| 1 |
Building and Installing Radiance with SCons |
| 2 |
| 3 |
| 4 |
This file describes how to build and install Radiance using the SCons |
| 5 |
based build system (an alternative to the traditional makeall script |
| 6 |
explained in the README file). |
| 7 |
| 8 |
| 9 |
Requirements |
| 10 |
| 11 |
| 12 |
Please make sure that you have dowloaded and unpacked BOTH the Radiance |
| 13 |
source package AND the archive with the auxiliary support files. |
| 14 |
Crucial parts of the system will be missing if you only have one of |
| 15 |
them, and SCons will be unable to build the software. |
| 16 |
| 17 |
SCons is a platform-independent software configuration and build system |
| 18 |
written in Python. If SCons and Python are not already installed on your |
| 19 |
system, then you need to download and install them first. |
| 20 |
| 21 |
Python: http://www.python.org/ |
| 22 |
SCons: http://www.scons.org/ |
| 23 |
| 24 |
For many systems, precompiled packages are available, such as Installer |
| 25 |
files for Windows. Most Linux distributions already come with Python |
| 26 |
installed and ready to use. |
| 27 |
| 28 |
SCons *may* use a libtiff already installed on your system. However, if |
| 29 |
it doesn't find one, it will build its own from sources included with |
| 30 |
Radiance. |
| 31 |
| 32 |
| 33 |
Building |
| 34 |
| 35 |
| 36 |
For building Radiance, go to the "ray" directory (where this file |
| 37 |
resides) in a console window and type: |
| 38 |
| 39 |
$> scons build |
| 40 |
| 41 |
or just |
| 42 |
| 43 |
$> scons |
| 44 |
| 45 |
The Scons program will find the necessary information, display a |
| 46 |
copyright message for you to acknowledge, and proceed to build the |
| 47 |
software. |
| 48 |
| 49 |
| 50 |
Configuring |
| 51 |
| 52 |
| 53 |
In the subdirectory "ray/platform/" there are a number of configuration |
| 54 |
files for various build environments. In this context, a "platform" is a |
| 55 |
specific combination of operating system and build tools (eg. compiler). |
| 56 |
On unix based systems, the compiler usually doesn't make much of a |
| 57 |
difference, but on Windows, there are seperate build environments for |
| 58 |
toolkits like Cygwin or MingW. |
| 59 |
| 60 |
The file "ray/platform/README" explains the settings that can be |
| 61 |
configured in those files, and how to create a new one, if you use a |
| 62 |
platform that isn't supported yet. |
| 63 |
| 64 |
| 65 |
Options |
| 66 |
| 67 |
| 68 |
You can add the following command line options when invoking Scons. |
| 69 |
The directories given here will override those specified in the |
| 70 |
configuration file. |
| 71 |
| 72 |
RAD_BINDIR=<directory> |
| 73 |
Install executables here |
| 74 |
(Default read from config file) |
| 75 |
| 76 |
RAD_MANDIR=<directory> |
| 77 |
Install man pages here |
| 78 |
| 79 |
| 80 |
RAD_RLIBDIR=<directory> |
| 81 |
Install support files here |
| 82 |
| 83 |
| 84 |
RAD_DEBUG=1|0 |
| 85 |
1: Build a debug version |
| 86 |
0: Build a production version (default) |
| 87 |
| 88 |
SKIP=1|0 |
| 89 |
1: Skip display of License terms |
| 90 |
0: Don't skip (default) |
| 91 |
| 92 |
SCons will remember the values given with those options. You don't need |
| 93 |
to supply them again each time when you run repeated builds and |
| 94 |
installs, but only when something changes. |
| 95 |
| 96 |
Invoking SCons with the -H flag will display informtion about many other |
| 97 |
options, but you won't normally need any of those. |
| 98 |
| 99 |
| 100 |
Testing |
| 101 |
| 102 |
| 103 |
Radiance comes with a (still very incomplete) test suite, which can be |
| 104 |
run by invoking |
| 105 |
| 106 |
$> scons test |
| 107 |
| 108 |
This executes a series of tests, each indicating success or failure. |
| 109 |
Testing will use the Radiance binaries in the "ray/bin/" directory, and the |
| 110 |
support files in "ray/lib/", where they are located after building but |
| 111 |
before installing. However, it will not trigger a (re-)build if any of |
| 112 |
those files are out of date or missing (instead, it will complain about |
| 113 |
failed tests because of missing executables etc.). You need to manually |
| 114 |
invoke building and testing after each other to ensure that everything |
| 115 |
is where it should be. |
| 116 |
| 117 |
Users (that means you!) are invited to contribute more test cases. |
| 118 |
The goal is that eventually (almost) all Radiance functionality can be |
| 119 |
tested for compliance with the specification and/or expected results. |
| 120 |
| 121 |
See the file "ray/test/README.txt" for details about the testing framework |
| 122 |
and instructions on how to contribute test cases. |
| 123 |
| 124 |
| 125 |
Installation |
| 126 |
| 127 |
| 128 |
The software will be installed into the directories given either in the |
| 129 |
configuration file or through command options, by invoking |
| 130 |
| 131 |
$> scons install |
| 132 |
| 133 |
To do this you need write permission in the target directories. |
| 134 |
Any files that are not present or not up to date will be (re-)built |
| 135 |
before being installed. |
| 136 |
| 137 |
You can install parts of the software by specifying one of three special |
| 138 |
targets: |
| 139 |
| 140 |
$> scons bininstall # only executable files |
| 141 |
$> scons rlibinstall # only support files |
| 142 |
$> scons maninstall # only manual pages |
| 143 |
| 144 |
| 145 |
Cleanup |
| 146 |
| 147 |
| 148 |
To save disk space on your system, or in preparation of a fresh build |
| 149 |
with different settings, you can clean up the source tree by invoking |
| 150 |
| 151 |
$> scons -c |
| 152 |
| 153 |
This will delete all the generated object files, libraries, and |
| 154 |
executables in and below the "ray/src/" subdirectory. |
| 155 |
| 156 |
