root/radiance/build_utils/find_libs.py
Thu Oct 22 21:16:05 2009 UTC (16 years ago) by schorsch
Changes since 1.4: +9 -0 lines
Diff to previous 1.4
SCons now checks for installed auxiliary support files.
Tue Dec 23 15:03:59 2008 UTC (16 years, 10 months ago) by schorsch
Changes since 1.3: +28 -8 lines
Diff to previous 1.3
Thu Oct 21 15:47:12 2004 UTC (21 years ago) by schorsch
Changes since 1.2: +19 -14 lines
Diff to previous 1.2
SCons build simplifications.
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 4 12:08:47 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 1.1: +12 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (22 years ago) by schorsch
Links to HEAD: (view) (download) (as text) (annotate) Links to rad4R0: (view) (download) (as text) (annotate)
