root/radiance/INSTALL.scons
Tue Jan 9 00:08:57 2018 UTC (7 years, 9 months ago) by schorsch
Changes since 1.6: +5 -0 lines
Diff to previous 1.6
SCons Option to build Pmap with OOC data on unix
Mon Jan 8 13:38:37 2018 UTC (7 years, 9 months ago) by schorsch
Changes since 1.5: +79 -40 lines
Diff to previous 1.5
Tue Apr 19 21:21:23 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.4: +15 -0 lines
Diff to previous 1.4
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
Thu Mar 10 02:06:11 2016 UTC (9 years, 7 months ago) by schorsch
Diff to previous 1.3
tifflib sources aren't included anymore
Thu Oct 22 21:24:21 2009 UTC (15 years, 11 months ago) by schorsch
Changes since 1.2: +3 -2 lines
Diff to previous 1.2
SCons now checks for installed auxiliary support files.
Thu Oct 22 20:50:27 2009 UTC (15 years, 11 months ago) by schorsch
Changes since 1.1: +4 -4 lines
Diff to previous 1.1
Fixing typos.
Fri Dec 26 17:00:32 2008 UTC (16 years, 9 months ago) by schorsch
Invoke test suite from SCons and installation instructions.
