| 1 |
greg |
1.1 |
cmake_minimum_required(VERSION 2.8.4) |
| 2 |
project("radiance") |
| 3 |
| 4 |
enable_testing() |
| 5 |
include(CTest) |
| 6 |
| 7 |
option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF) |
| 8 |
greg |
1.9 |
option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF) |
| 9 |
greg |
1.1 |
| 10 |
greg |
1.11 |
option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF) |
| 11 |
| 12 |
if( CPACK_NREL_SUPPORT ) |
| 13 |
# find git so we can query for the current git tag |
| 14 |
find_program(git git) |
| 15 |
if (NOT git) |
| 16 |
message(ERROR "Please specify the path to the git executable") |
| 17 |
endif() |
| 18 |
| 19 |
# call git log to get output containing the tag |
| 20 |
execute_process( |
| 21 |
greg |
1.12 |
COMMAND ${git} describe --tag --exact-match |
| 22 |
greg |
1.11 |
WORKING_DIRECTORY ${CMAKE_SOURCE_DIR} |
| 23 |
greg |
1.12 |
OUTPUT_VARIABLE git_tag_output) |
| 24 |
greg |
1.11 |
| 25 |
# create & install the source version .txt file |
| 26 |
greg |
1.12 |
file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}") |
| 27 |
greg |
1.11 |
install(FILES NREL_ver.txt DESTINATION bin/..) |
| 28 |
endif() |
| 29 |
| 30 |
greg |
1.1 |
if(NOT WIN32) |
| 31 |
greg |
1.4 |
set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1) |
| 32 |
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man) |
| 33 |
greg |
1.6 |
set(qt_plugin_term "PLUGIN") |
| 34 |
greg |
1.1 |
endif() |
| 35 |
greg |
1.4 |
| 36 |
if (WIN32) |
| 37 |
greg |
1.10 |
set(CPACK_NSIS_MODIFY_PATH 1) |
| 38 |
set(qt_plugin_term "LIBRARY") |
| 39 |
greg |
1.4 |
| 40 |
greg |
1.10 |
# Set RAYPATH on install |
| 41 |
set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS |
| 42 |
greg |
1.11 |
"WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'" |
| 43 |
greg |
1.10 |
| 44 |
greg |
1.4 |
| 45 |
greg |
1.10 |
# Unset RAYPATH on uninstall |
| 46 |
set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS |
| 47 |
"DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH" |
| 48 |
| 49 |
greg |
1.4 |
endif() |
| 50 |
| 51 |
if(UNIX) |
| 52 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance") |
| 53 |
add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO) |
| 54 |
else() |
| 55 |
greg |
1.5 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/") |
| 56 |
greg |
1.4 |
endif() |
| 57 |
| 58 |
if(APPLE) |
| 59 |
add_definitions(-DBSD -DNOSTEREO -Dfreebsd) |
| 60 |
include_directories(/usr/X11R6/include) |
| 61 |
greg |
1.8 |
SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6") |
| 62 |
greg |
1.4 |
endif() |
| 63 |
| 64 |
greg |
1.7 |
IF( BUILD_PACKAGE ) |
| 65 |
INCLUDE(radianceCPack.cmake ) |
| 66 |
ENDIF( BUILD_PACKAGE ) |
| 67 |
| 68 |
greg |
1.2 |
set(CPACK_PACKAGE_VERSION_MAJOR 4) |
| 69 |
greg |
1.4 |
set(CPACK_PACKAGE_VERSION_MINOR 2) |
| 70 |
set(CPACK_PACKAGE_VERSION_PATCH a) |
| 71 |
greg |
1.5 |
set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance") |
| 72 |
greg |
1.3 |
SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt") |
| 73 |
greg |
1.4 |
SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt") |
| 74 |
greg |
1.3 |
SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt") |
| 75 |
greg |
1.4 |
| 76 |
| 77 |
greg |
1.1 |
include(CPack) |
| 78 |
| 79 |
greg |
1.9 |
if(NOT BUILD_HEADLESS) |
| 80 |
find_package(Qt4 COMPONENTS QtCore QtGui) |
| 81 |
find_package(X11) |
| 82 |
endif() |
| 83 |
greg |
1.1 |
| 84 |
SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin) |
| 85 |
| 86 |
if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$") |
| 87 |
set(_INTEL_WINDOWS 1) |
| 88 |
endif() |
| 89 |
if(MSVC OR _INTEL_WINDOWS) |
| 90 |
add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE) |
| 91 |
endif() |
| 92 |
if(WIN32) |
| 93 |
add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp) |
| 94 |
endif() |
| 95 |
| 96 |
add_subdirectory("src") |
| 97 |
| 98 |
greg |
1.5 |
set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data) |
| 99 |
option(BUILD_TESTING "Download support tarball & enable testing?" ON) |
| 100 |
| 101 |
if(BUILD_TESTING) |
| 102 |
#download and extract radiance support files |
| 103 |
include(ExternalProject) |
| 104 |
set(base "${CMAKE_BINARY_DIR}/Downloads") |
| 105 |
set_property(DIRECTORY PROPERTY EP_BASE ${base}) |
| 106 |
ExternalProject_Add(radiance_support |
| 107 |
URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz |
| 108 |
URL_MD5 efd82970e1d0747eede8eb64c01048f4 |
| 109 |
CONFIGURE_COMMAND "" |
| 110 |
BUILD_COMMAND "" |
| 111 |
INSTALL_COMMAND "" |
| 112 |
| 113 |
| 114 |
#install support files. |
| 115 |
set(lib_dir ${base}/Source/radiance_support/lib) |
| 116 |
install( |
| 117 |
FILES |
| 118 |
${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal |
| 119 |
${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal |
| 120 |
${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal |
| 121 |
${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal |
| 122 |
${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal |
| 123 |
${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal |
| 124 |
${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal |
| 125 |
${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal |
| 126 |
${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal |
| 127 |
${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal |
| 128 |
${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal |
| 129 |
${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal |
| 130 |
${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal |
| 131 |
${lib_dir}/page1.txt ${lib_dir}/page2.txt |
| 132 |
${lib_dir}/Pix.fnt |
| 133 |
${lib_dir}/PixOblique.fnt |
| 134 |
${lib_dir}/Veerdana.fnt |
| 135 |
${lib_dir}/VeerdanaBold.fnt |
| 136 |
${lib_dir}/VeerdanaBoldItalic.fnt |
| 137 |
${lib_dir}/VeerdanaItalic.fnt |
| 138 |
${lib_dir}/helvet.fnt |
| 139 |
${lib_dir}/hexbit4x1.fnt |
| 140 |
${test_dir}/model.oct |
| 141 |
${test_dir}/model.vp |
| 142 |
DESTINATION lib |
| 143 |
| 144 |
| 145 |
install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic) |
| 146 |
install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic) |
| 147 |
install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic) |
| 148 |
install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic) |
| 149 |
install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic) |
| 150 |
install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic) |
| 151 |
install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic) |
| 152 |
install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic) |
| 153 |
install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic) |
| 154 |
install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic) |
| 155 |
install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic) |
| 156 |
install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic) |
| 157 |
install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic) |
| 158 |
install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic) |
| 159 |
install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic) |
| 160 |
greg |
1.1 |
| 161 |
greg |
1.5 |
add_subdirectory(cmake_tests) |
| 162 |
endif() |
| 163 |
| 164 |
greg |
1.1 |
install( |
| 165 |
FILES |
| 166 |
| 167 |
| 168 |
greg |
1.4 |
DESTINATION lib |
| 169 |
greg |
1.1 |
| 170 |
| 171 |
include(InstallRequiredSystemLibraries) |
| 172 |
add_subdirectory(InstallRules) |
