| 1 |
| 2 |
import os
| 3 |
import sys
| 4 |
import ConfigParser
| 5 |
| 6 |
| 7 |
_platdir = 'platform'
| 8 |
| 9 |
| 10 |
def read_plat(env, args, fn):
| 11 |
cfig = ConfigParser.ConfigParser(env.Dictionary())
| 12 |
cfig.read(fn)
| 13 |
buildvars = [['CC'], # replace
| 14 |
['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS',
| 15 |
'LIBPATH', 'LINKFLAGS']] # append
| 16 |
vars = [
| 17 |
['install',
| 18 |
['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'],
| 19 |
| 20 |
['code',
| 21 |
[], # replace
| 22 |
[ # append
| 23 |
'RAD_COMPAT', # currently obsolete
| 24 |
'RAD_MATHCOMPAT', # erf.c floating point error function
| 25 |
'RAD_ARGSCOMPAT', # fixargv0.c for Windows
| 26 |
'RAD_NETCOMPAT', # [win_]netproc.c for ranimate
| 27 |
'RAD_MLIB', # usually 'm', or any fastlib available
| 28 |
'RAD_SOCKETLIB', # ws_2_32 on Windows (VC links it automatically)
| 29 |
'RAD_PROCESS', # our process abstraction and win_popen()
| 30 |
'RAD_PCALLS', # more custom process abstraction
| 31 |
| 32 |
| 33 |
if args.get('RAD_DEBUG',0):
| 34 |
vars.insert(0, ['debug'] + buildvars)
| 35 |
else: vars.insert(0, ['build'] + buildvars)
| 36 |
for section in vars:
| 37 |
if cfig.has_section(section[0]):
| 38 |
for p in section[1]: # single items to replace
| 39 |
try: v = cfig.get(section[0], p)
| 40 |
except ConfigParser.NoOptionError: continue
| 41 |
env[p] = v
| 42 |
#print '%s: %s' % (p, env[p])
| 43 |
for p in section[2]: # multiple items to append
| 44 |
| 45 |
| 46 |
apply(env.Append,[],{p:env.Split(v)})
| 47 |
# XXX Check that basedir exists.
| 48 |
for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']:
| 49 |
if (env.has_key('RAD_BASEDIR') and env.has_key(k)
| 50 |
and not os.path.isabs(env[k])):
| 51 |
env[k] = os.path.join(env['RAD_BASEDIR'],env[k])
| 52 |
| 53 |
| 54 |
def load_plat(env, args, platform=None):
| 55 |
if platform == None: # override
| 56 |
p = sys.platform
| 57 |
else: p = platform
| 58 |
if p == 'win32' and 'gcc' in env['TOOLS']:
| 59 |
# we don't really want to know this here...
| 60 |
p = 'mingw'
| 61 |
pl = []
| 62 |
print 'Detected platform "%s" (%s).' % (sys.platform, os.name)
| 63 |
for i in [len(p), -1, -2]:
| 64 |
pfn = os.path.join(_platdir, p[:i] + '_custom.cfg')
| 65 |
if os.path.isfile(pfn):
| 66 |
print 'Reading configuration "%s"' % pfn
| 67 |
read_plat(env, args, pfn)
| 68 |
return 1
| 69 |
pfn = os.path.join(_platdir, p[:i] + '.cfg')
| 70 |
| 71 |
| 72 |
| 73 |
return 1
| 74 |
| 75 |
if os.name == 'posix':
| 76 |
pfn = os.path.join(_platdir, 'posix.cfg')
| 77 |
| 78 |
print 'Reading generic configuration "%s".' % pfn
| 79 |
| 80 |
return 1
| 81 |
| 82 |
print 'Platform "%s/%s" not supported yet' % (os.name, sys.platform)
| 83 |
sys.exit(2)
| 84 |
| 85 |
| 86 |
