root/radiance/build_utils/load_plat.py
Revision: 1.7
Committed: Mon Sep 19 11:30:09 2005 UTC (20 years, 1 month ago) by schorsch
Content type: text/x-python
Changes since 1.6: +12 -12 lines
1
2 import os
3 import sys
4 import string
5 import ConfigParser
6
7
8 _platdir = 'platform'
9
10
11 def read_plat(env, args, fn):
12 cfig = ConfigParser.ConfigParser(env.Dictionary())
13 cfig.read(fn)
14 buildvars = [['CC'], # replace
15 ['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS',
16 'LIBPATH', 'LINKFLAGS']] # append
17 vars = [
18 ['install',
19 ['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'],
20 []],
21 ['code',
22 [], # replace
23 [ # append
24 'RAD_COMPAT', # currently obsolete
25 'RAD_MATHCOMPAT', # erf.c floating point error function
26 'RAD_ARGSCOMPAT', # fixargv0.c for Windows
27 'RAD_NETCOMPAT', # [win_]netproc.c for ranimate
28 'RAD_MLIB', # usually 'm', or any fastlib available
29 'RAD_SOCKETLIB', # ws_2_32 on Windows (VC links it automatically)
30 'RAD_PROCESS']], # our process abstraction and win_popen()
31 ]
32 if args.get('RAD_DEBUG',0):
33 vars.insert(0, ['debug'] + buildvars)
34 else: vars.insert(0, ['build'] + buildvars)
35 for section in vars:
36 if cfig.has_section(section[0]):
37 for p in section[1]: # single items to replace
38 try: v = cfig.get(section[0], p)
39 except ConfigParser.NoOptionError: continue
40 env[p] = v
41 #print '%s: %s' % (p, env[p])
42 for p in section[2]: # multiple items to append
43 try: v = cfig.get(section[0], p)
44 except ConfigParser.NoOptionError: continue
45 apply(env.Append,[],{p:string.split(v)})
46 #print '%s: %s' % (p, env[p])
47 # XXX Check that basedir exists.
48 for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']:
49 if (env.has_key('RAD_BASEDIR') and env.has_key(k)
50 and not os.path.isabs(env[k])):
51 env[k] = os.path.join(env['RAD_BASEDIR'],env[k])
52
53
54 def load_plat(env, args, platform=None):
55 if platform == None: # override
56 p = sys.platform
57 else: p = platform
58 if p == 'win32' and 'gcc' in env['TOOLS']:
59 # we don't really want to know this here...
60 p = 'mingw'
61 pl = []
62 print 'Detected platform "%s" (%s).' % (sys.platform, os.name)
63 for i in [len(p), -1, -2]:
64 pfn = os.path.join(_platdir, p[:i] + '_custom.cfg')
65 if os.path.isfile(pfn):
66 print 'Reading configuration "%s"' % pfn
67 read_plat(env, args, pfn)
68 return 1
69 pfn = os.path.join(_platdir, p[:i] + '.cfg')
70 if os.path.isfile(pfn):
71 print 'Reading configuration "%s"' % pfn
72 read_plat(env, args, pfn)
73 return 1
74
75 if os.name == 'posix':
76 pfn = os.path.join(_platdir, 'posix.cfg')
77 if os.path.isfile(pfn):
78 print 'Reading generic configuration "%s".' % pfn
79 read_plat(env, args, pfn)
80 return 1
81
82 print 'Platform "%s/%s" not supported yet' % (os.name, sys.platform)
83 sys.exit(2)
84
85
86
