root/radiance/SConstruct
Revision: 1.4
Committed: Thu Oct 21 15:47:11 2004 UTC (21 years ago) by schorsch
Changes since 1.3: +12 -5 lines
SCons build simplifications.
# User Rev Content
1 schorsch 1.1
2     import os
3     import sys
4     import string
5
6     OPTFILE = 'rayopts.py'
7 schorsch 1.4 SourceSignatures('timestamp')
8 schorsch 1.1 def set_opts(env):
9     # XXX add some caching
10     opts = Options(OPTFILE, ARGUMENTS)
11     opts.Add('SKIP', 'Skip Display of License terms', 0)
12     opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
13     opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
14     opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
15 schorsch 1.2 opts.Add('RAD_DEBUG', 'Build a debug version', 0)
16 schorsch 1.1 opts.Update(env)
17     opts.Save(OPTFILE, env)
18     Help(opts.GenerateHelpText(env, sort=cmp))
19     # where stuff is located in the source tree
20     env['RAD_BUILDLIB'] = '#src/lib'
21     env['RAD_BUILDBIN'] = '#bin'
22     env['RAD_BUILDRLIB'] = '#lib'
23     env['RAD_BUILDMAN'] = '#doc/man'
24
25     def allplats_setup(env):
26     from build_utils import find_libs
27     find_libs.find_x11(env)
28     find_libs.find_gl(env) # OpenGL
29     #find_libs.find_pixar(env) # PIXAR_LIB for src/px/ra_pixar.c
30
31     def post_common_setup(env):
32     env.Append(CPPPATH = [os.path.join('#src', 'common')])
33     env.Append(LIBPATH=['../lib']) # our own libs
34     if not env.has_key('RAD_MLIB'):
35     env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
36
37     def shareinstall_setup(env):
38     from build_utils import install
39     # only scan for those files when we actually need them
40     if 'install' in sys.argv or 'rlibinstall' in sys.argv:
41     install.install_rlibfiles(env)
42     if 'install' in sys.argv or 'maninstall' in sys.argv:
43     install.install_manfiles(env)
44
45     # Set up build environment
46     env = Environment()
47
48 schorsch 1.4 if os.name == 'posix':
49     from build_utils import install
50     csh_b = Builder(action = install.install_cshscript,
51     suffix = '', src_suffix = '.csh')
52     env.Append(BUILDERS={'InstallCsh': csh_b})
53
54 schorsch 1.1 # configure platform-specific stuff
55     from build_utils import load_plat
56 schorsch 1.2 load_plat.load_plat(env, ARGUMENTS, platform=None)
57 schorsch 1.1
58     # override options
59     set_opts(env)
60
61     # accept license
62     if not env['SKIP'] and not '-c' in sys.argv:
63     from build_utils import copyright
64     copyright.show_license()
65
66     # fill in generic config
67     allplats_setup(env)
68
69 schorsch 1.4
70
71 schorsch 1.1 # Bring in all the actual things to build
72     Export('env')
73     SConscript(os.path.join('src', 'common', 'SConscript'))
74     post_common_setup(env)
75     for d in Split('meta cv gen ot rt px hd util cal'):
76 schorsch 1.3 print d
77 schorsch 1.1 SConscript(os.path.join('src', d, 'SConscript'))
78
79     if string.find(string.join(sys.argv[1:]), 'install') > -1:
80     shareinstall_setup(env)
81
82     # virtual targets
83 schorsch 1.4 env.Alias('bininstall', '$RAD_BINDIR')
84     env.Alias('rlibinstall', '$RAD_RLIBDIR')
85     env.Alias('maninstall', '$RAD_MANDIR')
86 schorsch 1.1
87     env.Alias('build', ['#bin'])
88     env.Alias('test', ['#src/test'])
89     env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
90
91     # Further virtual targets are defined locally:
92 schorsch 1.3 # meta_special: mt1601 okimate imagew mt160 mx80 impress aed5
93     # tcurve tscat tbar mtext libt4014.a plotout t4014
94     # px_special: ra_im, t4027, paintjet, mt160t, greyscale, colorscale, d48c
95     # util_special: scanner, makedist (not for Windows yet)
96     env.Alias('special', ['meta_special', 'px_special', 'util_special'])
97     env.Alias('special_install', ['meta_special_install',
98     'px_special_install', 'util_special_install'])
99 schorsch 1.1
