root/radiance/CMakeLists.txt
Sun Sep 28 19:53:23 2025 UTC (2 weeks, 1 day ago) by greg
Changes since 1.33: +15 -4 lines
Diff to previous 1.33 , to selected 1.26
chore: Mingbo fixed libtiff issues under Windows
Thu Jul 24 01:24:01 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 1.32: +2 -0 lines
Diff to previous 1.32 , to selected 1.26
chore: Added version string to all CMakeLists.txt files
Wed Jul 23 16:20:13 2025 UTC (2 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.31: +1 -0 lines
Diff to previous 1.31 , to selected 1.26
chore: Build updates to compile rxpiece on non-Window machines (thanks to Mingbo Peng)
Tue Dec 5 21:47:27 2023 UTC (22 months, 1 week ago) by greg
Changes since 1.30: +4 -2 lines
Diff to previous 1.30 , to selected 1.26
chore: Added cmake support for C++ compilation
Wed Nov 22 17:12:58 2023 UTC (22 months, 3 weeks ago) by greg
Changes since 1.29: +33 -6 lines
Diff to previous 1.29 , to selected 1.26
chore: Fixes to cmake builds for holodeck and OpenGL thanks to Randolph Fritz
Sat Nov 18 17:25:18 2023 UTC (22 months, 3 weeks ago) by greg
Changes since 1.28: +0 -1 lines
Diff to previous 1.28 , to selected 1.26
chore: hopeful fix to cmake change
Wed Nov 15 18:02:52 2023 UTC (22 months, 4 weeks ago) by greg
Changes since 1.27: +3 -2 lines
Diff to previous 1.27 , to selected 1.26
Tue May 16 22:58:18 2023 UTC (2 years, 4 months ago) by greg
Changes since 1.26: +9 -2 lines
Diff to previous 1.26
chore: Removed qt from macOS X and Linux builds as it was having issues
Revision 1.26 - (view) (download) (annotate) - [selected]
Wed Jan 11 23:31:17 2023 UTC (2 years, 9 months ago) by greg
Changes since 1.25: +5 -5 lines
Diff to previous 1.25
chore: Reinstated Qt dependencies/builds
Wed Jan 11 23:18:57 2023 UTC (2 years, 9 months ago) by greg
Changes since 1.24: +6 -5 lines
Diff to previous 1.24 , to selected 1.26
chore(libtiff): Trying to fix compile issue for libtiff under Windows
Mon Nov 8 15:38:51 2021 UTC (3 years, 11 months ago) by greg
Diff to previous 1.23 , to selected 1.26
chore: Checked in flag to eliminate warnings (thanks to Randolph Fritz)
Fri Jul 17 16:05:05 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.22: +1 -0 lines
Diff to previous 1.22 , to selected 1.26
chore(Windows): added installer root location
Wed Apr 3 20:18:54 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.21: +4 -0 lines
Diff to previous 1.21 , to selected 1.26
Checked in Rob G's changes for unit testing
Wed Jun 20 20:51:24 2018 UTC (7 years, 3 months ago) by greg
Changes since 1.20: +1 -3 lines
Diff to previous 1.20 , to selected 1.26
Updates to package installers from Rob G.
Wed Jun 20 03:04:44 2018 UTC (7 years, 3 months ago) by greg
Changes since 1.19: +4 -1 lines
Diff to previous 1.19 , to selected 1.26
Changes by Randolph Fritz to make cmake compiles smoother on Mac
Mon Jan 8 16:51:31 2018 UTC (7 years, 9 months ago) by greg
Changes since 1.18: +83 -112 lines
Diff to previous 1.18 , to selected 1.26
Update to CMake build system from Rob G. and Alex S., adding test cases
Sat Aug 19 14:16:15 2017 UTC (8 years, 1 month ago) by greg
Diff to previous 1.17 , to selected 1.26
Minor fixes for 5.1 release
Tue Mar 22 21:36:24 2016 UTC (9 years, 6 months ago) by greg
Diff to previous 1.16 , to selected 1.26
Rob G. fixes for "headless" target
Thu Feb 4 20:16:22 2016 UTC (9 years, 8 months ago) by greg
Diff to previous 1.15 , to selected 1.26
Change open filetype mask in rvu Windows app
Fri May 8 18:07:38 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.14: +11 -1 lines
Diff to previous 1.14 , to selected 1.26
Fixes for rvu under Windows
Tue Apr 21 19:16:51 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.13: +2 -2 lines
Diff to previous 1.13 , to selected 1.26
Fixes for Windows and photon map
Thu Aug 21 19:38:23 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Diff to previous 1.12 , to selected 1.26
Updated top-level cmake file
Fri Apr 18 20:51:49 2014 UTC (11 years, 5 months ago) by greg
CVS Tags: rad4R2
Diff to previous 1.11 , to selected 1.26
Installation fix
Wed Apr 16 20:48:07 2014 UTC (11 years, 6 months ago) by greg
Changes since 1.10: +21 -2 lines
Diff to previous 1.10 , to selected 1.26
Removed objview Ruby script, which is no longer needed for Windows
Tue Mar 25 21:22:30 2014 UTC (11 years, 6 months ago) by greg
Changes since 1.9: +10 -6 lines
Diff to previous 1.9 , to selected 1.26
Changes to set RAYPATH on Windows platforms more reliably
Thu Mar 20 22:49:21 2014 UTC (11 years, 6 months ago) by greg
Changes since 1.8: +5 -2 lines
Diff to previous 1.8 , to selected 1.26
Changes to speed installation on cloud computing systems
Mon Sep 23 22:17:28 2013 UTC (12 years ago) by greg
Changes since 1.7: +1 -0 lines
Diff to previous 1.7 , to selected 1.26
Make executables backwards-compatible to MacOS X 10.6.x
Thu Aug 16 17:59:45 2012 UTC (13 years, 2 months ago) by greg
Changes since 1.6: +4 -0 lines
Diff to previous 1.6 , to selected 1.26
Added NREL acknowledgment
Tue Jun 19 16:41:46 2012 UTC (13 years, 3 months ago) by greg
Diff to previous 1.5 , to selected 1.26
Added missing cmake files
Wed May 30 18:31:11 2012 UTC (13 years, 4 months ago) by greg
Changes since 1.4: +67 -56 lines
Diff to previous 1.4 , to selected 1.26
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (13 years, 5 months ago) by greg
Changes since 1.3: +51 -24 lines
Diff to previous 1.3 , to selected 1.26
Wed Oct 26 16:48:01 2011 UTC (13 years, 11 months ago) by greg
Diff to previous 1.2 , to selected 1.26
Tue Oct 25 22:53:14 2011 UTC (13 years, 11 months ago) by greg
Changes since 1.1: +5 -5 lines
Diff to previous 1.1 , to selected 1.26
Added files needed by cmake
Sat Oct 22 22:38:10 2011 UTC (13 years, 11 months ago) by greg
Diff to selected 1.26
Added qt interface for rvu and cmake files from Bill Hoffman
