| 1 | schorsch | 1.1 | import os |
| 2 |  |  |  |
| 3 |  |  | from SCons.SConf import SConf # aka Configure |
| 4 |  |  |  |
| 5 |  |  | def find_x11(env): |
| 6 |  |  | # Search for libX11, remember the X11 library and include dirs |
| 7 |  |  | for d in ('/usr/X11R6', '/usr/X11', '/usr/openwin'): |
| 8 |  |  | if os.path.isdir (d): |
| 9 |  |  | incdir = os.path.join(d, 'include') |
| 10 |  |  | libdir = os.path.join(d, 'lib') |
| 11 |  |  | env.Append(CPPPATH=[incdir]) # add temporarily |
| 12 |  |  | env.Append(LIBPATH=[libdir]) |
| 13 |  |  | conf = SConf(env) |
| 14 |  |  | if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0): |
| 15 |  |  | env.Replace(X11INCLUDE=incdir) |
| 16 |  |  | env.Replace(X11LIB=libdir) |
| 17 |  |  | env['CPPPATH'].remove(incdir) # not needed for now |
| 18 |  |  | env['LIBPATH'].remove(libdir) |
| 19 |  |  | if env['X11INCLUDE']: |
| 20 |  |  | # Check for SGI stereo extension |
| 21 |  |  | if conf.CheckCHeader('X11/extensions/SGIStereo.h'): |
| 22 |  |  | env['RAD_STEREO'] = '-DSTEREO' |
| 23 |  |  | else: env['RAD_STEREO'] = '-DNOSTEREO' |
| 24 |  |  | env = conf.Finish () |
| 25 |  |  | break |
| 26 |  |  | env = conf.Finish () |
| 27 |  |  |  |
| 28 | schorsch | 1.3 |  |
| 29 | schorsch | 1.1 | def find_gl(env): |
| 30 |  |  | # Check for libGL, set flag |
| 31 | schorsch | 1.3 | dl = [(None,None)] # standard search path |
| 32 |  |  | if env.has_key('X11INCLUDE'): # sometimes found there (Darwin) |
| 33 |  |  | dl.append((env['X11INCLUDE'], env['X11LIB'])) |
| 34 |  |  | #if os.name == 'nt': |
| 35 |  |  | #       dl.append((some win specific dirs)) |
| 36 |  |  | #if some other weirdness: |
| 37 |  |  | #       ... |
| 38 |  |  | for incdir, libdir in dl: |
| 39 |  |  | if incdir: env.Append(CPPPATH=[incdir]) # add temporarily |
| 40 |  |  | if libdir: env.Append(LIBPATH=[libdir]) |
| 41 |  |  | conf = SConf(env) |
| 42 | schorsch | 1.2 | if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0): |
| 43 |  |  | env['OGL'] = 1 |
| 44 |  |  | if incdir: env['CPPPATH'].remove(incdir) # not needed for now |
| 45 | schorsch | 1.3 | if libdir: env['LIBPATH'].remove(libdir) |
| 46 |  |  | if env.has_key('OGL'): |
| 47 |  |  | if incdir: env.Replace(OGLINCLUDE=[incdir]) |
| 48 |  |  | #if libdir: env.Replace(OGLLIB=[libdir]) |
| 49 |  |  | conf.Finish() |
| 50 |  |  | break |
| 51 |  |  | conf.Finish() |
| 52 | schorsch | 1.1 |  |
