root/radiance/InstallRules/GetPrerequisites.cmake
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 11 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad5R1, rad4R2, rad4R1, rad5R0
Added qt interface for rvu and cmake files from Bill Hoffman
# User Rev Content
1 greg 1.1 # - Functions to analyze and list executable file prerequisites.
2     # This module provides functions to list the .dll, .dylib or .so
3     # files that an executable or shared library file depends on. (Its
4     # prerequisites.)
5     #
6     # It uses various tools to obtain the list of required shared library files:
7     # dumpbin (Windows)
8     # ldd (Linux/Unix)
9     # otool (Mac OSX)
10     # The following functions are provided by this module:
11     # get_prerequisites
12     # list_prerequisites
13     # list_prerequisites_by_glob
14     # gp_append_unique
15     # is_file_executable
16     # gp_item_default_embedded_path
17     # (projects can override with gp_item_default_embedded_path_override)
18     # gp_resolve_item
19     # (projects can override with gp_resolve_item_override)
20     # gp_resolved_file_type
21     # (projects can override with gp_resolved_file_type_override)
22     # gp_file_type
23     # Requires CMake 2.6 or greater because it uses function, break, return and
24     # PARENT_SCOPE.
25     #
26     # GET_PREREQUISITES(<target> <prerequisites_var> <exclude_system> <recurse>
27     # <dirs>)
28     # Get the list of shared library files required by <target>. The list in
29     # the variable named <prerequisites_var> should be empty on first entry to
30     # this function. On exit, <prerequisites_var> will contain the list of
31     # required shared library files.
32     #
33     # <target> is the full path to an executable file. <prerequisites_var> is the
34     # name of a CMake variable to contain the results. <exclude_system> must be 0
35     # or 1 indicating whether to include or exclude "system" prerequisites. If
36     # <recurse> is set to 1 all prerequisites will be found recursively, if set to
37     # 0 only direct prerequisites are listed. <exepath> is the path to the top
38     # level executable used for @executable_path replacment on the Mac. <dirs> is
39     # a list of paths where libraries might be found: these paths are searched
40     # first when a target without any path info is given. Then standard system
41     # locations are also searched: PATH, Framework locations, /usr/lib...
42     #
43     # LIST_PREREQUISITES(<target> [<recurse> [<exclude_system> [<verbose>]]])
44     # Print a message listing the prerequisites of <target>.
45     #
46     # <target> is the name of a shared library or executable target or the full
47     # path to a shared library or executable file. If <recurse> is set to 1 all
48     # prerequisites will be found recursively, if set to 0 only direct
49     # prerequisites are listed. <exclude_system> must be 0 or 1 indicating whether
50     # to include or exclude "system" prerequisites. With <verbose> set to 0 only
51     # the full path names of the prerequisites are printed, set to 1 extra
52     # informatin will be displayed.
53     #
54     # LIST_PREREQUISITES_BY_GLOB(<glob_arg> <glob_exp>)
55     # Print the prerequisites of shared library and executable files matching a
56     # globbing pattern. <glob_arg> is GLOB or GLOB_RECURSE and <glob_exp> is a
57     # globbing expression used with "file(GLOB" or "file(GLOB_RECURSE" to retrieve
58     # a list of matching files. If a matching file is executable, its prerequisites
59     # are listed.
60     #
61     # Any additional (optional) arguments provided are passed along as the
62     # optional arguments to the list_prerequisites calls.
63     #
64     # GP_APPEND_UNIQUE(<list_var> <value>)
65     # Append <value> to the list variable <list_var> only if the value is not
66     # already in the list.
67     #
68     # IS_FILE_EXECUTABLE(<file> <result_var>)
69     # Return 1 in <result_var> if <file> is a binary executable, 0 otherwise.
70     #
71     # GP_ITEM_DEFAULT_EMBEDDED_PATH(<item> <default_embedded_path_var>)
72     # Return the path that others should refer to the item by when the item
73     # is embedded inside a bundle.
74     #
75     # Override on a per-project basis by providing a project-specific
76     # gp_item_default_embedded_path_override function.
77     #
78     # GP_RESOLVE_ITEM(<context> <item> <exepath> <dirs> <resolved_item_var>)
79     # Resolve an item into an existing full path file.
80     #
81     # Override on a per-project basis by providing a project-specific
82     # gp_resolve_item_override function.
83     #
84     # GP_RESOLVED_FILE_TYPE(<original_file> <file> <exepath> <dirs> <type_var>)
85     # Return the type of <file> with respect to <original_file>. String
86     # describing type of prerequisite is returned in variable named <type_var>.
87     #
88     # Use <exepath> and <dirs> if necessary to resolve non-absolute <file>
89     # values -- but only for non-embedded items.
90     #
91     # Possible types are:
92     # system
93     # local
94     # embedded
95     # other
96     # Override on a per-project basis by providing a project-specific
97     # gp_resolved_file_type_override function.
98     #
99     # GP_FILE_TYPE(<original_file> <file> <type_var>)
100     # Return the type of <file> with respect to <original_file>. String
101     # describing type of prerequisite is returned in variable named <type_var>.
102     #
103     # Possible types are:
104     # system
105     # local
106     # embedded
107     # other
108
109     #=============================================================================
110     # Copyright 2008-2009 Kitware, Inc.
111     #
112     # Distributed under the OSI-approved BSD License (the "License");
113     # see accompanying file Copyright.txt for details.
114     #
115     # This software is distributed WITHOUT ANY WARRANTY; without even the
116     # implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
117     # See the License for more information.
118     #=============================================================================
119     # (To distribute this file outside of CMake, substitute the full
120     # License text for the above reference.)
121
122     function(gp_append_unique list_var value)
123     set(contains 0)
124
125     foreach(item ${${list_var}})
126     if("${item}" STREQUAL "${value}")
127     set(contains 1)
128     break()
129     endif("${item}" STREQUAL "${value}")
130     endforeach(item)
131
132     if(NOT contains)
133     set(${list_var} ${${list_var}} "${value}" PARENT_SCOPE)
134     endif(NOT contains)
135     endfunction(gp_append_unique)
136
137
138     function(is_file_executable file result_var)
139     #
140     # A file is not executable until proven otherwise:
141     #
142     set(${result_var} 0 PARENT_SCOPE)
143
144     get_filename_component(file_full "${file}" ABSOLUTE)
145     string(TOLOWER "${file_full}" file_full_lower)
146
147     # If file name ends in .exe on Windows, *assume* executable:
148     #
149     if(WIN32 AND NOT UNIX)
150     if("${file_full_lower}" MATCHES "\\.exe$")
151     set(${result_var} 1 PARENT_SCOPE)
152     return()
153     endif("${file_full_lower}" MATCHES "\\.exe$")
154
155     # A clause could be added here that uses output or return value of dumpbin
156     # to determine ${result_var}. In 99%+? practical cases, the exe name
157     # match will be sufficient...
158     #
159     endif(WIN32 AND NOT UNIX)
160
161     # Use the information returned from the Unix shell command "file" to
162     # determine if ${file_full} should be considered an executable file...
163     #
164     # If the file command's output contains "executable" and does *not* contain
165     # "text" then it is likely an executable suitable for prerequisite analysis
166     # via the get_prerequisites macro.
167     #
168     if(UNIX)
169     if(NOT file_cmd)
170     find_program(file_cmd "file")
171     endif(NOT file_cmd)
172
173     if(file_cmd)
174     execute_process(COMMAND "${file_cmd}" "${file_full}"
175     OUTPUT_VARIABLE file_ov
176     OUTPUT_STRIP_TRAILING_WHITESPACE
177     )
178
179     # Replace the name of the file in the output with a placeholder token
180     # (the string " _file_full_ ") so that just in case the path name of
181     # the file contains the word "text" or "executable" we are not fooled
182     # into thinking "the wrong thing" because the file name matches the
183     # other 'file' command output we are looking for...
184     #
185     string(REPLACE "${file_full}" " _file_full_ " file_ov "${file_ov}")
186     string(TOLOWER "${file_ov}" file_ov)
187
188     #message(STATUS "file_ov='${file_ov}'")
189     if("${file_ov}" MATCHES "executable")
190     #message(STATUS "executable!")
191     if("${file_ov}" MATCHES "text")
192     #message(STATUS "but text, so *not* a binary executable!")
193     else("${file_ov}" MATCHES "text")
194     set(${result_var} 1 PARENT_SCOPE)
195     return()
196     endif("${file_ov}" MATCHES "text")
197     endif("${file_ov}" MATCHES "executable")
198     else(file_cmd)
199     message(STATUS "warning: No 'file' command, skipping execute_process...")
200     endif(file_cmd)
201     endif(UNIX)
202     endfunction(is_file_executable)
203
204
205     function(gp_item_default_embedded_path item default_embedded_path_var)
206
207     # On Windows and Linux, "embed" prerequisites in the same directory
208     # as the executable by default:
209     #
210     set(path "@executable_path")
211     set(overridden 0)
212
213     # On the Mac, relative to the executable depending on the type
214     # of the thing we are embedding:
215     #
216     if(APPLE)
217     #
218     # The assumption here is that all executables in the bundle will be
219     # in same-level-directories inside the bundle. The parent directory
220     # of an executable inside the bundle should be MacOS or a sibling of
221     # MacOS and all embedded paths returned from here will begin with
222     # "@executable_path/../" and will work from all executables in all
223     # such same-level-directories inside the bundle.
224     #
225
226     # By default, embed things right next to the main bundle executable:
227     #
228     set(path "@executable_path/../../Contents/MacOS")
229
230     # Embed .dylibs right next to the main bundle executable:
231     #
232     if(item MATCHES "\\.dylib$")
233     set(path "@executable_path/../MacOS")
234     set(overridden 1)
235     endif(item MATCHES "\\.dylib$")
236
237     # Embed frameworks in the embedded "Frameworks" directory (sibling of MacOS):
238     #
239     if(NOT overridden)
240     if(item MATCHES "[^/]+\\.framework/")
241     set(path "@executable_path/../Frameworks")
242     set(overridden 1)
243     endif(item MATCHES "[^/]+\\.framework/")
244     endif(NOT overridden)
245     endif()
246
247     # Provide a hook so that projects can override the default embedded location
248     # of any given library by whatever logic they choose:
249     #
250     if(COMMAND gp_item_default_embedded_path_override)
251     gp_item_default_embedded_path_override("${item}" path)
252     endif(COMMAND gp_item_default_embedded_path_override)
253
254     set(${default_embedded_path_var} "${path}" PARENT_SCOPE)
255     endfunction(gp_item_default_embedded_path)
256
257
258     function(gp_resolve_item context item exepath dirs resolved_item_var)
259     set(resolved 0)
260     set(resolved_item "${item}")
261
262     # Is it already resolved?
263     #
264     if(IS_ABSOLUTE "${resolved_item}" AND EXISTS "${resolved_item}")
265     set(resolved 1)
266     endif(IS_ABSOLUTE "${resolved_item}" AND EXISTS "${resolved_item}")
267
268     if(NOT resolved)
269     if(item MATCHES "@executable_path")
270     #
271     # @executable_path references are assumed relative to exepath
272     #
273     string(REPLACE "@executable_path" "${exepath}" ri "${item}")
274     get_filename_component(ri "${ri}" ABSOLUTE)
275
276     if(EXISTS "${ri}")
277     #message(STATUS "info: embedded item exists (${ri})")
278     set(resolved 1)
279     set(resolved_item "${ri}")
280     else(EXISTS "${ri}")
281     message(STATUS "warning: embedded item does not exist '${ri}'")
282     endif(EXISTS "${ri}")
283     endif(item MATCHES "@executable_path")
284     endif(NOT resolved)
285
286     if(NOT resolved)
287     if(item MATCHES "@loader_path")
288     #
289     # @loader_path references are assumed relative to the
290     # PATH of the given "context" (presumably another library)
291     #
292     get_filename_component(contextpath "${context}" PATH)
293     string(REPLACE "@loader_path" "${contextpath}" ri "${item}")
294     get_filename_component(ri "${ri}" ABSOLUTE)
295
296     if(EXISTS "${ri}")
297     #message(STATUS "info: embedded item exists (${ri})")
298     set(resolved 1)
299     set(resolved_item "${ri}")
300     else(EXISTS "${ri}")
301     message(STATUS "warning: embedded item does not exist '${ri}'")
302     endif(EXISTS "${ri}")
303     endif(item MATCHES "@loader_path")
304     endif(NOT resolved)
305
306     if(NOT resolved)
307     set(ri "ri-NOTFOUND")
308     find_file(ri "${item}" ${exepath} ${dirs} NO_DEFAULT_PATH)
309     find_file(ri "${item}" ${exepath} ${dirs} /usr/lib)
310     if(ri)
311     #message(STATUS "info: 'find_file' in exepath/dirs (${ri})")
312     set(resolved 1)
313     set(resolved_item "${ri}")
314     set(ri "ri-NOTFOUND")
315     endif(ri)
316     endif(NOT resolved)
317
318     if(NOT resolved)
319     if(item MATCHES "[^/]+\\.framework/")
320     set(fw "fw-NOTFOUND")
321     find_file(fw "${item}"
322     "~/Library/Frameworks"
323     "/Library/Frameworks"
324     "/System/Library/Frameworks"
325     )
326     if(fw)
327     #message(STATUS "info: 'find_file' found framework (${fw})")
328     set(resolved 1)
329     set(resolved_item "${fw}")
330     set(fw "fw-NOTFOUND")
331     endif(fw)
332     endif(item MATCHES "[^/]+\\.framework/")
333     endif(NOT resolved)
334
335     # Using find_program on Windows will find dll files that are in the PATH.
336     # (Converting simple file names into full path names if found.)
337     #
338     if(WIN32 AND NOT UNIX)
339     if(NOT resolved)
340     set(ri "ri-NOTFOUND")
341     find_program(ri "${item}" PATHS "${exepath};${dirs}" NO_DEFAULT_PATH)
342     find_program(ri "${item}" PATHS "${exepath};${dirs}")
343     if(ri)
344     #message(STATUS "info: 'find_program' in exepath/dirs (${ri})")
345     set(resolved 1)
346     set(resolved_item "${ri}")
347     set(ri "ri-NOTFOUND")
348     endif(ri)
349     endif(NOT resolved)
350     endif(WIN32 AND NOT UNIX)
351
352     # Provide a hook so that projects can override item resolution
353     # by whatever logic they choose:
354     #
355     if(COMMAND gp_resolve_item_override)
356     gp_resolve_item_override("${context}" "${item}" "${exepath}" "${dirs}" resolved_item resolved)
357     endif(COMMAND gp_resolve_item_override)
358
359     if(NOT resolved)
360     message(STATUS "
361     warning: cannot resolve item '${item}'
362
363     possible problems:
364     need more directories?
365     need to use InstallRequiredSystemLibraries?
366     run in install tree instead of build tree?
367     ")
368     # message(STATUS "
369     #******************************************************************************
370     #warning: cannot resolve item '${item}'
371     #
372     # possible problems:
373     # need more directories?
374     # need to use InstallRequiredSystemLibraries?
375     # run in install tree instead of build tree?
376     #
377     # context='${context}'
378     # item='${item}'
379     # exepath='${exepath}'
380     # dirs='${dirs}'
381     # resolved_item_var='${resolved_item_var}'
382     #******************************************************************************
383     #")
384     endif(NOT resolved)
385
386     set(${resolved_item_var} "${resolved_item}" PARENT_SCOPE)
387     endfunction(gp_resolve_item)
388
389
390     function(gp_resolved_file_type original_file file exepath dirs type_var)
391     #message(STATUS "**")
392
393     if(NOT IS_ABSOLUTE "${original_file}")
394     message(STATUS "warning: gp_resolved_file_type expects absolute full path for first arg original_file")
395     endif()
396
397     set(is_embedded 0)
398     set(is_local 0)
399     set(is_system 0)
400
401     set(resolved_file "${file}")
402
403     if("${file}" MATCHES "^@(executable|loader)_path")
404     set(is_embedded 1)
405     endif()
406
407     if(NOT is_embedded)
408     if(NOT IS_ABSOLUTE "${file}")
409     gp_resolve_item("${original_file}" "${file}" "${exepath}" "${dirs}" resolved_file)
410     endif()
411
412     string(TOLOWER "${original_file}" original_lower)
413     string(TOLOWER "${resolved_file}" lower)
414
415     if(UNIX)
416     if(resolved_file MATCHES "^(/lib/|/lib32/|/lib64/|/usr/lib/|/usr/lib32/|/usr/lib64/|/usr/X11R6/|/usr/bin/)")
417     set(is_system 1)
418     endif()
419     endif()
420
421     if(APPLE)
422     if(resolved_file MATCHES "^(/System/Library/|/usr/lib/)")
423     set(is_system 1)
424     endif()
425     endif()
426
427     if(WIN32)
428     string(TOLOWER "$ENV{SystemRoot}" sysroot)
429     string(REGEX REPLACE "\\\\" "/" sysroot "${sysroot}")
430
431     string(TOLOWER "$ENV{windir}" windir)
432     string(REGEX REPLACE "\\\\" "/" windir "${windir}")
433
434     if(lower MATCHES "^(${sysroot}/sys(tem|wow)|${windir}/sys(tem|wow)|(.*/)*msvc[^/]+dll)")
435     set(is_system 1)
436     endif()
437
438     if(UNIX)
439     # if cygwin, we can get the properly formed windows paths from cygpath
440     find_program(CYGPATH_EXECUTABLE cygpath)
441
442     if(CYGPATH_EXECUTABLE)
443     execute_process(COMMAND ${CYGPATH_EXECUTABLE} -W
444     OUTPUT_VARIABLE env_windir
445     OUTPUT_STRIP_TRAILING_WHITESPACE)
446     execute_process(COMMAND ${CYGPATH_EXECUTABLE} -S
447     OUTPUT_VARIABLE env_sysdir
448     OUTPUT_STRIP_TRAILING_WHITESPACE)
449     string(TOLOWER "${env_windir}" windir)
450     string(TOLOWER "${env_sysdir}" sysroot)
451
452     if(lower MATCHES "^(${sysroot}/sys(tem|wow)|${windir}/sys(tem|wow)|(.*/)*msvc[^/]+dll)")
453     set(is_system 1)
454     endif()
455     endif(CYGPATH_EXECUTABLE)
456     endif(UNIX)
457     endif(WIN32)
458
459     if(NOT is_system)
460     get_filename_component(original_path "${original_lower}" PATH)
461     get_filename_component(path "${lower}" PATH)
462     if("${original_path}" STREQUAL "${path}")
463     set(is_local 1)
464     endif()
465     endif()
466     endif()
467
468     # Return type string based on computed booleans:
469     #
470     set(type "other")
471
472     if(is_system)
473     set(type "system")
474     elseif(is_embedded)
475     set(type "embedded")
476     elseif(is_local)
477     set(type "local")
478     endif()
479
480     #message(STATUS "gp_resolved_file_type: '${file}' '${resolved_file}'")
481     #message(STATUS " type: '${type}'")
482
483     if(NOT is_embedded)
484     if(NOT IS_ABSOLUTE "${resolved_file}")
485     if(lower MATCHES "^msvc[^/]+dll" AND is_system)
486     message(STATUS "info: non-absolute msvc file '${file}' returning type '${type}'")
487     else()
488     message(STATUS "warning: gp_resolved_file_type non-absolute file '${file}' returning type '${type}' -- possibly incorrect")
489     endif()
490     endif()
491     endif()
492
493     # Provide a hook so that projects can override the decision on whether a
494     # library belongs to the system or not by whatever logic they choose:
495     #
496     if(COMMAND gp_resolved_file_type_override)
497     gp_resolved_file_type_override("${resolved_file}" type)
498     endif()
499
500     set(${type_var} "${type}" PARENT_SCOPE)
501
502     #message(STATUS "**")
503     endfunction()
504
505
506     function(gp_file_type original_file file type_var)
507     if(NOT IS_ABSOLUTE "${original_file}")
508     message(STATUS "warning: gp_file_type expects absolute full path for first arg original_file")
509     endif()
510
511     get_filename_component(exepath "${original_file}" PATH)
512
513     set(type "")
514     gp_resolved_file_type("${original_file}" "${file}" "${exepath}" "" type)
515
516     set(${type_var} "${type}" PARENT_SCOPE)
517     endfunction(gp_file_type)
518
519
520     function(get_prerequisites target prerequisites_var exclude_system recurse exepath dirs)
521     set(verbose 0)
522     set(eol_char "E")
523
524     if(NOT IS_ABSOLUTE "${target}")
525     message("warning: target '${target}' is not absolute...")
526     endif(NOT IS_ABSOLUTE "${target}")
527
528     if(NOT EXISTS "${target}")
529     message("warning: target '${target}' does not exist...")
530     endif(NOT EXISTS "${target}")
531
532     # <setup-gp_tool-vars>
533     #
534     # Try to choose the right tool by default. Caller can set gp_tool prior to
535     # calling this function to force using a different tool.
536     #
537     if("${gp_tool}" STREQUAL "")
538     set(gp_tool "ldd")
539     if(APPLE)
540     set(gp_tool "otool")
541     endif(APPLE)
542     if(WIN32 AND NOT UNIX) # This is how to check for cygwin, har!
543     set(gp_tool "dumpbin")
544     endif(WIN32 AND NOT UNIX)
545     endif("${gp_tool}" STREQUAL "")
546
547     set(gp_tool_known 0)
548
549     if("${gp_tool}" STREQUAL "ldd")
550     set(gp_cmd_args "")
551     set(gp_regex "^[\t ]*[^\t ]+ => ([^\t\(]+) .*${eol_char}$")
552     set(gp_regex_error "not found${eol_char}$")
553     set(gp_regex_fallback "^[\t ]*([^\t ]+) => ([^\t ]+).*${eol_char}$")
554     set(gp_regex_cmp_count 1)
555     set(gp_tool_known 1)
556     endif("${gp_tool}" STREQUAL "ldd")
557
558     if("${gp_tool}" STREQUAL "otool")
559     set(gp_cmd_args "-L")
560     set(gp_regex "^\t([^\t]+) \\(compatibility version ([0-9]+.[0-9]+.[0-9]+), current version ([0-9]+.[0-9]+.[0-9]+)\\)${eol_char}$")
561     set(gp_regex_error "")
562     set(gp_regex_fallback "")
563     set(gp_regex_cmp_count 3)
564     set(gp_tool_known 1)
565     endif("${gp_tool}" STREQUAL "otool")
566
567     if("${gp_tool}" STREQUAL "dumpbin")
568     set(gp_cmd_args "/dependents")
569     set(gp_regex "^ ([^ ].*[Dd][Ll][Ll])${eol_char}$")
570     set(gp_regex_error "")
571     set(gp_regex_fallback "")
572     set(gp_regex_cmp_count 1)
573     set(gp_tool_known 1)
574     set(ENV{VS_UNICODE_OUTPUT} "") # Block extra output from inside VS IDE.
575     endif("${gp_tool}" STREQUAL "dumpbin")
576
577     if(NOT gp_tool_known)
578     message(STATUS "warning: gp_tool='${gp_tool}' is an unknown tool...")
579     message(STATUS "CMake function get_prerequisites needs more code to handle '${gp_tool}'")
580     message(STATUS "Valid gp_tool values are dumpbin, ldd and otool.")
581     return()
582     endif(NOT gp_tool_known)
583
584     set(gp_cmd_paths ${gp_cmd_paths}
585     "C:/Program Files/Microsoft Visual Studio 9.0/VC/bin"
586     "C:/Program Files (x86)/Microsoft Visual Studio 9.0/VC/bin"
587     "C:/Program Files/Microsoft Visual Studio 8/VC/BIN"
588     "C:/Program Files (x86)/Microsoft Visual Studio 8/VC/BIN"
589     "C:/Program Files/Microsoft Visual Studio .NET 2003/VC7/BIN"
590     "C:/Program Files (x86)/Microsoft Visual Studio .NET 2003/VC7/BIN"
591     "/usr/local/bin"
592     "/usr/bin"
593     )
594
595     find_program(gp_cmd ${gp_tool} PATHS ${gp_cmd_paths})
596
597     if(NOT gp_cmd)
598     message(STATUS "warning: could not find '${gp_tool}' - cannot analyze prerequisites...")
599     return()
600     endif(NOT gp_cmd)
601
602     if("${gp_tool}" STREQUAL "dumpbin")
603     # When running dumpbin, it also needs the "Common7/IDE" directory in the
604     # PATH. It will already be in the PATH if being run from a Visual Studio
605     # command prompt. Add it to the PATH here in case we are running from a
606     # different command prompt.
607     #
608     get_filename_component(gp_cmd_dir "${gp_cmd}" PATH)
609     get_filename_component(gp_cmd_dlls_dir "${gp_cmd_dir}/../../Common7/IDE" ABSOLUTE)
610     # Use cmake paths as a user may have a PATH element ending with a backslash.
611     # This will escape the list delimiter and create havoc!
612     if(EXISTS "${gp_cmd_dlls_dir}")
613     # only add to the path if it is not already in the path
614     set(gp_found_cmd_dlls_dir 0)
615     file(TO_CMAKE_PATH "$ENV{PATH}" env_path)
616     foreach(gp_env_path_element ${env_path})
617     if("${gp_env_path_element}" STREQUAL "${gp_cmd_dlls_dir}")
618     set(gp_found_cmd_dlls_dir 1)
619     endif()
620     endforeach(gp_env_path_element)
621
622     if(NOT gp_found_cmd_dlls_dir)
623     file(TO_NATIVE_PATH "${gp_cmd_dlls_dir}" gp_cmd_dlls_dir)
624     set(ENV{PATH} "$ENV{PATH};${gp_cmd_dlls_dir}")
625     endif()
626     endif(EXISTS "${gp_cmd_dlls_dir}")
627     endif("${gp_tool}" STREQUAL "dumpbin")
628     #
629     # </setup-gp_tool-vars>
630
631     if("${gp_tool}" STREQUAL "ldd")
632     set(old_ld_env "$ENV{LD_LIBRARY_PATH}")
633     foreach(dir ${exepath} ${dirs})
634     set(ENV{LD_LIBRARY_PATH} "${dir}:$ENV{LD_LIBRARY_PATH}")
635     endforeach(dir)
636     endif("${gp_tool}" STREQUAL "ldd")
637
638
639     # Track new prerequisites at each new level of recursion. Start with an
640     # empty list at each level:
641     #
642     set(unseen_prereqs)
643
644     # Run gp_cmd on the target:
645     #
646     execute_process(
647     COMMAND ${gp_cmd} ${gp_cmd_args} ${target}
648     OUTPUT_VARIABLE gp_cmd_ov
649     )
650
651     if("${gp_tool}" STREQUAL "ldd")
652     set(ENV{LD_LIBRARY_PATH} "${old_ld_env}")
653     endif("${gp_tool}" STREQUAL "ldd")
654
655     if(verbose)
656     message(STATUS "<RawOutput cmd='${gp_cmd} ${gp_cmd_args} ${target}'>")
657     message(STATUS "gp_cmd_ov='${gp_cmd_ov}'")
658     message(STATUS "</RawOutput>")
659     endif(verbose)
660
661     get_filename_component(target_dir "${target}" PATH)
662
663     # Convert to a list of lines:
664     #
665     string(REGEX REPLACE ";" "\\\\;" candidates "${gp_cmd_ov}")
666     string(REGEX REPLACE "\n" "${eol_char};" candidates "${candidates}")
667
668     # check for install id and remove it from list, since otool -L can include a
669     # reference to itself
670     set(gp_install_id)
671     if("${gp_tool}" STREQUAL "otool")
672     execute_process(
673     COMMAND otool -D ${target}
674     OUTPUT_VARIABLE gp_install_id_ov
675     )
676     # second line is install name
677     string(REGEX REPLACE ".*:\n" "" gp_install_id "${gp_install_id_ov}")
678     if(gp_install_id)
679     # trim
680     string(REGEX MATCH "[^\n ].*[^\n ]" gp_install_id "${gp_install_id}")
681     #message("INSTALL ID is \"${gp_install_id}\"")
682     endif(gp_install_id)
683     endif("${gp_tool}" STREQUAL "otool")
684
685     # Analyze each line for file names that match the regular expression:
686     #
687     foreach(candidate ${candidates})
688     if("${candidate}" MATCHES "${gp_regex}")
689
690     # Extract information from each candidate:
691     if(gp_regex_error AND "${candidate}" MATCHES "${gp_regex_error}")
692     string(REGEX REPLACE "${gp_regex_fallback}" "\\1" raw_item "${candidate}")
693     else(gp_regex_error AND "${candidate}" MATCHES "${gp_regex_error}")
694     string(REGEX REPLACE "${gp_regex}" "\\1" raw_item "${candidate}")
695     endif(gp_regex_error AND "${candidate}" MATCHES "${gp_regex_error}")
696
697     if(gp_regex_cmp_count GREATER 1)
698     string(REGEX REPLACE "${gp_regex}" "\\2" raw_compat_version "${candidate}")
699     string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\1" compat_major_version "${raw_compat_version}")
700     string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\2" compat_minor_version "${raw_compat_version}")
701     string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\3" compat_patch_version "${raw_compat_version}")
702     endif(gp_regex_cmp_count GREATER 1)
703
704     if(gp_regex_cmp_count GREATER 2)
705     string(REGEX REPLACE "${gp_regex}" "\\3" raw_current_version "${candidate}")
706     string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\1" current_major_version "${raw_current_version}")
707     string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\2" current_minor_version "${raw_current_version}")
708     string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\3" current_patch_version "${raw_current_version}")
709     endif(gp_regex_cmp_count GREATER 2)
710
711     # Use the raw_item as the list entries returned by this function. Use the
712     # gp_resolve_item function to resolve it to an actual full path file if
713     # necessary.
714     #
715     set(item "${raw_item}")
716
717     # Add each item unless it is excluded:
718     #
719     set(add_item 1)
720
721     if("${item}" STREQUAL "${gp_install_id}")
722     set(add_item 0)
723     endif("${item}" STREQUAL "${gp_install_id}")
724
725     if(add_item AND ${exclude_system})
726     set(type "")
727     gp_resolved_file_type("${target}" "${item}" "${exepath}" "${dirs}" type)
728
729     if("${type}" STREQUAL "system")
730     set(add_item 0)
731     endif("${type}" STREQUAL "system")
732     endif(add_item AND ${exclude_system})
733
734     if(add_item)
735     list(LENGTH ${prerequisites_var} list_length_before_append)
736     gp_append_unique(${prerequisites_var} "${item}")
737     list(LENGTH ${prerequisites_var} list_length_after_append)
738
739     if(${recurse})
740     # If item was really added, this is the first time we have seen it.
741     # Add it to unseen_prereqs so that we can recursively add *its*
742     # prerequisites...
743     #
744     # But first: resolve its name to an absolute full path name such
745     # that the analysis tools can simply accept it as input.
746     #
747     if(NOT list_length_before_append EQUAL list_length_after_append)
748     gp_resolve_item("${target}" "${item}" "${exepath}" "${dirs}" resolved_item)
749     set(unseen_prereqs ${unseen_prereqs} "${resolved_item}")
750     endif(NOT list_length_before_append EQUAL list_length_after_append)
751     endif(${recurse})
752     endif(add_item)
753     else("${candidate}" MATCHES "${gp_regex}")
754     if(verbose)
755     message(STATUS "ignoring non-matching line: '${candidate}'")
756     endif(verbose)
757     endif("${candidate}" MATCHES "${gp_regex}")
758     endforeach(candidate)
759
760     list(LENGTH ${prerequisites_var} prerequisites_var_length)
761     if(prerequisites_var_length GREATER 0)
762     list(SORT ${prerequisites_var})
763     endif(prerequisites_var_length GREATER 0)
764     if(${recurse})
765     set(more_inputs ${unseen_prereqs})
766     foreach(input ${more_inputs})
767     get_prerequisites("${input}" ${prerequisites_var} ${exclude_system} ${recurse} "${exepath}" "${dirs}")
768     endforeach(input)
769     endif(${recurse})
770
771     set(${prerequisites_var} ${${prerequisites_var}} PARENT_SCOPE)
772     endfunction(get_prerequisites)
773
774
775     function(list_prerequisites target)
776     if("${ARGV1}" STREQUAL "")
777     set(all 1)
778     else("${ARGV1}" STREQUAL "")
779     set(all "${ARGV1}")
780     endif("${ARGV1}" STREQUAL "")
781
782     if("${ARGV2}" STREQUAL "")
783     set(exclude_system 0)
784     else("${ARGV2}" STREQUAL "")
785     set(exclude_system "${ARGV2}")
786     endif("${ARGV2}" STREQUAL "")
787
788     if("${ARGV3}" STREQUAL "")
789     set(verbose 0)
790     else("${ARGV3}" STREQUAL "")
791     set(verbose "${ARGV3}")
792     endif("${ARGV3}" STREQUAL "")
793
794     set(count 0)
795     set(count_str "")
796     set(print_count "${verbose}")
797     set(print_prerequisite_type "${verbose}")
798     set(print_target "${verbose}")
799     set(type_str "")
800
801     get_filename_component(exepath "${target}" PATH)
802
803     set(prereqs "")
804     get_prerequisites("${target}" prereqs ${exclude_system} ${all} "${exepath}" "")
805
806     if(print_target)
807     message(STATUS "File '${target}' depends on:")
808     endif(print_target)
809
810     foreach(d ${prereqs})
811     math(EXPR count "${count} + 1")
812
813     if(print_count)
814     set(count_str "${count}. ")
815     endif(print_count)
816
817     if(print_prerequisite_type)
818     gp_file_type("${target}" "${d}" type)
819     set(type_str " (${type})")
820     endif(print_prerequisite_type)
821
822     message(STATUS "${count_str}${d}${type_str}")
823     endforeach(d)
824     endfunction(list_prerequisites)
825
826
827     function(list_prerequisites_by_glob glob_arg glob_exp)
828     message(STATUS "=============================================================================")
829     message(STATUS "List prerequisites of executables matching ${glob_arg} '${glob_exp}'")
830     message(STATUS "")
831     file(${glob_arg} file_list ${glob_exp})
832     foreach(f ${file_list})
833     is_file_executable("${f}" is_f_executable)
834     if(is_f_executable)
835     message(STATUS "=============================================================================")
836     list_prerequisites("${f}" ${ARGN})
837     message(STATUS "")
838     endif(is_f_executable)
839     endforeach(f)
840     endfunction(list_prerequisites_by_glob)
