root/radiance/CMakeLists.txt
Revision: 1.18
Committed: Sat Aug 19 14:16:15 2017 UTC (8 years, 1 month ago) by greg
Minor fixes for 5.1 release
1 cmake_minimum_required(VERSION 2.8.4)
2 project("radiance")
3
4 if(NOT ${CMAKE_VERSION} VERSION_LESS "2.8.11")
5 cmake_policy(SET CMP0020 NEW)
6 if(NOT ${CMAKE_VERSION} VERSION_LESS "3.0")
7 cmake_policy(SET CMP0042 NEW)
8 if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1")
9 cmake_policy(SET CMP0054 NEW)
10 endif()
11 endif()
12 endif()
13
14 enable_testing()
15 include(CTest)
16
17 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
18 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
19 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
20
21 option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF)
22
23 if( CPACK_NREL_SUPPORT )
24 # find git so we can query for the current git tag
25 find_program(git git)
26 if (NOT git)
27 message(ERROR "Please specify the path to the git executable")
28 endif()
29
30 # call git log to get output containing the tag
31 execute_process(
32 COMMAND ${git} describe --tag --exact-match
33 WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
34 OUTPUT_VARIABLE git_tag_output)
35
36 # create & install the source version .txt file
37 file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}")
38 install(FILES NREL_ver.txt DESTINATION bin/..)
39 endif()
40
41 if(NOT WIN32)
42 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
43 install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
44 set(qt_plugin_term "PLUGIN")
45 endif()
46
47 if (WIN32)
48 set(CPACK_NSIS_MODIFY_PATH 1)
49 set(qt_plugin_term "LIBRARY")
50
51 # Set RAYPATH on install
52 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
53 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
54 )
55
56 # Unset RAYPATH on uninstall
57 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
58 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
59 )
60 endif()
61
62 if(UNIX)
63 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
64 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
65 else()
66 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
67 endif()
68
69 if(APPLE)
70 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
71 include_directories(/usr/X11R6/include)
72 SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6")
73 endif()
74
75 IF( BUILD_PACKAGE )
76 INCLUDE(radianceCPack.cmake )
77 ENDIF( BUILD_PACKAGE )
78
79 set(CPACK_PACKAGE_VERSION_MAJOR 5)
80 set(CPACK_PACKAGE_VERSION_MINOR 1)
81 set(CPACK_PACKAGE_VERSION_PATCH 0)
82 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
83 SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
84 SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
85 SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
86
87
88 include(CPack)
89
90 if(NOT BUILD_HEADLESS)
91 find_package(Qt5Widgets)
92 find_package(X11)
93 endif()
94
95 SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
96
97 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
98 set(_INTEL_WINDOWS 1)
99 endif()
100 if(MSVC OR _INTEL_WINDOWS)
101 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
102 endif()
103 if(WIN32)
104 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
105 endif()
106
107 add_subdirectory("src")
108
109 set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
110 option(BUILD_TESTING "Download support tarball & enable testing?" ON)
111
112 if(BUILD_TESTING)
113 #download and extract radiance support files
114 include(ExternalProject)
115 set(base "${CMAKE_BINARY_DIR}/Downloads")
116 set_property(DIRECTORY PROPERTY EP_BASE ${base})
117 ExternalProject_Add(radiance_support
118 URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
119 URL_MD5 efd82970e1d0747eede8eb64c01048f4
120 CONFIGURE_COMMAND ""
121 BUILD_COMMAND ""
122 INSTALL_COMMAND ""
123 )
124
125 #install support files.
126 set(lib_dir ${base}/Source/radiance_support/lib)
127 install(
128 FILES
129 ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
130 ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
131 ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
132 ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
133 ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
134 ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
135 ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
136 ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
137 ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
138 ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
139 ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
140 ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
141 ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
142 ${lib_dir}/page1.txt ${lib_dir}/page2.txt
143 ${lib_dir}/Pix.fnt
144 ${lib_dir}/PixOblique.fnt
145 ${lib_dir}/Veerdana.fnt
146 ${lib_dir}/VeerdanaBold.fnt
147 ${lib_dir}/VeerdanaBoldItalic.fnt
148 ${lib_dir}/VeerdanaItalic.fnt
149 ${lib_dir}/helvet.fnt
150 ${lib_dir}/hexbit4x1.fnt
151 ${test_dir}/model.oct
152 ${test_dir}/model.vp
153 DESTINATION lib
154 )
155
156 install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
157 install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
158 install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
159 install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
160 install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
161 install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
162 install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
163 install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
164 install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
165 install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
166 install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
167 install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
168 install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
169 install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
170 install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
171
172 add_subdirectory(cmake_tests)
173 endif()
174
175 install(
176 FILES
177 ${test_dir}/model.oct
178 ${test_dir}/model.vp
179 DESTINATION lib
180 )
181
182 include(InstallRequiredSystemLibraries)
183 add_subdirectory(InstallRules)
