 .IP "\f[B]\f[CB]CrP, CgP, CbP\f[B]\f[R]" 3
893 perturbed material color
894 .RS 3
895 .RE
896 .LP
897 For prism1 and prism2 primitives, the following are available:
898 .IP "\f[B]\f[CB]DxA, DyA, DzA\f[B]\f[R]" 3
899 direction to target light source
900 .RS 3
901 .RE
902 .LP
903 Other functions, variables and constants are defined as well in the file
904 \f[C]src/rt/rayinit.cal\f[R], which gets installed in the standard
905 \f[I]Radiance\f[R] library directory and can be modified or appended as
906 desired\**.
907 .FS
908 It is usually a good idea to store any such customized files in a
909 personal library location and set the \f[C]RAYPATH\f[R] environment
910 variable to search there first.
911 This way, it does not affect other users or get overwritten during the
912 next system installation.
913 .FE
914 .SH 3
915 \f[BI]Radiance\f[B] Programs
916 .pdfhref O 3 "Radiance Programs"
917 .pdfhref M "radiance-programs-1"
918 .LP
919 Table 2 shows \f[I]Radiance\f[R] programs that read and write function
920 files.
921 .PP
922 .na
923 .TS
924 delim(@@) tab( );
925 l l l l.
926 T{
927 Program
928 T} T{
929 Read
930 T} T{
931 Write
932 T} T{
933 Function
934 T}
935 _
936 T{
937 \f[B]calc\f[R]
938 T} T{
939 X
940 T} T{
941 X
942 T} T{
943 Interactive calculator
944 T}
945 T{
946 \f[B]genrev\f[R]
947 T} T{
948 X
949 T} T{
950 T} T{
951 Generate surface of revolution
952 T}
953 T{
954 \f[B]gensurf\f[R]
955 T} T{
956 X
957 T} T{
958 T} T{
959 Generate arbitrary surface patch
960 T}
961 T{
962 \f[B]genworm\f[R]
963 T} T{
964 X
965 T} T{
966 T} T{
967 Generate varying diameter curved path
968 T}
969 T{
970 \f[B]macbethcal\f[R]
971 T} T{
972 T} T{
973 X
974 T} T{
975 Compute image color & contrast correction
976 T}
977 T{
978 \f[B]pcomb\f[R]
979 T} T{
980 X
981 T} T{
982 T} T{
983 Perform arbitrary math on picture(s)
984 T}
985 T{
986 \f[B]rcalc\f[R]
987 T} T{
988 X
989 T} T{
990 T} T{
991 Record stream calculator
992 T}
993 T{
994 \f[B]rpict\f[R]
995 T} T{
996 X
997 T} T{
998 T} T{
999 Batch rendering program
1000 T}
1001 T{
1002 \f[B]rtrace\f[R]
1003 T} T{
1004 X
1005 T} T{
1006 T} T{
1007 Customizable ray-tracer
1008 T}
1009 T{
1010 \f[B]rview\f[R]
1011 T} T{
1012 X
1013 T} T{
1014 T} T{
1015 Interactive renderer
1016 T}
1017 T{
1018 \f[B]tabfunc\f[R]
1019 T} T{
1020 T} T{
1021 X
1022 T} T{
1023 Create function file from tabulated data
1024 T}
1025 .TE
1026 .ad
1027 .LP
1028 \f[B]Table 2.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
1029 read and write function files.
1030 .PP
1031 In addition, the program \f[B]ev\f[R] evaluates expressions given as
1032 command line arguments, though it does not handle function files or
1033 definitions.
1034 There are also a number of 2-d plotting routines that use a slightly
1035 modified statement syntax, called \f[B]bgraph\f[R], \f[B]dgraph\f[R],
1036 \f[B]gcomp\f[R], and \f[B]igraph\f[R].
1037 Additional utility programs are useful in combination with rcalc for
1038 data analysis and scene generation.
1039 The program \f[B]cnt\f[R] generates simple records to drive
1040 \f[B]rcalc\f[R], and the \f[B]total\f[R] program is handy for adding up
1041 results.
1042 The \f[B]histo\f[R] program computes histograms needed for certain types
1043 of statistical analysis.
1044 The \f[B]lam\f[R] program concatenates columns from multiple input
1045 files, and \f[B]neat\f[R] neatens up columns for better display.
1046 .SH 3
1047 \f[BI]Radiance\f[B] C Library
1048 .pdfhref O 3 "Radiance C Library"
1049 .pdfhref M "radiance-c-library-1"
1050 .LP
1051 The standard routines for loading and evaluating function files are
1052 divided into three modules, \f[C]src/common/calexpr.c\f[R] for
1053 expression parsing and evaluation, \f[C]src/common/caldefn.c\f[R] for
1054 variable and function storage and lookup, and
1055 \f[C]src/common/calfunc.c\f[R] for library function storage and function
1056 evaluation.
1057 There is a fourth module for writing out expressions called
1058 \f[C]src/common/calprnt.c\f[R], which we will not discuss.
1059 They all use the header file \f[C]src/common/calcomp.h\f[R], which
1060 defines common data structures and evaluation macros.
1061 Of these, the three most often used declarations for external routines
1062 are:
1063 .IP "\f[B]\f[CB]typedef struct epnode EPNODE;\f[B]\f[R]" 3
1064 Expression parse tree node.
1065 Some routines return pointers to this structure type, and the main
1066 evaluation macro, \f[C]evalue(ep)\f[R], takes an argument of this type.
1067 .RS 3
1068 .RE
1069 .IP "\f[B]\f[CB](double) evalue(ep);\f[B]\f[R]" 3
1070 Evaluate an expression parse tree.
1071 Uses node type table to access appropriate function depending on root
1072 node type.
1073 (E.g., an addition node calls \f[C]eadd(ep)\f[R].)
1074 .RS 3
1075 .RE
1076 .IP "\f[B]\f[CB]extern unsigned long eclock;\f[B]\f[R]" 3
1077 This is a counter used to determine when variable values need updating.
1078 The initial value is 0, which tells the routines always to reevaluate
1079 variables.
1080 Once incremented to 1, variable evaluations are cached and not
1081 recomputed until \f[C]eclock\f[R] is incremented again.
1082 Usually, client programs increment \f[C]eclock\f[R] each time
1083 definitions or internal states affecting returned values change.
1084 This assures the quickest evaluation of correct results.
1085 .RS 3
1086 .RE
1087 .LP
1088 The usual approach to handling definitions is to compile them into the
1089 central lookup table; variable and function references are later
1090 evaluated by traversing the stored parse trees.
1091 Syntax errors and undefined symbol errors during evaluation result in
1092 calls to the user-definable routine \f[C]eputs(s)\f[R] to report the
1093 error and \f[C]quit(status)\f[R] to exit the program.
1094 Domain and range errors during evaluation set \f[C]errno\f[R], then call
1095 the user-definable routine \f[C]wputs(s)\f[R] to report the error and
1096 return zero as the expression result.
1097 Following are standard routines provided for parsing from a file and
1098 parsing from a string:
1099 .IP "\f[B]\f[CB]EPNODE *eparse(char *expr);\f[B]\f[R]" 3
1100 Compile the string expr into a parse tree for later evaluation with
1101 evalue(ep).
1102 .RS 3
1103 .RE
1104 .IP "\f[B]\f[CB]epfree(EPNODE *ep);\f[B]\f[R]" 3
1105 Free memory associated with ep, including any variables referenced if
1106 they are no longer defined.
1107 .RS 3
1108 .RE
1109 .IP "\f[B]\f[CB]double eval(char *expr);\f[B]\f[R]" 3
1110 Immediately parse, evaluate and free the given string expression.
1111 .RS 3
1112 .RE
1113 .IP "\f[B]\f[CB]fcompile(char *fname);\f[B]\f[R]" 3
1114 Compile definitions from the given file, or standard input if fname is
1115 NULL.
1116 .RS 3
1117 .RE
1118 .IP "\f[B]\f[CB]scompile(char *str, char *fn, int ln);\f[B]\f[R]" 3
1119 Compile definitions from the string str, taken from file fn at line
1120 number ln.
1121 If no file is associated, fn can be NULL, and ln can be 0.
1122 .RS 3
1123 .RE
1124 .LP
1125 The following routines allow one to control the current context for
1126 definition lookup and storage:
1127 .IP "\f[B]\f[CB]char *setcontext(char *ctx);\f[B]\f[R]" 3
1128 Set the current context to ctx.
1129 If ctx is NULL, then simply return the current context.
1130 An empty string sets the global context.
1131 .RS 3
1132 .RE
1133 .IP "\f[B]\f[CB]char *pushcontext(char *name);\f[B]\f[R]" 3
1134 Push another context onto the stack.
1135 Return the new (full) context.
1136 .RS 3
1137 .RE
1138 .IP "\f[B]\f[CB]char *popcontext();\f[B]\f[R]" 3
1139 Pop the top context name off the stack.
1140 Return the new (full) context.
1141 .RS 3
1142 .RE
1143 .LP
1144 The following functions permit the explicit setting of variable and
1145 function values:
1146 .IP "\f[B]\f[CB]varset(char *vname, int assign, double val);\f[B]\f[R]" 3
1147 Set the specified variable to the given value, using a constant
1148 assignment if assign is `:' or a regular one if it is `='.
1149 This is always faster than compiling a string to do the same thing.
1150 .RS 3
1151 .RE
1152 .IP "\f[B]\f[CB]funset(char *fname, int nargs, int assign, double (*fptr)(char *fn));\f[B]\f[R]" 3
1153 Assign the specified library function, which takes a minimum of nargs
1154 arguments.
1155 The function will have the constant attribute if assign is `:', or not
1156 if it is `='.
1157 The only argument to the referenced function pointer is the function
1158 name, which will equal fname.
1159 (This string must therefore be declared static.)
1160 This offers a convenient method to identify calls to an identical
1161 function assigned multiple tasks.
1162 Argument values are obtained with calls back to the argument(n) library
1163 function.
1164 .RS 3
1165 .RE
1166 .LP
1167 The following functions are provided for evaluating a function or
1168 variable in the current definition set:
1169 .IP "\f[B]\f[CB]double varvalue(char *vname);\f[B]\f[R]" 3
1170 Evaluate the given variable and return the result.
1171 Since a hash lookup is necessary to resolve the reference, this is
1172 slightly less efficient than evaluating a compiled expression via
1173 evalue(ep), which uses soft links generated and maintained during
1174 compilation.
1175 .RS 3
1176 .RE
1177 .IP "\f[B]\f[CB]double funvalue(char *fn, int n, double a);\f[B]\f[R]" 3
1178 Evaluate the function fn, passing n real arguments in the array a.
1179 There is currently no mechanism for passing functions or function name
1180 arguments from client programs.
1181 .RS 3
1182 .RE
1183 .LP
1184 These routines can be used to check the existence of a specific function
1185 or variable:
1186 .IP "\f[B]\f[CB]int vardefined(char *vname);\f[B]\f[R]" 3
1187 Return non-zero if the named variable is defined.
1188 (If the symbol is defined as a function, zero is returned.)
1189 .RS 3
1190 .RE
1191 .IP "\f[B]\f[CB]int fundefined(char *fname);\f[B]\f[R]" 3
1192 Return the number of required arguments for the named function if it is
1193 defined, or zero if it is not defined.
1194 (If the symbol is defined as a variable, zero is returned.)
1195 .RS 3
1196 .RE
1197 .LP
1198 These routines allow definitions to be cleared:
1199 .IP "\f[B]\f[CB]dclear(char *dname);\f[B]\f[R]" 3
1200 Clear the given variable or function, unless it is a constant
1201 expression.
1202 .RS 3
1203 .RE
1204 .IP "\f[B]\f[CB]dremove(char *dname);\f[B]\f[R]" 3
1205 Clear the given variable or function, even if it is a constant
1206 expression.
1207 Library definitions cannot be removed, except by calling funset with a
1208 \f[C]NULL\f[R] pointer for the function argument.
1209 .RS 3
1210 .RE
1211 .IP "\f[B]\f[CB]dcleanup(int level);\f[B]\f[R]" 3
1212 Clear definitions.
1213 If level is 0, then just clear variable definitions.
1214 If level is 2, then clear constants as well.
1215 If the current context is local, then only local definitions will be
1216 affected.
1217 If global, all definitions in all contexts will be affected.
1218 .RS 3
1219 .RE
1220 .LP
1221 These routines may be used during library function evaluation:
1222 .IP "\f[B]\f[CB]int nargum();\f[B]\f[R]" 3
1223 Determine the number of arguments available in the current function
1224 evaluation context.
1225 .RS 3
1226 .RE
1227 .IP "\f[B]\f[CB]double argument(int n);\f[B]\f[R]" 3
1228 Evaluate and return the nth argument.
1229 .RS 3
1230 .RE
1231 .IP "\f[B]\f[CB]char *argfun(n);\f[B]\f[R]" 3
1232 Get the name of the function passed as argument n.\ (Generates an error
1233 if the nth argument is not a function.)
1234 .RS 3
1235 .RE
1236 .LP
1237 Other, even more specialized routines are provided for controlling the
1238 parsing process, printing out expressions and sifting through stored
1239 definitions, but these are not accessed by most client programs.
1240 Worth noting are the various compile flags that affect which features of
1241 the expression language are included.
1242 The standard library sets the flags \f[C]-DVARIABLE\f[R],
1243 \f[C]-DFUNCTION\f[R], \f[C]-DRCONST\f[R], and \f[C]-DBIGLIB\f[R].
1244 Here is a list of compile flags and their meanings:
1245 .IP "\f[B]\f[CB]-DVARIABLE\f[B]\f[R]" 3
1246 Allow user-defined variables and (if \f[C]-DFUNCTION\f[R]) user- defined
1247 functions.
1248 .RS 3
1249 .RE
1250 .IP "\f[B]\f[CB]-DFUNCTION\f[B]\f[R]" 3
1251 Compile in library functions and (if \f[C]-DVARIABLE\f[R]) allow
1252 user-supplied function definitions.
1253 .RS 3
1254 .RE
1255 .IP "\f[B]\f[CB]-DBIGLIB\f[B]\f[R]" 3
1256 Include larger library of standard functions, i.e., standard C math
1257 library.
1258 Otherwise, only minimal library is compiled in, and other functions may
1259 be added using \f[C]funset\f[R].
1260 .RS 3
1261 .RE
1262 .IP "\f[B]\f[CB]-DRCONST\f[B]\f[R]" 3
1263 Reduce constant subexpressions during compilation.
1264 This can result in substantial savings during later evaluation, but the
1265 original user-supplied expressions are lost.
1266 .RS 3
1267 .RE
1268 .IP "\f[B]\f[CB]-DREDEFW\f[B]\f[R]" 3
1269 Issue a warning via \f[C]wputs(s)\f[R] if a new definition hides a
1270 constant definition or library function, or replaces an existing,
1271 distinct definition for the same symbol.
1272 (The \f[C]varset\f[R] routine never generates warnings, however.)
1273 .RS 3
1274 .RE
1275 .IP "\f[B]\f[CB]-DINCHAN\f[B]\f[R]" 3
1276 Provide for \f[C]\[rs]$N\f[R] syntax for input channels, which result in
1277 callbacks to client-supplied chanvalue(n) routine on each evaluation.
1278 .RS 3
1279 .RE
1280 .IP "\f[B]\f[CB]-DOUTCHAN\f[B]\f[R]" 3
1281 Provide for \f[C]\[rs]$N\f[R] lvalue syntax for output channels, which
1282 are evaluated via the chanout(cs) library function, which calls
1283 \f[C](*cs)(n, value)\f[R]for each assigned channel definition.
1284 .RS 3
1285 .RE
1286 .SH 2
1287 Data File Format (.dat suffix)
1288 .pdfhref O 2 "Data File Format \(.dat suffix\)"
1289 .pdfhref M "data-file-format-.dat-suffix"
1290 .LP
1291 Although it is possible to store tabular data in a function file using
1292 the select library function, it is more convenient and efficient to
1293 devote a special file format to this purpose.
1294 \f[I]Radiance\f[R] data files store scalar values on an N-dimensional
1295 rectangular grid.
1296 Grid (independent) axes may be regularly or irregularly divided, as
1297 shown in Figure 1.
1298 This data is interpolated during rendering (using N-dimensional linear
1299 interpolation) to compute the desired values.
1300 .PSPIC "figure1.eps"
1301 .ce 1000
1302 Division of axes in .dat file
1303 .ce 0
1304 .PP
1305 \f[B]Figure 1.\f[R] A 2-dimensional grid with one regularly divided axis
1306 and one irregularly divided axis.
1307 Each intersection corresponds to a data value that appears in the file.
1308 .PP
1309 Data files are broken into two sections, the header and the body.
1310 The header specifies the grid, and the body contains the data values in
1311 a standard order.
1312 The first value in the file is a positive integer indicating the number
1313 of dimensions.
1314 Next comes that number of axis specifications, in one of two formats.
1315 For a regularly divided axis, the starting and ending value is given,
1316 followed by the number of divisions.
1317 For an irregularly divided axis, two zeros are followed by the number of
1318 divisions then that number of division values.
1319 The two zeros are merely there to indicate an irregular spacing is being
1320 specified.
1321 Once all the axes have been given, the header is done and the body of
1322 the file begins, which consists of one data value after another.
1323 The ordering of the data is such that the last axis given is the one
1324 being traversed most rapidly, similar to a static array assignment in C.
1325 .PP
1326 A file corresponding to the topology shown in Figure 1 is:
1327 .IP
1328 .nf
1329 \f[C]
1330 ######### Header ########
1331 2 # Two-dimensional data array
1332 0.5 0.1 5 # The regularly spaced axis
1333 0 0 5 3 5 10 16 20 # The irregularly spaced axis
1334 ########## Body #########
1335 # The data values, starting with the
1336 # upper left, moving right then down:
1337 19.089 7.001 14.647 6.3671 8.0003
1338 3.8388 11.873 19.294 16.605 2.7435
1339 16.699 6.387 2.8123 16.195 17.615
1340 14.36 14.413 16.184 15.635 4.5403
1341 3.6740 14.550 10.332 15.932 1.2678
1342 \f[]
1343 .fi
1344 .LP
1345 Comments begin with a pound sign (`#') and continue to the end of the
1346 line.
1347 White space is ignored except as a data separator, thus the position of
1348 header and data values on each line is irrelevant except to improve
1349 readability.
1350 .SH 3
1351 \f[BI]Radiance\f[B] Programs
1352 .pdfhref O 3 "Radiance Programs"
1353 .pdfhref M "radiance-programs-2"
1354 .LP
1355 Table 3 shows \f[I]Radiance\f[R] programs that read and write data
1356 files.
1357 .PP
1358 .na
1359 .TS
1360 delim(@@) tab( );
1361 l l l l.
1362 T{
1363 Program
1364 T} T{
1365 Read
1366 T} T{
1367 Write
1368 T} T{
1369 Function
1370 T}
1371 _
1372 T{
1373 \f[B]ies2rad\f[R]
1374 T} T{
1375 T} T{
1376 X
1377 T} T{
1378 Convert IES luminaire file to \f[I]Radiance\f[R]
1379 T}
1380 T{
1381 \f[B]mgf2rad\f[R]
1382 T} T{
1383 T} T{
1384 X
1385 T} T{
1386 Convert MGF file to \f[I]Radiance\f[R]
1387 T}
1388 T{
1389 \f[B]rpict\f[R]
1390 T} T{
1391 X
1392 T} T{
1393 T} T{
1394 Batch rendering program
1395 T}
1396 T{
1397 \f[B]rtrace\f[R]
1398 T} T{
1399 X
1400 T} T{
1401 T} T{
1402 Customizable ray-tracer
1403 T}
1404 T{
1405 \f[B]rview\f[R]
1406 T} T{
1407 X
1408 T} T{
1409 T} T{
1410 Interactive renderer
1411 T}
1412 .TE
1413 .ad
1414 .LP
1415 \f[B]Table 3.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
1416 read and write data files.
1417 .SH 3
1418 \f[BI]Radiance\f[B] C Library
1419 .pdfhref O 3 "Radiance C Library"
1420 .pdfhref M "radiance-c-library-2"
1421 .LP
1422 The header file \f[C]src/rt/data.h\f[R] gives the standard data
1423 structures used by the routines in \f[C]src/rt/data.c\f[R] for reading
1424 and interpolating data files.
1425 The main data type is \f[C]DATARRAY\f[R], which is a structure
1426 containing the grid specification and a pointer to the data array, which
1427 is of the type \f[C]DATATYPE\f[R] (normally \f[B]float\f[R] to save
1428 space).
1429 .PP
1430 The main routine for reading data files is \f[C]getdata(dname)\f[R],
1431 which searches the standard \f[I]Radiance\f[R] library locations set by
1432 the \f[C]RAYPATH\f[R] environment variable.
1433 The return value is a pointer to the loaded \f[C]DATARRAY\f[R], which
1434 may have been loaded by a previous call.
1435 (The routine keeps a hash table of loaded files to minimize time and
1436 memory requirements.)
1437 The \f[C]freedata(dname)\f[R] routine frees memory associated with the
1438 named data file, or all data arrays if \f[C]dname\f[R] is
1439 \f[C]NULL\f[R].
1440 .PP
1441 The routine that interpolates data values is \f[C]datavalue(dp,pt)\f[R],
1442 which takes a \f[C]DATARRAY\f[R] pointer and an array of
1443 \f[B]double\f[R]s of the appropriate length (the number of dimensions in
1444 \f[C]dp\f[R]).
1445 The \f[B]double\f[R] returned is the interpolated value at that point in
1446 the scalar field.
1447 If the requested point lies outside the data\[cq]s grid, it is
1448 extrapolated from the perimeter values up to a distance of one division
1449 in each dimension, and falls off harmonically to zero outside of that.
1450 This was selected as the most robust compromise, but to be safe it is
1451 generally best to avoid giving out-of-domain points to
1452 \f[C]datavalue\f[R].
1453 .SH 2
1454 Font File Format (.fnt suffix)
1455 .pdfhref O 2 "Font File Format \(.fnt suffix\)"
1456 .pdfhref M "font-file-format-.fnt-suffix"
1457 .LP
1458 Font files are used for text patterns and mixtures, and by the
1459 \f[B]psign\f[R] program to generate simple text labels.
1460 Each character glyph is set up on a simple rectangular coordinate system
1461 running from [0,255] in x and y, and the glyph itself is a polygon.
1462 Figure 2 shows an example of the letter \[lq]A\[rq].
1463 .PSPIC "figure2.eps"
1464 .ce 1000
1465 Drawing of an A, based on coordinates
1466 .ce 0
1467 .PP
1468 \f[B]Figure 2.\f[R] A glyph for an \[lq]A\[rq] character in standard
1469 font coordinates.
1470 Note that the hole is made via a seam, just as with \f[I]Radiance\f[R]
1471 scene polygons.
1472 The actual aspect and spacing of the character will be determined by the
1473 client program.
1474 .PP
1475 Each glyph begins with the decimal value of that character\[cq]s index,
1476 which is 65 for \[lq]A\[rq] according to the ASCII standard.
1477 This is followed by the number of vertices, then the vertices themselves
1478 in @left ( x sub 1 , y sub 1 right ) , left ( x sub 2 , y sub 2 right )@
1479 order.
1480 White space again serves as a separator, and comments may begin with a
1481 pound sign (`#') and continue to the end of line.
1482 Here is the glyph entry for the letter \[lq]A\[rq] corresponding to
1483 Figure 2:
1484 .IP
1485 .nf
1486 \f[C]
1487 65 15 # Helvetica \[dq]A\[dq]
1488 155 222 242 48 185 48 168 86
1489 83 86 65 48 12 48 101 222
1490 155 222 128 179 126 179 97 116
1491 155 116 128 179 155 222
1492 \f[]
1493 .fi
1494 .LP
1495 If the number of vertices given is zero, then the character is a space.
1496 This is not the same as no entry, which means there is no valid glyph
1497 for that character.
1498 Glyphs may appear in any order, with indices ranging from 0 to 255.
1499 The maximum number of vertices for a single glyph is 32767.
1500 .PP
1501 Two standard font files are provided, \f[C]helvet.fnt\f[R] and
1502 \f[C]hexbit4x1.fnt\f[R].
1503 The former is a Helvetica font from the public domain Hershey font set.
1504 The second is a simple bit pattern font for hexadecimal encodings of
1505 bitmaps.
1506 .SH 3
1507 \f[BI]Radiance\f[B] Programs
1508 .pdfhref O 3 "Radiance Programs"
1509 .pdfhref M "radiance-programs-3"
1510 .LP
1511 Table 4 shows \f[I]Radiance\f[R] programs that read and write font
1512 files.
1513 .PP
1514 .na
1515 .TS
1516 delim(@@) tab( );
1517 l l l l.
1518 T{
1519 Program
1520 T} T{
1521 Read
1522 T} T{
1523 Write
1524 T} T{
1525 Function
1526 T}
1527 _
1528 T{
1529 \f[B]pcompos\f[R]
1530 T} T{
1531 X
1532 T} T{
1533 T} T{
1534 Compose \f[I]Radiance\f[R] pictures
1535 T}
1536 T{
1537 \f[B]psign\f[R]
1538 T} T{
1539 X
1540 T} T{
1541 T} T{
1542 Generate \f[I]Radiance\f[R] picture label
1543 T}
1544 T{
1545 \f[B]rpict\f[R]
1546 T} T{
1547 X
1548 T} T{
1549 T} T{
1550 Batch rendering program
1551 T}
1552 T{
1553 \f[B]rtrace\f[R]
1554 T} T{
1555 X
1556 T} T{
1557 T} T{
1558 Customizable ray-tracer
1559 T}
1560 T{
1561 \f[B]rview\f[R]
1562 T} T{
1563 X
1564 T} T{
1565 T} T{
1566 Interactive renderer
1567 T}
1568 .TE
1569 .ad
1570 .LP
1571 \f[B]Table 4.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
1572 read and write font files.
1573 .SH 3
1574 \f[BI]Radiance\f[B] C Library
1575 .pdfhref O 3 "Radiance C Library"
1576 .pdfhref M "radiance-c-library-3"
1577 .LP
1578 Similar to data files, font files are usually read and stored in a
1579 lookup table.
1580 The data structures for fonts are in \f[C]src/common/font.h\f[R], and
1581 the routines for reading and spacing them are in
1582 \f[C]src/common/font.c\f[R].
1583 The main structure type is \f[C]FONT\f[R].
1584 The routine \f[C]getfont(fname)\f[R] loads a font file from the
1585 \f[I]Radiance\f[R] library (set by the \f[C]RAYPATH\f[R] environment
1586 variable), and returns a pointer to the resulting \f[C]FONT\f[R]
1587 structure.
1588 If the file has been previously loaded, a pointer to the stored
1589 structure is returned.
1590 The \f[C]freefont(fname)\f[R] routine frees memory associated with the
1591 named font file and deletes it from the table, or frees all font data if
1592 \f[C]fname\f[R] is \f[C]NULL\f[R].
1593 .PP
1594 Three different routines are available for text spacing.
1595 The \f[C]uniftext(sp,tp,f\f[R]) function takes the nul-terminated string
1596 \f[C]tp\f[R] and computes uniform per-character spacing for the font
1597 \f[C]f\f[R], returned in the short integer array \f[C]sp\f[R].
1598 (This is a fairly simple process, and all spacing values will be 255
1599 unless a character has no corresponding glyph.)
1600 The \f[C]squeeztext(sp,tp,f,cis)\f[R] performs a similar function, but
1601 puts only \f[C]ci\f[R]s units between adjacent characters, based on the
1602 actual width of each font glyph.
1603 The most sophisticated spacing function is
1604 \f[C]proptext(sp,tp,f,cis,nsi)\f[R], which produces a total line length
1605 equal to what it would be with uniform spacing, while maintaining equal
1606 inter-character spacing throughout (i.e., proportional spacing).
1607 The \f[C]nsi\f[R] argument is the number of spaces (zero-vertex glyphs)
1608 considered as an indent.
1609 That is, if this many or more adjacent spaces occur in \f[C]tp\f[R], the
1610 indented text following will appear at the same point as it would have
1611 had the spacing been uniform.
1612 This maintains columns in tabulated text despite the proportional
1613 spacing.
1614 Tabs are not understood or interpreted by any of these routines, and
1615 must be expanded to the appropriate number of spaces via
1616 \f[B]expand\f[R].
1617 .SH 3
1618 Octree Format (.oct suffix)
1619 .pdfhref O 3 "Octree Format \(.oct suffix\)"
1620 .pdfhref M "octree-format-.oct-suffix"
1621 .LP
1622 In \f[I]Radiance\f[R], octrees are used to accelerate ray intersection
1623 calculations as described by Glassner [Glassner84].
1624 This data structure is computed by the \f[B]oconv\f[R] program, which
1625 produces a binary file as its output.
1626 An octree file contains a list of \f[I]Radiance\f[R] scene description
1627 files (which may be empty), some information to guarantee portability
1628 between systems and different versions of the code, followed by the
1629 octree data itself.
1630 If the octree file is \[lq]frozen,\[rq] then it will also contain the
1631 scene data, compiled into a binary format for quick loading.
1632 This is most convenient for octrees that are used in \f[I]instance\f[R]
1633 primitives, which may be moved to a different (library) location from
1634 the originating scene files.
1635 .PP
1636 An octree recursively subdivides 3-dimensional space into 8 subtrees,
1637 hence its name.
1638 Each \[lq]leaf\[rq] node contains between zero and \f[C]MAXSET\f[R]
1639 surface primitives, indicating that section of space contains part or
1640 all of those surfaces.
1641 (Surface primitives may appear more than once in the octree.)
1642 The goal of \f[B]oconv\f[R] is to build an octree that contains no more
1643 than N surfaces in each leaf node, where N is set by the \f[B]-n\f[R]
1644 option (5 by default).
1645 It may allow more surfaces in places where the octree has reached its
1646 maximum resolution (depth), set by the \f[B]-r\f[R] option (1024 \[em]
1647 depth 10 by default).
1648 Figure 3 shows a quadtree dividing 2-dimensional space, analogous to our
1649 3-dimensional octree.
1650 .PSPIC "figure3.eps"
1651 .ce 1000
1652 A quadtree dividing two-dimensional space
1653 .ce 0
1654 .PP
1655 \f[B]Figure 3.\f[R] An example quadtree divided so that no leaf node
1656 contains more than 2 objects.
1657 A three-dimensional octree works the same way.
1658 Each leaf node is either empty, or contains a list of intersecting
1659 surfaces.
1660 .SH 3
1661 Basic File Structure
1662 .pdfhref O 3 "Basic File Structure"
1663 .pdfhref M "basic-file-structure-1"
1664 .LP
1665 An octree file is divided into five sections: the information header,
1666 the scene boundaries, the scene file names, the octree data structure,
1667 and the compiled scene data.
1668 If the octree is frozen, then the compiled scene data is included and
1669 the scene file names are not.
1670 Otherwise, the scene data is left off.
1671 .SH 4
1672 Information Header
1673 .pdfhref O 4 "Information Header"
1674 .pdfhref M "information-header"
1675 .LP
1676 As with other binary \f[I]Radiance\f[R] formats, the beginning of an
1677 octree file is the information header.
1678 The first line is \[lq]#?RADIANCE\[rq] to aid in identification by the
1679 UNIX \f[B]file\f[R] program.
1680 Following this is the \f[B]oconv\f[R] command (or commands) used to
1681 produce the octree, then a line indicating the format,
1682 \f[C]FORMAT=Radiance_octree\f[R].
1683 The end of the information header is always an empty line.
1684 Here is an example of an octree information header, as reported by
1685 \f[B]getinfo\f[R]:
1686 .IP
1687 .nf
1688 \f[C]
1689 #?RADIANCE
1690 oconv model.b90 desk misc
1691 oconv -f -i modelb.oct window blinds lights lamp
1692 FORMAT=Radiance_octree
1693 \f[]
1694 .fi
1695 .LP
1696 The actual content of this header is ignored when an octree is read
1697 except for the \f[C]FORMAT\f[R] line, which if it appears must match the
1698 one shown above.
1699 .SH 4
1700 Scene Boundaries
1701 .pdfhref O 4 "Scene Boundaries"
1702 .pdfhref M "scene-boundaries"
1703 .LP
1704 After the information header, there is a magic number indicating the
1705 format version and the size of object indices (in bytes per index).
1706 This is a two-byte quantity, which must be one of the following in the
1707 current release:
1708 .PP
1709 .na
1710 .nr LLold \n[LL]
1711 .TS
1712 delim(@@) tab( );
1713 lw(35.0n) lw(35.0n).
1714 T{
1715 .nr LL 35.0n
1716 285
1717 T} T{
1718 .nr LL 35.0n
1719 Two-byte object indices.
1720 T}
1721 T{
1722 .nr LL 35.0n
1723 287
1724 T} T{
1725 .nr LL 35.0n
1726 Four-byte object indices.
1727 T}
1728 T{
1729 .nr LL 35.0n
1730 291
1731 T} T{
1732 .nr LL 35.0n
1733 Eight-byte object indices.
1734 (Only supported on architectures with 64-bit \f[B]longs\f[R].)
1735 T}
1736 .TE
1737 .nr LL \n[LLold]
1738 .ad
1739 .LP
1740 Technically, the code will also support odd-sized integers, but they are
1741 not found on any existing machine architectures so we can forget about
1742 them.
1743 .PP
1744 Following the octree magic number, we have the enclosing cube for the
1745 scene, which defines the dimensions of the octree\[cq]s root node.
1746 The cube is aligned along the world coordinate axes, so may be defined
1747 by one corner (the 3-dimensional minimum) and the side length.
1748 For historical reasons, these four values are stored as ASCII-encoded
1749 real values in nul-terminated strings.
1750 (The octree boundaries may also be read using \f[B]getinfo\f[R] with the
1751 \f[B]-d\f[R] option.)
1752 .SH 4
1753 Scene File Names
1754 .pdfhref O 4 "Scene File Names"
1755 .pdfhref M "scene-file-names"
1756 .LP
1757 Following the octree dimensions, the names of the scene description
1758 files are given, each stored a nul-terminated string.
1759 The end of this file list is indicated by an empty string.
1760 If the octree is \[lq]frozen,\[rq] meaning it contains the compiled
1761 scene information as well, then no file names will be present (i.e., the
1762 first string will be empty).
1763 .SH 4
1764 Octree Data Structure
1765 .pdfhref O 4 "Octree Data Structure"
1766 .pdfhref M "octree-data-structure"
1767 .LP
1768 After the scene description files, an N-byte integer indicates the total
1769 number of primitives given to \f[B]oconv\f[R], where N is the size
1770 derived from the magic number as we described.
1771 This object count will be used to verify that the files have not changed
1772 significantly since the octree was written\**.
1773 .FS
1774 Small changes that do not affect geometry will not cause problems, but
1775 if the primitive count changes, so does the indexing of surfaces, and
1776 with that the octree data structure becomes invalid.
1777 A second check is made to insure that no non-surface primitives appear
1778 in any leaf nodes, and this at least guarantees that the renderer will
1779 not dump core from an outdated octree, even if the results are wrong.
1780 .FE
1781 .PP
1782 After the primitive count, the actual octree is stored, using the
1783 following recursive procedure:
1784 .IP
1785 .nf
1786 \f[C]
1787 puttree(ot) begin
1788 if ot is a tree then
1789 write the character \[aq]\[rs]002\[aq]
1790 call puttree on each child node (0-7) else if ot is empty then
1791 write the character \[aq]\[rs]000\[aq]
1792 else
1793 write the character \[aq]\[rs]001\[aq]
1794 write out the number of surfaces
1795 write out each surface\[aq]s index
1796 end
1797 end puttree
1798 \f[]
1799 .fi
1800 .LP
1801 The number of surfaces and the surface indices are each N-byte integers,
1802 and the tree node types are single bytes.
1803 Reading the octree is accomplished with a complementary procedure.
1804 .SH 4
1805 Compiled Scene Data
1806 .pdfhref O 4 "Compiled Scene Data"
1807 .pdfhref M "compiled-scene-data"
1808 .LP
1809 If the octree is frozen, then this data structure is followed by a
1810 compiled version of the scene.
1811 This avoids the problems of changes to scene files, and allows an octree
1812 to be moved conveniently from one location and one system to another
1813 without worrying about the associated scene files.
1814 .PP
1815 The scene data begins with a listing of the defined primitive types.
1816 This list consists of the name of each type as a nul-terminated string,
1817 followed by an empty string once the list has been exhausted.
1818 This permits the indexing of primitive types with a single byte later
1819 on, without concern about changes to \f[I]Radiance\f[R] involving
1820 \f[C]src/common/otypes.h\f[R].
1821 .PP
1822 The scene primitives are written one at a time.
1823 First is a single byte with the primitive type index, as determined from
1824 the list given above.
1825 Second is the N-byte modifier index, followed by the primitive\[cq]s
1826 identifier as a nul-terminated string.
1827 String arguments start with a 2-byte integer indicating the argument
1828 count, followed by the strings themselves, which are nul-terminated.
1829 Real arguments next have a 2-byte count followed by the real values,
1830 each stored as a 4-byte mantissa followed by a 1-byte (signed) exponent.
1831 (The mantissa is the numerator of a fraction of @2 sup 31 \[u2212] 1@.)
1832 The end of data is indicated with a -1 value for the object type
1833 (byte=255).
1834 .SH 3
1835 \f[BI]Radiance\f[B] Programs
1836 .pdfhref O 3 "Radiance Programs"
1837 .pdfhref M "radiance-programs-4"
1838 .LP
1839 Table 5 shows \f[I]Radiance\f[R] programs that read and write octree
1840 files.
1841 .PP
1842 .na
1843 .TS
1844 delim(@@) tab( );
1845 l l l l.
1846 T{
1847 Program
1848 T} T{
1849 Read
1850 T} T{
1851 Write
1852 T} T{
1853 Function
1854 T}
1855 _
1856 T{
1857 \f[B]getinfo\f[R]
1858 T} T{
1859 X
1860 T} T{
1861 T} T{
1862 Print information header from binary file
1863 T}
1864 T{
1865 \f[B]oconv\f[R]
1866 T} T{
1867 X
1868 T} T{
1869 X
1870 T} T{
1871 Compile \f[I]Radiance\f[R] scene description
1872 T}
1873 T{
1874 \f[B]rad\f[R]
1875 T} T{
1876 X
1877 T} T{
1878 X
1879 T} T{
1880 Render \f[I]Radiance\f[R] scene
1881 T}
1882 T{
1883 \f[B]rpict\f[R]
1884 T} T{
1885 X
1886 T} T{
1887 T} T{
1888 Batch rendering program
1889 T}
1890 T{
1891 \f[B]rpiece\f[R]
1892 T} T{
1893 X
1894 T} T{
1895 T} T{
1896 Parallel batch rendering program
1897 T}
1898 T{
1899 \f[B]rtrace\f[R]
1900 T} T{
1901 X
1902 T} T{
1903 T} T{
1904 Customizable ray-tracer
1905 T}
1906 T{
1907 \f[B]rview\f[R]
1908 T} T{
1909 X
1910 T} T{
1911 T} T{
1912 Interactive renderer
1913 T}
1914 .TE
1915 .ad
1916 .LP
1917 \f[B]Table 5.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
1918 read and write octree files.
1919 .SH 3
1920 \f[BI]Radiance\f[B] C Library
1921 .pdfhref O 3 "Radiance C Library"
1922 .pdfhref M "radiance-c-library-4"
1923 .LP
1924 Since reading an octree file also may involve reading a
1925 \f[I]Radiance\f[R] scene description, some of the same library routines
1926 are called indirectly.
1927 The header file \f[C]src/common/octree.h\f[R] is needed in addition to
1928 the \f[C]src/common/object.h\f[R] file.
1929 The module \f[C]src/ot/writeoct.c\f[R] contains the main routines for
1930 writing an octree to stdout, while \f[C]src/common/readoct.c\f[R]
1931 contains the corresponding routines for reading an octree from a file.
1932 Both modules access routines in \f[C]src/common/portio.c\f[R] for
1933 reading and writing portable binary data.
1934 .PP
1935 Here is the main call for writing out an octree:
1936 .IP "\f[B]\f[CB]writeoct(int store, CUBE *scene, char *ofn[]);\f[B]\f[R]" 3
1937 Write the octree stored in scene to stdout, assuming the header has
1938 already been written.
1939 The flags in store determine what will be included.
1940 Normally, this variable is one of \f[C]IO_ALL\f[R] or
1941 \f[C](IO_ALL & \[ti]IO_FILES)\f[R] correspondingto writing a normal or a
1942 frozen octree, respectively.
1943 .RS 3
1944 .RE
1945 .LP
1946 Here is the main call for reading in an octree:
1947 .IP "\f[B]\f[CB]readoct(char *fname, int load, CUBE *scene, char *ofn[]);\f[B]\f[R]" 3
1948 Read the octree file fname into scene, saving scene file names in the
1949 ofn array.
1950 What is loaded depends on the flags in load,which may be one or more of
1951 \f[C]IO_CHECK\f[R], \f[C]IO_INFO\f[R], \f[C]IO_SCENE\f[R],
1952 \f[C]IO_TREE\f[R], \f[C]IO_FILES\f[R] and \f[C]IO_BOUNDS\f[R].
1953 These correspond to checking file type and consistency, transferring the
1954 information header to stdout, loading the scene data, loading the octree
1955 structure, assigning the scene file names to ofn, and assigning the
1956 octree cube boundaries.
1957 The macro \f[C]IO_ALL\f[R] includes all of these flags, for convenience.
1958 .RS 3
1959 .RE
1960 .SH 2
1961 Picture File Format (.hdr suffix)
1962 .pdfhref O 2 "Picture File Format \(.hdr suffix\)"
1963 .pdfhref M "picture-file-format-.hdr-suffix"
1964 .LP
1965 \f[I]Radiance\f[R] pictures\**
1966 .FS
1967 The picture filename extension used to be .pic, but that conflicted with
1968 too many other programs.
1969 It was replaced with .hdr, an abbreviation of \[lq]high dynamic
1970 range.\[rq]
1971 .FE
1972 differ from standard computer graphics images inasmuch as they contain
1973 real physical data, namely radiance values at each pixel.
1974 To do this, it is necessary to maintain floating point information, and
1975 we use a 4-byte/pixel encoding described in Chapter II.5 of
1976 \f[I]Graphics Gems II\f[R] [Arvo91,p.80].
1977 The basic idea is to store a 1-byte mantissa for each of three
1978 primaries, and a common 1-byte exponent.
1979 The accuracy of these values will be on the order of 1% (±1 in 200) over
1980 a dynamic range from 10\*{-38\*} to 10\*{38\*}.
1981 .PP
1982 Although \f[I]Radiance\f[R] pictures \f[I]may\f[R] contain physical
1983 data, they do not \f[I]necessarily\f[R] contain physical data.
1984 If the rendering did not use properly modeled light sources, or the
1985 picture was converted from some other format, or custom filtering was
1986 applied, then the physical data will be invalid.
1987 Table 6 lists programs that read and write \f[I]Radiance\f[R] pictures,
1988 with pluses next to the X-marks indicating where physical data is
1989 preserved (or at least understood).
1990 Specifically, if the picture file read or written by a program has an
1991 \[lq]X+\[rq], then it has maintained the physical validity of the pixels
1992 by keeping track of any exposure or color corrections in the appropriate
1993 header variables, described below.
1994 .SH 3
1995 Basic File Structure
1996 .pdfhref O 3 "Basic File Structure"
1997 .pdfhref M "basic-file-structure-2"
1998 .LP
1999 \f[I]Radiance\f[R] picture files are divided into three sections: the
2000 information header, the resolution string, and the scanline records.
2001 All of these must be present or the file is incomplete.
2002 .SH 4
2003 Information Header
2004 .pdfhref O 4 "Information Header"
2005 .pdfhref M "information-header-1"
2006 .LP
2007 The information header begins with the usual \f[C]#?RADIANCE\f[R]
2008 identifier, followed by one or more lines containing the programs used
2009 to produce the picture.
2010 These commands may be interspersed with variables describing relevant
2011 information such as the view, exposure, color correction, and so on.
2012 Variable assignments begin on a new line, and the variable name (usually
2013 all upper case) is followed by an equals sign (`='), which is followed
2014 by the assigned value up until the end of line.
2015 Some variable assignments override previous assignments in the same
2016 header, where other assignments are cumulative.
2017 Here are the most important variables for \f[I]Radiance\f[R] pictures:
2018 .IP "\f[B]\f[CB]FORMAT\f[B]\f[R]" 3
2019 A line indicating the file\[cq]s format.
2020 At most one \f[C]FORMAT\f[R] line is allowed, and it must be assigned a
2021 value of either \f[C]32-bit_rle_rgbe\f[R] or \f[C]32-bit_rle_xyze\f[R]
2022 to be a valid \f[I]Radiance\f[R] picture.
2023 .RS 3
2024 .RE
2025 .IP "\f[B]\f[CB]EXPOSURE\f[B]\f[R]" 3
2026 A single floating point number indicating a multiplier that has been
2027 applied to all the pixels in the file.
2028 \f[C]EXPOSURE\f[R] values are cumulative, so the original pixel values
2029 (i.e., radiances in w/sr/m\*{2\*}) must be derived by taking the values
2030 in the file and dividing by all the \f[C]EXPOSURE\f[R] settings
2031 multiplied together.
2032 No \f[C]EXPOSURE\f[R] setting implies that no exposure changes have
2033 taken place.
2034 .RS 3
2035 .RE
2036 .IP "\f[B]\f[CB]COLORCORR\f[B]\f[R]" 3
2037 A color correction multiplier that has been applied to this picture.
2038 Similar to the \f[C]EXPOSURE\f[R] variable except given in three parts
2039 for the three primaries.
2040 In general, the value should have a brightness of unity, so that it does
2041 not affect the actual brightness of pixels, which should be tracked by
2042 \f[C]EXPOSURE\f[R] changes instead.
2043 (This variable is also cumulative.)
2044 .RS 3
2045 .RE
2046 .IP "\f[B]\f[CB]SOFTWARE\f[B]\f[R]" 3
2047 The software version used to create the picture, usually something like
2048 \f[C]RADIANCE 3.04 official release July 16, 1996\f[R].
2049 .RS 3
2050 .RE
2051 .IP "\f[B]\f[CB]PIXASPECT\f[B]\f[R]" 3
2052 The pixel aspect ratio, expressed as a decimal fraction of the height of
2053 each pixel to its width.
2054 This is not to be confused with the image aspect ratio, which is the
2055 total height over width.
2056 (The image aspect ratio is actually equal to the height in pixels over
2057 the width in pixels, \f[I]multiplied\f[R] by the pixel aspect ratio.)
2058 These assignments are cumulative, so the actual pixel aspect ratio is
2059 all ratios multiplied together.
2060 If no \f[C]PIXASPECT\f[R] assignment appears, the ratio is assumed to be
2061 1.
2062 .RS 3
2063 .RE
2064 .IP "\f[B]\f[CB]VIEW\f[B]\f[R]" 3
2065 The \f[I]Radiance\f[R] view parameters used to create this picture.
2066 Multiple assignments are cumulative inasmuch as new view options add to
2067 or override old ones.
2068 .RS 3
2069 .RE
2070 .IP "\f[B]\f[CB]PRIMARIES\f[B]\f[R]" 3
2071 The CIE (x,y) chromaticity coordinates of the three (RGB) primaries and
2072 the white point used to standardize the picture\[cq]s color system.
2073 This is used mainly by the \f[B]ra_xyze\f[R] program to convert between
2074 color systems.
2075 If no \f[C]PRIMARIES\f[R] line appears, we assume the standard primaries
2076 defined in \f[C]src/common/color.h\f[R], namely
2077 \f[C]0.640 0.330 0.290 0.600 0.150 0.060 0.333 0.333\f[R] for red,
2078 green, blue and white, respectively.
2079 .RS 3
2080 .RE
2081 .LP
2082 As always, the end of the header is indicated by an empty line.
2083 .SH 4
2084 Resolution String
2085 .pdfhref O 4 "Resolution String"
2086 .pdfhref M "resolution-string"
2087 .LP
2088 All \f[I]Radiance\f[R] pictures have a standard coordinate system, which
2089 is shown in Figure 4.
2090 The origin is always at the lower left corner, with the X coordinate
2091 increasing to the right, and the Y coordinate increasing in the upward
2092 direction.
2093 The actual ordering of pixels in the picture file, however, is addressed
2094 by the resolution string.
2095 .PSPIC "figure4.eps"
2096 .ce 1000
2097 Radiance picture coordinate system
2098 .ce 0
2099 .PP
2100 \f[B]Figure 4.\f[R] The standard coordinate system for an MxN picture.
2101 .PP
2102 The resolution string is given as one of the following:
2103 .IP "\f[B]\f[CB]-Y N +X M\f[B]\f[R]" 3
2104 The standard orientation produced by the renderers, indicating that Y is
2105 decreasing in the file, and X is increasing.
2106 X positions are increasing in each scanline, starting with the upper
2107 left position in the picture and moving to the upper right initially,
2108 then on down the picture.
2109 Some programs will only handle pictures with this ordering.
2110 .RS 3
2111 .RE
2112 .IP "\f[B]\f[CB]-Y N -X M\f[B]\f[R]" 3
2113 The X ordering has been reversed, effectively flipping the image left to
2114 right from the standard ordering.
2115 .RS 3
2116 .RE
2117 .IP "\f[B]\f[CB]+Y N -X M\f[B]\f[R]" 3
2118 The image has been flipped left to right and also top to bottom, which
2119 is the same as rotating it by 180 degrees.
2120 .RS 3
2121 .RE
2122 .IP "\f[B]\f[CB]+Y N +X M\f[B]\f[R]" 3
2123 The image has been flipped top to bottom from the standard ordering.
2124 .RS 3
2125 .RE
2126 .IP "\f[B]\f[CB]+X M +Y N\f[B]\f[R]" 3
2127 The image has been rotated 90 degrees clockwise.
2128 .RS 3
2129 .RE
2130 .IP "\f[B]\f[CB]-X M +Y N\f[B]\f[R]" 3
2131 The image has been rotated 90 degrees clockwise, then flipped top to
2132 bottom.
2133 .RS 3
2134 .RE
2135 .IP "\f[B]\f[CB]-X M -Y N\f[B]\f[R]" 3
2136 The image has been rotated 90 degrees counter-clockwise.
2137 .RS 3
2138 .RE
2139 .IP "\f[B]\f[CB]+X M -Y N\f[B]\f[R]" 3
2140 The image has been rotate 90 degrees counter-clockwise, then flipped top
2141 to bottom.
2142 .RS 3
2143 .RE
2144 .LP
2145 The reason for tracking all these changes in picture orientation is so
2146 programs that compute ray origin and direction from the \f[C]VIEW\f[R]
2147 variable in the information header will work despite such changes.
2148 Also, it can reduce memory requirements on converting from other image
2149 formats that have a different scanline ordering, such as Targa.
2150 .SH 4
2151 Scanline Records
2152 .pdfhref O 4 "Scanline Records"
2153 .pdfhref M "scanline-records"
2154 .LP
2155 \f[I]Radiance\f[R] scanlines come in one of three flavors, described
2156 below:
2157 .IP "\f[B]Uncompressed\f[R]" 3
2158 Each scanline is represented by M pixels with 4 bytes per pixel, for a
2159 total length of 4xM bytes.
2160 This is the simplest format to read and write, since it has a one-to-one
2161 correspondence to an array of \f[C]COLR\f[R] values.
2162 .RS 3
2163 .RE
2164 .IP "\f[B]Old run-length encoded\f[R]" 3
2165 Repeated pixel values are indicated by an illegal (i.e., unnormalized)
2166 pixel that has 1\[cq]s for all three mantissas, and an exponent that
2167 corresponds to the number of times the previous pixel is repeated.
2168 Consecutive repeat indicators contain higher-order bytes of the count.
2169 .RS 3
2170 .RE
2171 .IP "\f[B]New run-length encoded\f[R]" 3
2172 In this format, the four scanline components (three primaries and
2173 exponent) are separated for better compression using adaptive run-length
2174 encoding (described by Glassner in Chapter II.8 of \f[I]Graphics Gems
2175 II\f[R] [Arvo91,p.89]).
2176 The record begins with an unnormalized pixel having two bytes equal to
2177 2, followed by the upper byte and the lower byte of the scanline length
2178 (which must be less than 32768).
2179 A run is indicated by a byte with its high-order bit set, corresponding
2180 to a count with excess 128.
2181 A non-run is indicated with a byte less than 128.
2182 The maximum compression ratio using this scheme is better than 100:1,
2183 but typical performance for \f[I]Radiance\f[R] pictures is more like
2184 2:1.
2185 .RS 3
2186 .RE
2187 .LP
2188 The physical values these scanlines correspond to depend on the format
2189 and other information contained in the information header.
2190 If the \f[C]FORMAT\f[R] string indicates RGB data, then the units for
2191 each primary are spectral radiances over the corresponding waveband,
2192 such that a pixel value of @left ( 1 , 1 , 1 right )@ corresponds to a
2193 total energy of 1 w/sr/m\*{2\*} over the visible spectrum.
2194 The actual luminance value (in lm/sr/m\*{2\*}) can be computed from the
2195 following formula for the standard \f[I]Radiance\f[R] RGB primaries:
2196 .PP
2197 .EQ
2198 L sub v = 179 left ( 0.265 r + 0.670 g + 0.065 b right )
2199 .EN
2200 .PP
2201 The value of 179 lm/w is the standard \f[I]luminous efficacy\f[R] of
2202 equal-energy white light that is defined and used by \f[I]Radiance\f[R]
2203 specifically for this conversion.
2204 This and the other values above are defined in
2205 \f[C]src/common/color.h\f[R], and the above formula is given as a macro,
2206 \f[C]luminance(col)\f[R].
2207 .PP
2208 If the \f[C]FORMAT\f[R] string indicates XYZ data, then the units of the
2209 Y primary are already lm/sr/m\*{2\*}, so the above conversion is
2210 unnecessary.
2211 .SH 3
2212 \f[BI]Radiance\f[B] programs
2213 .pdfhref O 3 "Radiance programs"
2214 .pdfhref M "radiance-programs-5"
2215 .LP
2216 Table 6 shows the many programs that read and write \f[I]Radiance\f[R]
2217 pictures.
2218 .PP
2219 .na
2220 .TS
2221 delim(@@) tab( );
2222 l l l l.
2223 T{
2224 Program
2225 T} T{
2226 Read
2227 T} T{
2228 Write
2229 T} T{
2230 Function
2231 T}
2232 _
2233 T{
2234 \f[B]falsecolor\f[R]
2235 T} T{
2236 X+
2237 T} T{
2238 X
2239 T} T{
2240 Create false color image
2241 T}
2242 T{
2243 \f[B]findglare\f[R]
2244 T} T{
2245 X+
2246 T} T{
2247 T} T{
2248 Find sources of discomfort glare
2249 T}
2250 T{
2251 \f[B]getinfo\f[R]
2252 T} T{
2253 X
2254 T} T{
2255 T} T{
2256 Print information header from binary file
2257 T}
2258 T{
2259 \f[B]macbethcal\f[R]
2260 T} T{
2261 X
2262 T} T{
2263 X
2264 T} T{
2265 Compute image color & contrast correction
2266 T}
2267 T{
2268 \f[B]normpat\f[R]
2269 T} T{
2270 X
2271 T} T{
2272 X
2273 T} T{
2274 Normalize picture for use as pattern tile
2275 T}
2276 T{
2277 \f[B]objpict\f[R]
2278 T} T{
2279 T} T{
2280 X
2281 T} T{
2282 Generate composite picture of object
2283 T}
2284 T{
2285 \f[B]pcomb\f[R]
2286 T} T{
2287 X+
2288 T} T{
2289 X
2290 T} T{
2291 Perform arbitrary math on picture(s)
2292 T}
2293 T{
2294 \f[B]pcond\f[R]
2295 T} T{
2296 X+
2297 T} T{
2298 X
2299 T} T{
2300 Condition a picture for display
2301 T}
2302 T{
2303 \f[B]pcompos\f[R]
2304 T} T{
2305 X
2306 T} T{
2307 X
2308 T} T{
2309 Composite pictures
2310 T}
2311 T{
2312 \f[B]pextrem\f[R]
2313 T} T{
2314 X+
2315 T} T{
2316 T} T{
2317 Find minimum and maximum pixels
2318 T}
2319 T{
2320 \f[B]pfilt\f[R]
2321 T} T{
2322 X+
2323 T} T{
2324 X+
2325 T} T{
2326 Filter and anti-alias picture
2327 T}
2328 T{
2329 \f[B]pflip\f[R]
2330 T} T{
2331 X+
2332 T} T{
2333 X+
2334 T} T{
2335 Flip picture left-right and/or top-bottom
2336 T}
2337 T{
2338 \f[B]pinterp\f[R]
2339 T} T{
2340 X+
2341 T} T{
2342 X+
2343 T} T{
2344 Interpolate/extrapolate picture views
2345 T}
2346 T{
2347 \f[B]protate\f[R]
2348 T} T{
2349 X+
2350 T} T{
2351 X+
2352 T} T{
2353 Rotate picture 90 degrees clockwise
2354 T}
2355 T{
2356 \f[B]psign\f[R]
2357 T} T{
2358 T} T{
2359 X
2360 T} T{
2361 Create text picture
2362 T}
2363 T{
2364 \f[B]pvalue\f[R]
2365 T} T{
2366 X+
2367 T} T{
2368 X+
2369 T} T{
2370 Convert picture to/from simpler formats
2371 T}
2372 T{
2373 \f[B]ra_avs\f[R]
2374 T} T{
2375 X
2376 T} T{
2377 X
2378 T} T{
2379 Convert to/from AVS image format
2380 T}
2381 T{
2382 \f[B]ra_pict\f[R]
2383 T} T{
2384 X
2385 T} T{
2386 X
2387 T} T{
2388 Convert to/from Macintosh PICT2 format
2389 T}
2390 T{
2391 \f[B]ra_ppm\f[R]
2392 T} T{
2393 X
2394 T} T{
2395 X
2396 T} T{
2397 Convert to/from Poskanzer Port.
2398 Pixmap
2399 T}
2400 T{
2401 \f[B]ra_pr\f[R]
2402 T} T{
2403 X
2404 T} T{
2405 X
2406 T} T{
2407 Convert to/from Sun 8-bit rasterfile
2408 T}
2409 T{
2410 \f[B]ra_pr24\f[R]
2411 T} T{
2412 X
2413 T} T{
2414 X
2415 T} T{
2416 Convert to/from Sun 24-bit rasterfile
2417 T}
2418 T{
2419 \f[B]ra_ps\f[R]
2420 T} T{
2421 X
2422 T} T{
2423 T} T{
2424 Convert to B&W or color PostScript
2425 T}
2426 T{
2427 \f[B]ra_rgbe\f[R]
2428 T} T{
2429 X
2430 T} T{
2431 X
2432 T} T{
2433 Convert to/from uncompressed picture
2434 T}
2435 T{
2436 \f[B]ra_t8\f[R]
2437 T} T{
2438 X
2439 T} T{
2440 X
2441 T} T{
2442 Convert to/from Targa 8-bit format
2443 T}
2444 T{
2445 \f[B]ra_t16\f[R]
2446 T} T{
2447 X
2448 T} T{
2449 X
2450 T} T{
2451 Convert to/from Targa 16-bit and 24-bit
2452 T}
2453 T{
2454 \f[B]ra_tiff\f[R]
2455 T} T{
2456 X
2457 T} T{
2458 X
2459 T} T{
2460 Convert to/from TIFF 8-bit and 24-bit
2461 T}
2462 T{
2463 \f[B]ra_xyze\f[R]
2464 T} T{
2465 X
2466 T} T{
2467 X
2468 T} T{
2469 Convert to/from CIE primary picture
2470 T}
2471 T{
2472 \f[B]rad\f[R]
2473 T} T{
2474 T} T{
2475 X+
2476 T} T{
2477 Render Radiance scene
2478 T}
2479 T{
2480 \f[B]ranimate\f[R]
2481 T} T{
2482 T} T{
2483 X+
2484 T} T{
2485 Animate Radiance scene
2486 T}
2487 T{
2488 \f[B]rpict\f[R]
2489 T} T{
2490 X
2491 T} T{
2492 X+
2493 T} T{
2494 Batch rendering program
2495 T}
2496 T{
2497 \f[B]rpiece\f[R]
2498 T} T{
2499 X
2500 T} T{
2501 X+
2502 T} T{
2503 Parallel batch rendering program
2504 T}
2505 T{
2506 \f[B]rtrace\f[R]
2507 T} T{
2508 X
2509 T} T{
2510 X+
2511 T} T{
2512 Customizable ray-tracer
2513 T}
2514 T{
2515 \f[B]rview\f[R]
2516 T} T{
2517 X
2518 T} T{
2519 X+
2520 T} T{
2521 Interactive renderer
2522 T}
2523 T{
2524 \f[B]vwright\f[R]
2525 T} T{
2526 X
2527 T} T{
2528 T} T{
2529 Get view parameters and shift them
2530 T}
2531 T{
2532 \f[B]xglaresrc\f[R]
2533 T} T{
2534 X
2535 T} T{
2536 T} T{
2537 Display glare sources from \f[B]findglare\f[R]
2538 T}
2539 T{
2540 \f[B]ximage\f[R]
2541 T} T{
2542 X+
2543 T} T{
2544 T} T{
2545 Display \f[I]Radiance\f[R] picture under \f[I]X11\f[R]
2546 T}
2547 T{
2548 \f[B]xshowtrace\f[R]
2549 T} T{
2550 X
2551 T} T{
2552 T} T{
2553 Show ray traces on \f[I]X11\f[R] display
2554 T}
2555 .TE
2556 .ad
2557 .LP
2558 \f[B]Table 6.\f[R] \f[I]Radiance\f[R] programs that read and write
2559 picture files.
2560 Pluses indicate when a program makes use of or preserves physical pixel
2561 values.
2562 .SH 3
2563 \f[BI]Radiance\f[B] C Library
2564 .pdfhref O 3 "Radiance C Library"
2565 .pdfhref M "radiance-c-library-5"
2566 .LP
2567 There are a fair number of routines for reading, writing and
2568 manipulating \f[I]Radiance\f[R] pictures.
2569 If you want to write a converter to or from a 24-bit image format, you
2570 can follow the skeletal example in \f[C]src/px/ra_skel.c\f[R].
2571 This has all of the basic functionality of the other \f[B]ra_*\f[R]
2572 image conversion programs, with the actual code for the destination type
2573 removed (or simplified).
2574 The method in \f[C]ra_skel\f[R] uses the routines in
2575 \f[C]src/common/colrops.c\f[R] to avoid conversion to machine floating
2576 point, which can slow things down and is not necessary in this case.
2577 .PP
2578 Below we describe routines for reading and writing pictures, which rely
2579 heavily on definitions in \f[C]src/common/color.h\f[R].
2580 We start with the calls for manipulating information headers, followed
2581 by the calls for resolution strings, then the calls for scanline
2582 records.
2583 .PP
2584 Information headers are manipulated with the routines in
2585 \f[C]src/common/header.c\f[R] and the macros in \f[C]color.h\f[R].
2586 Features for handing views are defined in \f[C]src/common/view.h\f[R]
2587 with routines in \f[C]src/common/image.c\f[R].
2588 Here are the relevant calls for reading and copying information headers:
2589 .IP "\f[B]\f[CB]int checkheader(FILE *fin, char *fmt, FILE *fout);\f[B]\f[R]" 3
2590 Read the header information from \f[C]fin\f[R], copying to
2591 \f[C]fout\f[R] (unless fout is \f[C]NULL\f[R]), checking any
2592 \f[C]FORMAT\f[R] line against the string \f[C]fmt\f[R].
2593 The \f[C]FORMAT\f[R] line (if it exists) will not be copied to
2594 \f[C]fout\f[R].
2595 The function returns 1 if the header was OK and the format matched, 0 if
2596 the header was OK but there was no format line, and -1 if the format
2597 line did not match or there was some problem reading the header.
2598 Wildcard characters (`*' and `?') may appear in \f[C]fmt\f[R], in which
2599 case a globbing match is applied, and the matching format value will be
2600 copied to fmt upon success.
2601 The normal \f[C]fmt\f[R] values for pictures are \f[C]COLRFMT\f[R] for
2602 \f[I]Radiance\f[R] RGB, \f[C]CIEFMT\f[R] for 4-byte XYZ pixels, or a
2603 copy of \f[C]PICFMT\f[R] for glob matches to either.
2604 (Do not pass \f[C]PICFMT\f[R] directly, as this will cause an illegal
2605 memory access on systems that store static strings in read-only memory.)
2606 .RS 3
2607 .RE
2608 .IP "\f[B]\f[CB]int getheader(FILE *fp, int (*f)(), char *p);\f[B]\f[R]" 3
2609 For those who need more control, \f[C]getheader\f[R] reads the header
2610 from \f[C]fp\f[R], calling the function \f[C]f\f[R] (if
2611 not\f[C]NULL\f[R]) with each input line and the client data pointer
2612 \f[C]p\f[R].
2613 A simple call to skip the header is \f[C]getheader(fp,NULL,NULL)\f[R].
2614 To copy the header unconditionally to \f[C]stdout\f[R], call
2615 \f[C]getheader(fp,fputs,stdout)\f[R].
2616 More often, \f[C]getheader\f[R] is called with a client function, which
2617 checks each line for specific variable settings.
2618 .RS 3
2619 .RE
2620 .IP "\f[B]\f[CB]int isformat(char *s);\f[B]\f[R]" 3
2621 Returns non-zero if the line \f[C]s\f[R] is a \f[C]FORMAT\f[R]
2622 assignment.
2623 .RS 3
2624 .RE
2625 .IP "\f[B]\f[CB]int formatval(char *r, char *s);\f[B]\f[R]" 3
2626 Returns the \f[C]FORMAT\f[R] value from line \f[C]s\f[R] in the string
2627 \f[C]r\f[R].
2628 Returns non-zero if \f[C]s\f[R] is a valid format line.
2629 .RS 3
2630 .RE
2631 .IP "\f[B]\f[CB]fputformat(char *s, FILE *fp);\f[B]\f[R]" 3
2632 Put format assignment \f[C]s\f[R] to the stream \f[C]fp\f[R].
2633 .RS 3
2634 .RE
2635 .IP "\f[B]\f[CB]isexpos(s)\f[B]\f[R]" 3
2636 Macro returns non-zero if the line \f[C]s\f[R] is an \f[C]EXPOSURE\f[R]
2637 setting.
2638 .RS 3
2639 .RE
2640 .IP "\f[B]exposval(s)\f[R]" 3
2641 Macro returns \f[B]double\f[R] exposure value from line \f[C]s\f[R].
2642 .RS 3
2643 .RE
2644 .IP "\f[B]\f[CB]fputexpos(ex,fp)\f[B]\f[R]" 3
2645 Macro** | puts real exposure value \f[C]ex\f[R] to stream \f[C]fp\f[R].
2646 .RS 3
2647 .RE
2648 .IP "\f[B]\f[CB]iscolcor(s)\f[B]\f[R]" 3
2649 Macro returns non-zero if the line \f[C]s\f[R] is a \f[C]COLORCORR\f[R]
2650 setting.
2651 .RS 3
2652 .RE
2653 .IP "\f[B]\f[CB]colcorval(cc,s)\f[B]\f[R]" 3
2654 Macro assign color correction value from line \f[C]s\f[R] in the
2655 \f[C]COLOR\f[R] variable \f[C]cc\f[R].
2656 .RS 3
2657 .RE
2658 .IP "\f[B]\f[CB]fputcolcor(cc,fp)\f[B]\f[R]" 3
2659 Macro puts correction \f[C]COLOR\f[R] \f[C]cc\f[R] to stream
2660 \f[C]fp\f[R].
2661 .RS 3
2662 .RE
2663 .IP "\f[B]\f[CB]isaspect(s)\f[B]\f[R]" 3
2664 Macro returns non-zero if the line \f[C]s\f[R] is a \f[C]PIXASPECT\f[R]
2665 setting.
2666 .RS 3
2667 .RE
2668 .IP "\f[B]\f[CB]aspectval(s)\f[B]\f[R]" 3
2669 Macro returns double pixel aspect value from line \f[C]s\f[R].
2670 .RS 3
2671 .RE
2672 .IP "\f[B]\f[CB]fputaspect(pa,fp)\f[B]\f[R]" 3
2673 Macro puts real pixel aspect value \f[C]pa\f[R] to stream \f[C]fp\f[R].
2674 .RS 3
2675 .RE
2676 .IP "\f[B]\f[CB]int isview(char *s);\f[B]\f[R]" 3
2677 Returns non-zero if header line \f[C]s\f[R] contains view parameters.
2678 Note that \[ga]\f[C]s\f[R] could be either a \f[C]VIEW\f[R] assignment
2679 or a rendering command.
2680 .RS 3
2681 .RE
2682 .IP "\f[B]\f[CB]int sscanview(VIEW *vp, char *s);\f[B]\f[R]" 3
2683 Scan view options from the string \f[C]s\f[R] into the \f[C]VIEW\f[R]
2684 structure pointed to by \f[C]vp\f[R].
2685 .RS 3
2686 .RE
2687 .IP "\f[B]\f[CB]fprintview(VIEW *vp, FILE *fp);\f[B]\f[R]" 3
2688 Print view options in \f[C]vp\f[R] to the stream \f[C]fp\f[R].
2689 Note that this does not print out \[lq]VIEW=\[rq] first, or end the
2690 line.
2691 Therefore, one usually calls \f[C]fputs(VIEWSTR,fp)\f[R] followed by
2692 \f[C]fprintview(vp,fp)\f[R], then \f[C]putc(\[aq]\[rs]n\[aq],fp)\f[R].
2693 .RS 3
2694 .RE
2695 .IP "\f[B]\f[CB]isprims(s)\f[B]\f[R]" 3
2696 Macro returns non-zero if the line \f[C]s\f[R] is a \f[C]PRIMARIES\f[R]
2697 setting.
2698 .RS 3
2699 .RE
2700 .IP "\f[B]\f[CB]primsval(p,s)\f[B]\f[R]" 3
2701 Macro assign color primitives from line \f[C]s\f[R] in the
2702 \f[C]RGBPRIMS\f[R] variable \f[C]p\f[R].
2703 .RS 3
2704 .RE
2705 .IP "\f[B]\f[CB]fputprims(p,fp)\f[B]\f[R]" 3
2706 Macro puts color primitives \f[C]p\f[R] to stream \f[C]fp\f[R].
2707 .RS 3
2708 .RE
2709 .LP
2710 The header file \f[C]src/common/resolu.h\f[R] has macros for resolution
2711 strings, which are handled by routines in \f[C]src/common/resolu.c\f[R].
2712 Here are the relevant calls:
2713 .IP "\f[B]\f[CB]fgetsresolu(rs,fp)\f[B]\f[R]" 3
2714 Macro to get a resolution string from the stream \f[C]fp\f[R] and put it
2715 in the \f[C]RESOLU\f[R] structure pointed to by \f[C]rs\f[R].
2716 The return value is non-zero if the resolution was successfully loaded.
2717 .RS 3
2718 .RE
2719 .IP "\f[B]\f[CB]fputsresolu(rs,fp)\f[B]\f[R]" 3
2720 Macro to write the \f[C]RESOLU\f[R] structure pointed to by rs to the
2721 stream fp.
2722 .RS 3
2723 .RE
2724 .IP "\f[B]\f[CB]scanlen(rs)\f[B]\f[R]" 3
2725 Macro to get the scanline length from the \f[C]RESOLU\f[R] structure
2726 pointed to by \f[C]rs\f[R].
2727 .RS 3
2728 .RE
2729 .IP "\f[B]\f[CB]numscans(rs)\f[B]\f[R]" 3
2730 Macro to get the number of scanlines from the \f[C]RESOLU\f[R] structure
2731 pointed to by \f[C]rs\f[R].
2732 .RS 3
2733 .RE
2734 .IP "\f[B]\f[CB]fscnresolu(slp,nsp,fp)\f[B]\f[R]" 3
2735 Macro to read in a resolution string from \f[C]fp\f[R] and assign the
2736 scanline length and number of scanlines to the integers pointed to by
2737 \f[C]slp\f[R] and \f[C]nsp\f[R], respectively.
2738 This call expects standard English-text ordered scanlines, and returns
2739 non-zero only if the resolution string agrees.
2740 .RS 3
2741 .RE
2742 .IP "\f[B]\f[CB]fprtresolu(sl,ns,fp)\f[B]\f[R]" 3
2743 Macro to print out a resolution string for \f[C]ns\f[R] scanlines of
2744 length \f[C]sl\f[R] in standard English-text ordering to \f[C]fp\f[R].
2745 .RS 3
2746 .RE
2747 .LP
2748 The file \f[C]src/common/color.c\f[R] contains the essential routines
2749 for reading and writing scanline records.
2750 Here are the relevant calls and macros:
2751 .IP "\f[B]\f[CB]int freadcolrs(COLR *scn, int sl, FILE *fp);\f[B]\f[R]" 3
2752 Read a scanline record of length \f[C]sl\f[R] from stream \f[C]fp\f[R]
2753 into the \f[C]COLR\f[R] array \f[C]scn\f[R].
2754 Interprets uncompressed, old, and new run-length encoded records.
2755 Returns 0 on success, -1 on failure.
2756 .RS 3
2757 .RE
2758 .IP "\f[B]\f[CB]int fwritecolrs(COLR *scn, int sl, FILE *fp);\f[B]\f[R]" 3
2759 Write the scanline record stored in the \f[C]COLR\f[R] array
2760 \f[C]scn\f[R], length \f[C]sl\f[R], to the stream \f[C]fp\f[R].
2761 Uses the new run-length encoding unless \f[C]sl\f[R] is less than 8 or
2762 greater than 32767, when an uncompressed record is written.
2763 Returns 0 on success, -1 if there was an error.
2764 .RS 3
2765 .RE
2766 .IP "\f[B]\f[CB]int freadscan(COLOR *fscn, int sl, FILE *fp);\f[B]\f[R]" 3
2767 Reads a scanline of length \f[C]sl\f[R] from the stream \f[C]fp\f[R] and
2768 converts to machine floating-point format in the array \f[C]fscn\f[R].
2769 Recognizes all scanline record encodings.
2770 Returns 0 on success, or -1 on failure.
2771 .RS 3
2772 .RE
2773 .IP "\f[B]\f[CB]int fwritescan(COLOR *fscn, int sl, FILE *fp);\f[B]\f[R]" 3
2774 Write the floating-point scanline of length \f[C]sl\f[R] stored in the
2775 array fscn to the stream \f[C]fp\f[R].
2776 Converts to 4-byte/pixel scanline format and calls \f[C]fwritecolrs\f[R]
2777 to do the actual write.
2778 Returns 0 on success, or -1 if there was an error.
2779 .RS 3
2780 .RE
2781 .IP "\f[B]\f[CB]colval(col,p)\f[B]\f[R]" 3
2782 Macro to get primary p from the floating-point \f[C]COLOR col\f[R].
2783 The primary index may be one of \f[C]RED\f[R], \f[C]GRN\f[R] or
2784 \f[C]BLU\f[R] for RGB colors, or CIEX, CIEY or CIEZ for XYZ colors.
2785 This macro is a valid lvalue, so can be used on the left of assignment
2786 statements as well.
2787 .RS 3
2788 .RE
2789 .IP "\f[B]\f[CB]colrval(clr,p)\f[B]\f[R]" 3
2790 Macro to get primary \f[C]p\f[R] from the 4-byte \f[C]COLR\f[R] pixel
2791 \f[C]clr\f[R].
2792 The primary index may be one of RED, GRN or BLU for RGB colors, or CIEX,
2793 CIEY or CIEZ for XYZ colors.
2794 Unless just one primary is needed, it is more efficient to call
2795 \f[C]colr_color\f[R] and use the \f[C]colval\f[R] macro on the result.
2796 .RS 3
2797 .RE
2798 .IP "\f[B]\f[CB]colr_color(COLOR col, COLR clr);\f[B]\f[R]" 3
2799 Convert the 4-byte pixel \f[C]clr\f[R] to a machine floating-point
2800 representation and store the result in \f[C]col\f[R].
2801 .RS 3
2802 .RE
2803 .IP "\f[B]\f[CB]setcolr(COLR clr, double p1, p2, p3);\f[B]\f[R]" 3
2804 Assign the 4-byte pixel \f[C]clr\f[R] according to the three primary
2805 values \f[C]p1\f[R], \f[C]p2\f[R] and \f[C]p3\f[R].
2806 These can be either \f[I]Radiance\f[R] RGB values or CIE XYZ values.
2807 .RS 3
2808 .RE
2809 .SH 2
2810 Z-buffer Format (.zbf suffix)
2811 .pdfhref O 2 "Z-buffer Format \(.zbf suffix\)"
2812 .pdfhref M "z-buffer-format-.zbf-suffix"
2813 .LP
2814 The Z-buffer format used in \f[I]Radiance\f[R] hardly qualifies as a
2815 format at all.
2816 It is in fact a straight copy on the 4-byte machine floating point
2817 values of each pixel in standard scanline order.
2818 There is no information header or resolution string that would make the
2819 file independently useful.
2820 This is usually OK, because Z-buffer files are almost always created and
2821 used in conjunction with a picture file, which has this identifying
2822 information.
2823 .PP
2824 The major shortcoming of this format is that the machine representation
2825 and byte ordering is not always the same from one system to another,
2826 which limits the portability of Z-buffer files.
2827 Since they are primarily used for interpolating animation frames, and
2828 this usually occurs on networks with similar architectures, there is
2829 usually no problem.
2830 Also, since the adoption of IEEE standard floating-point calculations,
2831 different machine representations are becoming quite rare.
2832 [TBD: is this necessary at this point?]
2833 .SH 3
2834 \f[BI]Radiance\f[B] programs
2835 .pdfhref O 3 "Radiance programs"
2836 .pdfhref M "radiance-programs-6"
2837 .LP
2838 Table 7 shows the programs that read and write \f[I]Radiance\f[R]
2839 Z-buffer files.
2840 The pvalue program may be used to convert Z-buffer files to
2841 \f[I]Radiance\f[R] pictures for the purpose of visualizing the values
2842 using falsecolor.
2843 For example, the following command converts the Z-buffer file
2844 \f[C]frame110.zbf\f[R] associated with the picture
2845 \f[C]frame110.hdr\f[R] to a viewable image:
2846 .IP
2847 .nf
2848 \f[C]
2849 % pvalue -h \[ga]getinfo -d < frame110.hdr\[ga] -r -b -df
2850 frame110.zbf | falsecolor -m 1 -s 40 -l Meters >
2851 frame110z.hdr
2852 \f[]
2853 .fi
2854 .LP
2855 The \f[B]getinfo\f[R] program appearing in back-quotes was used to get
2856 the dimensions associated with the Z-buffer from its corresponding
2857 picture file.
2858 .PP
2859 .na
2860 .TS
2861 delim(@@) tab( );
2862 l l l l.
2863 T{
2864 Program
2865 T} T{
2866 Read
2867 T} T{
2868 Write
2869 T} T{
2870 Function
2871 T}
2872 _
2873 T{
2874 \f[B]pinterp\f[R]
2875 T} T{
2876 X
2877 T} T{
2878 X
2879 T} T{
2880 Interpolate/extrapolate picture views
2881 T}
2882 T{
2883 \f[B]pvalue\f[R]
2884 T} T{
2885 X
2886 T} T{
2887 X
2888 T} T{
2889 Convert picture to/from simpler formats
2890 T}
2891 T{
2892 \f[B]rad\f[R]
2893 T} T{
2894 T} T{
2895 X
2896 T} T{
2897 Render Radiance scene
2898 T}
2899 T{
2900 \f[B]ranimate\f[R]
2901 T} T{
2902 X
2903 T} T{
2904 X
2905 T} T{
2906 Animate Radiance scene
2907 T}
2908 T{
2909 \f[B]rpict\f[R]
2910 T} T{
2911 T} T{
2912 X
2913 T} T{
2914 Batch rendering program
2915 T}
2916 T{
2917 \f[B]rtrace\f[R]
2918 T} T{
2919 T} T{
2920 X
2921 T} T{
2922 Customizable ray-tracer
2923 T}
2924 .TE
2925 .ad
2926 .LP
2927 \f[B]Table 7.\f[R] \f[I]Radiance\f[R] programs that read and write
2928 Z-buffer files.
2929 .SH 3
2930 \f[BI]Radiance\f[B] C Library
2931 .pdfhref O 3 "Radiance C Library"
2932 .pdfhref M "radiance-c-library-6"
2933 .LP
2934 There are no library functions devoted to reading and writing Z-buffer
2935 files in particular.
2936 The normal method is to read and write Z-buffer scanlines with the
2937 standard \f[C]fread\f[R] and \f[C]fwrite\f[R] library functions using an
2938 appropriate float array.
2939 .SH 2
2940 Ambient File Format (.amb suffix)
2941 .pdfhref O 2 "Ambient File Format \(.amb suffix\)"
2942 .pdfhref M "ambient-file-format-.amb-suffix"
2943 .LP
2944 \f[I]Radiance\f[R] can store its diffuse interreflection cache in an
2945 \f[I]ambient file\f[R] for reuse by other processes.
2946 This file is in a system-independent binary format, similar to an octree
2947 or picture file, with an information header that can be read using
2948 \f[B]getinfo\f[R].
2949 Following the header, there is a magic number specific to this file
2950 type, then the ambient value records themselves in encoded form.
2951 .SH 4
2952 Information Header
2953 .pdfhref O 4 "Information Header"
2954 .pdfhref M "information-header-2"
2955 .LP
2956 The information header begins with the usual \[lq]#?RADIANCE\[rq]
2957 identifier, followed by the originating program and the ambient
2958 calculation parameters (and octree name).
2959 After this is the line:
2960 .IP
2961 .nf
2962 \f[C]
2963 FORMAT=Radiance_ambval
2964 \f[]
2965 .fi
2966 .LP
2967 This identifies the general file type, followed by an empty line ending
2968 the header.
2969 As with most information headers, this exact sequence need not be
2970 followed, so long as there is no inconsistent \f[C]FORMAT\f[R] setting.
2971 .SH 4
2972 Magic Number
2973 .pdfhref O 4 "Magic Number"
2974 .pdfhref M "magic-number"
2975 .LP
2976 Following the information header is the two-byte magic number, which for
2977 the current ambient file format is 557.
2978 This number may change later should the file format be altered in
2979 incompatible ways.
2980 .SH 4
2981 Ambient Value Records
2982 .pdfhref O 4 "Ambient Value Records"
2983 .pdfhref M "ambient-value-records"
2984 .LP
2985 Ambient values are written to the file in no particular order.
2986 Each diffuse interreflection value in \f[I]Radiance\f[R] has the
2987 following members:
2988 .IP "\f[B]Level\f[R]" 3
2989 The number of reflections between the primary (eye) ray and this
2990 surface.
2991 A value with fewer reflections may be used in place of one with more,
2992 but not the other way around.
2993 .RS 3
2994 .RE
2995 .IP "\f[B]Weight\f[R]" 3
2996 The weighting value associated with this ray or ambient value.
2997 Similar to the level to avoid using inappropriate values from the cache.
2998 .RS 3
2999 .RE
3000 .IP "\f[B]Position\f[R]" 3
3001 The origin point of this interreflection calculation.
3002 .RS 3
3003 .RE
3004 .IP "\f[B]Direction\f[R]" 3
3005 The surface normal indicating the zenith of the sample hemisphere for
3006 this value.
3007 .RS 3
3008 .RE
3009 .IP "\f[B]Value\f[R]" 3
3010 The calculated indirect irradiance at this point, in w/m\*{2\*} (RGB
3011 color).
3012 .RS 3
3013 .RE
3014 .IP "\f[B]Radius\f[R]" 3
3015 The cosine-weighted, harmonic mean distance to other surfaces visible
3016 from this point, used to decide point spacing.
3017 .RS 3
3018 .RE
3019 .IP "\f[B]Posgradient\f[R]" 3
3020 The position-based gradient vector, indicating how brightness changes as
3021 a function of position in the sample plane.
3022 .RS 3
3023 .RE
3024 .IP "\f[B]Dirgradient\f[R]" 3
3025 The direction-based gradient vector, indicating how brightness changes
3026 as a function of surface orientation.
3027 .RS 3
3028 .RE
3029 .LP
3030 The members are stored one after the other in the above order using
3031 system-independent binary representations.
3032 The Level member takes 1 byte, Weight takes 5, Position takes 15,
3033 Direction another 15, Value is 4 bytes (using the same color format as
3034 \f[I]Radiance\f[R] pictures), Radius takes 5 bytes, and Posgradient and
3035 Dirgradient each take 15 bytes, for a total size of 75 bytes per record.
3036 .SH 3
3037 \f[BI]Radiance\f[B] Programs
3038 .pdfhref O 3 "Radiance Programs"
3039 .pdfhref M "radiance-programs-7"
3040 .LP
3041 Table 8 shows \f[I]Radiance\f[R] programs that read and write ambient
3042 files.
3043 The program \f[B]lookamb\f[R] is especially useful for examining the
3044 contents of ambient files and debugging problems in the calculation.
3045 .PP
3046 .na
3047 .TS
3048 delim(@@) tab( );
3049 l l l l.
3050 T{
3051 Program
3052 T} T{
3053 Read
3054 T} T{
3055 Write
3056 T} T{
3057 Function
3058 T}
3059 _
3060 T{
3061 \f[B]getinfo\f[R]
3062 T} T{
3063 X
3064 T} T{
3065 T} T{
3066 Print information header from binary file
3067 T}
3068 T{
3069 \f[B]lookamb\f[R]
3070 T} T{
3071 X
3072 T} T{
3073 X
3074 T} T{
3075 Convert \f[I]Radiance\f[R] ambient file
3076 T}
3077 T{
3078 \f[B]rad\f[R]
3079 T} T{
3080 X
3081 T} T{
3082 X
3083 T} T{
3084 Render \f[I]Radiance\f[R] scene
3085 T}
3086 T{
3087 \f[B]rpict\f[R]
3088 T} T{
3089 X
3090 T} T{
3091 X
3092 T} T{
3093 Batch rendering program
3094 T}
3095 T{
3096 \f[B]rpiece\f[R]
3097 T} T{
3098 X
3099 T} T{
3100 X
3101 T} T{
3102 Parallel batch rendering program
3103 T}
3104 T{
3105 \f[B]rtrace\f[R]
3106 T} T{
3107 X
3108 T} T{
3109 X
3110 T} T{
3111 Customizable ray-tracer
3112 T}
3113 T{
3114 \f[B]rview\f[R]
3115 T} T{
3116 X
3117 T} T{
3118 X
3119 T} T{
3120 Interactive renderer
3121 T}
3122 .TE
3123 .ad
3124 .LP
3125 \f[B]Table 8.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
3126 read and write ambient files.
3127 .SH 3
3128 \f[BI]Radiance\f[B] C Library
3129 .pdfhref O 3 "Radiance C Library"
3130 .pdfhref M "radiance-c-library-7"
3131 .LP
3132 The \f[C]src/rt/ambient.h\f[R] file contains definitions of the
3133 \f[C]AMBVAL\f[R] structure and certain details of the ambient file
3134 format.
3135 The \f[C]src/rt/ambio.c\f[R] module contains the specialized routines
3136 for reading and writing ambient files, and these functions in turn
3137 access routines in \f[C]src/common/portio.c\f[R] for reading and writing
3138 portable binary data.
3139 The information header is handled by the routines in
3140 \f[C]src/common/header.c\f[R], similar to the method described for
3141 \f[I]Radiance\f[R] picture files.
3142 Here are the main calls from \f[C]src/rt/ambio.c\f[R]:
3143 .IP "\f[B]\f[CB]putambmagic(FILE *fp);\f[B]\f[R]" 3
3144 Put out the appropriate two-byte magic number for a \f[I]Radiance\f[R]
3145 ambient file to the stream \f[C]fp\f[R].
3146 .RS 3
3147 .RE
3148 .IP "\f[B]\f[CB]int hasambmagic(FILE *fp);\f[B]\f[R]" 3
3149 Read the next two bytes from the stream \f[C]fp\f[R] and return non-zero
3150 if they match an ambient file\[cq]s magic number.
3151 .RS 3
3152 .RE
3153 .IP "\f[B]\f[CB]int writeambval(AMBVAL *av, FILE *fp);\f[B]\f[R]" 3
3154 Write out the ambient value structure \f[C]av\f[R] to the stream
3155 \f[C]fp\f[R], returning -1 if a file error occurred, or 0 normally.
3156 .RS 3
3157 .RE
3158 .IP "\f[B]\f[CB]int readambval(AMBVAL *av, FILE *fp);\f[B]\f[R]" 3
3159 Read in the next ambient value structure from the stream \f[C]fp\f[R]
3160 and put the result in \f[C]av\f[R].
3161 Return 1 if the read was successful, 0 if the end of file was reached or
3162 there was an error.
3163 The \f[C]ambvalOK\f[R] function is used to check the consistency of the
3164 value read.
3165 .RS 3
3166 .RE
3167 .IP "\f[B]\f[CB]int ambvalOK(AMBVAL *av);\f[B]\f[R]" 3
3168 Return non-zero if the member values of the \f[C]av\f[R] structure are
3169 not too outlandish.
3170 This is handy as insurance against a corrupted ambient file.
3171 .RS 3
3172 .RE
3173 .SH 2
3174 Conclusion
3175 .pdfhref O 2 "Conclusion"
3176 .pdfhref M "conclusion"
3177 .LP
3178 We have described the main file formats native to \f[I]Radiance\f[R] and
3179 shown how even the binary formats can be reliably shared in
3180 heterogeneous computing environments.
3181 This corresponds to one of the basic philosophies of UNIX software,
3182 which is system independence.
3183 A more detailed understanding of the formats may still require some use
3184 of binary dump programs and delving into the \f[I]Radiance\f[R] source
3185 code.
